OME 884/5 on a DC?
Discussion in 'Suspension' started by deadbeat son, Jun 11, 2009.
  1. Jun 11, 2009 at 11:57 AM
    deadbeat son
    deadbeat son [OP] Well-Known Member
    Denver, CO
    Okay, I realize OME recommends their 886 coil for the '05-up DC 4x4 models, but let me explain my train of thought.
    I'm looking for a stiffer front suspension, but I don't want to gain much height. I'm running the size tire I want with the stock suspension, but I'd like to firm up the response and add some weight carrying capacity. I'm getting the leaf spring TSB done soon (dealer ordered parts yesterday) so I don't mind lifting the front around 1-1.5", but I really don't want the typical 2.5-3" most people strive for.
    If I run the 885 (or possibly even 884) with the N140 front shocks, what do you think my net gain in height would be? Would the 1" shorter length of the 884 put me too far down in the N140's travel range to be safe?
    Any real world experience with these non-standard combinations is appreciated!
  2. Jun 11, 2009 at 12:07 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Try the Eibachs for the 1.5 lift and I believe they are stiffer than the 884.
  3. Jun 11, 2009 at 12:25 PM
    deadbeat son
    Denver, CO
    Those were my original plan; however, after speaking to Bilstein Tech Support on the phone yesterday, they recommended against running those coils with any of their shocks (to include the 5100) because of the spring rate.
    This truck will see extensive offroad and back country use; the stronger spring rate could have detrimental effects on a shock not designed to support it. This is why I'm looking at an OME system.
  4. Jun 11, 2009 at 12:33 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Just run the 885 coils with the OME shocks. They might be a little tall at first till they settle. But that should work out arlight since you have a Double Cab Truck (they have more weight up front). Plus for serious off-road, I feel like the OME shocks are a little bit more heavy duty than the bilsteins.
  5. Jun 11, 2009 at 12:40 PM
    deadbeat son
    Denver, CO
    Thanks Dan. Maybe I'll get 884s and 885s and see which work best for me with the rear TSB. Same rate but different length, right?
    884 - 14" 590lb/in
    885 - 15" 590lb/in
    Is that correct?
  6. Jun 11, 2009 at 12:53 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Yep, the 886 is also 15" but a 600 or higher rate.
  7. Jun 11, 2009 at 4:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 886 is a 650# rate. :)
  8. Jun 11, 2009 at 4:43 PM
    deadbeat son
    Denver, CO
    After talking with a local OME fitter, they feel the 884/N140 combo will be taller than I'm hoping. I may look into the possibility of an 883/N139 setup.
  9. Jun 11, 2009 at 5:40 PM
    johnecon2001
    Phoenix, AZ
    The 884's will sag quite a bit.. I wouldn't even consider putting that much of a truck on the 883's.
  10. Jun 11, 2009 at 5:49 PM
    deadbeat son
    Denver, CO
    I think your concern is unwarranted.
    883, 884, and 885 are all the same spring rate. There's not a full inch of difference in coil length between the 884 and 885 either, it's only 10mm. The 883 is just 10mm shorter yet. That's less than 1" difference between the 885 and the 883. The local shop sees 3" of lift out of the 885 on a DC. For my particular application, the 883 seems like the most logical choice.
