OME 884 Results
Discussion in 'Suspension' started by TotalBrutal, Mar 15, 2012.
  1. Mar 15, 2012 at 9:20 AM
    TotalBrutal
    TotalBrutal [OP] Well-Known Member
    Dan
    Vancouver Island, BC
    2007 V6 4X4
    Front 5100s @ 0, OME 844s, Rear 5100s, AFE pro dry filter
    So i have seen lots of questions going around on this forum about what kinda heights you can expect with the OME 884 springs compared to 5100s and I have seen no real definitive answers, so i thought i would post my results. I originally had 5100s set at 1.75 with stock offroad springs. My original measurments with 5100s (from hub center to fender) are as follows:
    Driver Front: 21.75"
    Passenger Front: 21.75"
    Driver Rear 22.75"
    Passenger Rear: 23.1"
    Measurements after installing OME 884 springs with 5100s set at 0:
    Driver Front: 22"
    Passenger Front: 22.1"
    Driver Rear 22.75"
    So I ended up gaining an extra quarter inch from the new springs for a total of 2" in the front from stock. Love the way it sits now and rides better IMO. It has a slight lean towards the drivers side in the front now but barely noticible so I dont care, wont bother adding a lean spacer. My alignment was well withing spec in every single category as well, so this is a great lift/level if you do not want the added cost of new UCAs.
  2. Mar 15, 2012 at 9:26 AM
    mclovin
    mclovin chicka chicka, yeah!
    UK
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    i've got an OME system with 884's and i have to say that it rides just as good if not better then the day i drove it off the lot.
