OME 883's with 5100's
Discussion in 'Suspension' started by thinkingman, Dec 18, 2012.
  1. Dec 18, 2012 at 3:45 PM
    thinkingman
    thinkingman [OP] Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I have searched and read until my eyes bleed....
    2006 DCSB
    Here is the question:
    I installed OME Dakars last week and the lift is pretty dramatic compared to the front.
    I want a mild lift in front so the rake isn't so crazy.
    Can I use stock spring perches on 5100's set a 0?
    How much lift to expect?
    BTW, having springs that actually work is pretty great....I had no idea it would feel this good.
    Thanks.
  2. Dec 18, 2012 at 3:50 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I don't know about stock spring perches, I'd use the ones meant for 5100's. As far as 883's, you can use them on 5100's and you can expect 1.5" of lift out of them when you set the 5100's at 0.
  3. Dec 18, 2012 at 5:33 PM
    thinkingman
    redmond WA
    I don't remember....Did I get new perches with the 5100's?
    If that's the case, I can just plug and play the OME 883's?
    It makes sense.....
