OME 884 with top plate spacers - DCLB
Discussion in 'Suspension' started by BCBoy, Apr 16, 2013.
  1. Apr 16, 2013 at 5:54 PM
    BCBoy
    BCBoy [OP] Active Member
    Vancouver, BC
    11 MGM DCLB Sport
    Custom leather/Heated seats, Leather armrests, Lund Genesis Tonneau, Pop N Lock, 285/70R17 Nitto Terra Grapplers, OME 885x Coils with top plate spacers, 1/4" taco lean spacer, 5100's all around, 1.5" AAL, OME CB drop, Weathertechs, OEM running boards, Extra D-rings, Matt123 TRD Skid Plate, Curt discovery brake controller, Spidertrax wheel spacers
    Last year I made the mistake of putting ome 884 coils on my DC and I ended up with a touch over 2" of lift. I have regretted it since day one so now I am trying to figure out how to get more lift the easiest. My question is, how much lift will I see overall if I add top plate spacers to my 884's? Thanks!
  2. Apr 16, 2013 at 5:56 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Switch to 885's
  3. Apr 16, 2013 at 6:37 PM
    BCBoy
    Vancouver, BC
    11 MGM DCLB Sport
    That's what I'm thinking will work best. Your truck looks great, are you using top plate spacers on your 885's?
  4. Apr 16, 2013 at 6:38 PM
    OZ-T
    Peter North
    British Columbia
    No top plate spacers , just the 5mm OME trim packer on the driver side
  5. Apr 16, 2013 at 7:30 PM
    BCBoy
    Vancouver, BC
    11 MGM DCLB Sport
    That's what I was thinking about doing but I figure I won't get the height I want because my truck is a DC. I may just go with 885's and the 5mm lean spacer. My other option would be to go with 885's with a 1/2 spacer on the driver side and a 1/4 spacer on the passenger because I would still like to have a slight front to back rake. Any opinions on this?
  6. Apr 16, 2013 at 9:22 PM
    BCBoy
    Vancouver, BC
    11 MGM DCLB Sport
    Would that give me roughly 2.75"?
  7. Apr 16, 2013 at 10:14 PM
    OZ-T
    Peter North
    British Columbia
    I got 2 1/2" on my DCLB 4x4 with just the 885's , no top plate spacers
  8. Apr 16, 2013 at 10:48 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Like OZ said 885s will get you 2.5".
    Easiest way would be to add the spacers (amount of lift is twice the thickness of the spacer, 884s & 885s have the same spring rate with the 885s being a little longer).
    Best way would be to swap the 884s for 885s.
    I was at a full 3" front & rear with 885s & Dakars on my AC 4Banger.
    Sliders lowered me 0.25" front & rear. A full set of skids lowered my front another 0.5".
    I added 0.25" top plate spacers to regain 0.5" of what I lost up front and now sit at 2.75" front & rear.
    If you don't plan on adding any weight to your Taco the 884s should be fine. If you do definitely go for the 885s & add spacers when you add weight.
    Old Man Emu: Questions, Answers & Pictures ([​IMG] 1 2 3 ... Last Page)
