OME 885, 5100's, LR UCA Topping out?!
Discussion in 'Suspension' started by steezinstangl, Mar 5, 2013.
  1. Mar 7, 2013 at 9:42 PM
    #41
    steezinstangl
    steezinstangl [OP] Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
  2. Mar 7, 2013 at 9:47 PM
    #42
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Mar 7, 2013 at 10:03 PM
    #43
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    I'm almost positive it isn't! but it's worth a try, i'll check it out when i tear i apart.
  4. Mar 8, 2013 at 12:40 AM
    #44
    Sport2012
    Sport2012 Thin Blue Line
    NJ
    12 TRD Sport DCSB 4x4
    Tint, EGR In Channel visors, Access-Lorado tonneau, Tacoma bed mat, Plasti Dip Badges, Tailgate mod, Fog light anytime mod, Toytec (TTHA-CK) 3" lift kit w/height adjustable coilovers, 5100's w/Eibach coils, TSB AAL, LR UCA's, CB drop kit, Diff drop kit, XD spy's on 285/70/17 Duratrac's
    I have a 2012 sport DCSB. I just installed the Toytec (TTHA-CK) 3" lift kit, 5100's w/Eibach coils and LR UCA's last week. I'm also having that same issue, over speed bumps or pot holes. It feels like the shocks dont have enough travel, either up or down i'm not sure. Hope someone can provide a solution. I am totally a novice at all of this, but it seems the problem is the shocks....
    Is it possible that these 5100's are "maxed out" in length?
    Or that their travel is restricted?
  5. Mar 8, 2013 at 6:32 AM
    #45
    SnowmanFX
    SnowmanFX Well-Known Member
    San Antonio, TX
    TX Pinstriped 08 Tacoma
    3" Lift w/small goodies
    Strut > Washer > Rubber mount > Top Hat > Rubber Mount > Washer > Nut
    The Washers are concave and should cup the rubber mounts. I can see the tops are OK but if the underside ones are missing the washer the shock can push right through the rubber any time it wants.
    I had this noise on my truck just on the drivers side and I believe it was because I had play in the top hat bolted to the strut. I had almost 1/4" less thread showing than the passenger side. When I would hit bumps it sounded like my strut was just flopping around in there.
  6. Mar 8, 2013 at 8:52 AM
    #46
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    im pretty sure i have all the washer and rubber mounts in the right places. What do you mean exactly that you had play in the top hat bolted to the strut? like the top plate that has the 3 bolts to tighten to the strut mount on the frame?
  7. Mar 8, 2013 at 8:56 AM
    #47
    Pilot68
    Pilot68 Well-Known Member
    Jared
    Socal
    12 Tacoma Double Cab TRD Sport
    Bilstein 5100 on all 4 (fronts set 1.85"), FJ Trail Wheels, Bridgestone Revo 2s (265/75/16), Viper 5704, 18% Carbon Window Tint, Euro Antenna
    The bottom coil plate on the 5100 is probably upside down...
  8. Mar 8, 2013 at 8:58 AM
    #48
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    It looks like it is the correct way to me.
    OP,
    What is the measurement from the center of the hub up to the fender?
  9. Mar 8, 2013 at 1:37 PM
    #49
    SnowmanFX
    San Antonio, TX
    The nut on the strut, not being tight all the way so when it was compressed it would move up and then back down and hit the washer and make noise.
  10. Mar 8, 2013 at 3:32 PM
    #50
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    about 24 inches
  11. Mar 8, 2013 at 3:43 PM
    #51
    OZ-T
    Peter North
    British Columbia
    With the 5100's @ 0 ?
  12. Mar 8, 2013 at 3:46 PM
    #52
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    yes, i got a pretty big lift from the 885's. i expected it to be lower from what everyone says
  13. Mar 8, 2013 at 3:49 PM
    #53
    OZ-T
    Peter North
    British Columbia
    Somethings not right
  14. Mar 8, 2013 at 4:34 PM
    #54
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    crap, excuse my mistake i measured from the middle of the center cap on my wheel so it might be off. i'll remeasure.
  15. Mar 8, 2013 at 4:49 PM
    #55
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    I have the exact same setup, but mine is a 4x4.
    hub to fender up front is 23 1/8" driver side, 23 1/4" passenger side.
  16. Mar 8, 2013 at 7:06 PM
    #56
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    well i tried tightening the nut up, no luck
  17. Mar 8, 2013 at 7:43 PM
    #57
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    FOUND A FIX!!!!
    Spray white grease, or maybe use graphite grease which is better and put it all around the bottom coil and on the bottom coil plate. The metal on metal contact with the spring moving there was making the noise. went over speed bumps again and it finally sounds normal like when it was stock!
  18. Mar 8, 2013 at 8:01 PM
    #58
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    good to hear.
  19. Mar 8, 2013 at 10:37 PM
    #59
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    alright never mind, grease ended up not working. the clunk came back...
  20. Mar 8, 2013 at 10:45 PM
    #60
    OZ-T
    Peter North
    British Columbia
    Something is not right with your 24" hub to fender up front with just 885's providing the lift
