OME 885, 5100's, LR UCA Topping out?!
Discussion in 'Suspension' started by steezinstangl, Mar 5, 2013.
  1. Mar 14, 2013 at 6:41 PM
    #121
    steezinstangl
    steezinstangl [OP] Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    what i plan on doing down the road is putting part of a bike tube or finding rubber things to cushion the coil on the bottom coil plate so it wouldn't have metal on metal contact. but i don't wanna mess with it since id rather not get another alignment lol
  2. Mar 14, 2013 at 6:53 PM
    #122
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    If the coil is seated properly i highly doubt that it is bouncing off of the coil seat making a noise
  3. Mar 14, 2013 at 7:38 PM
    #123
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    it is seated properly, man i don't even know anymore haha, i'll just drive it
  4. Mar 14, 2013 at 9:50 PM
    #124
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    My access cab got full 3" with just the coils too.
  5. Mar 14, 2013 at 10:29 PM
    #125
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    do you have that clunk or thud sound too right after going over the top of the speed bump?
  6. Mar 17, 2013 at 8:49 PM
    #126
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Yeah but it's a lot less noticable the more weight I have in the truck. I've got a little over 2000 miles on my lift now and it's not as bad now as was at the beginning.
    With 30 cement blocks stacked in the front half of the bed and a 200lb passenger the front does smooth out quite a bit but still bangs some.
    I've put marking paint in various places and haven't fount any contact happening (none of that paint chipping/rubbing off).
    Like we've said earlier, I'm pretty sure is just that the access cab prerunner doesn't have enough front weight to compress the 885s down for normal driving so the shock is getting slammed to full extension a lot.
    I'm thinking about make a front skid plate bull bar thing for the main purpose of getting some weight out front but that'll depend on how much the materials would cost. Not willing to spend much on it.
  7. Mar 18, 2013 at 9:13 PM
    #127
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Agreed. It has to be the weight since we have the lightest tacomas available other than the regular cab. Other than that I love the suspension set up I have. Well worth every penny.
  8. Mar 20, 2013 at 8:08 AM
    #128
    SnowmanFX
    SnowmanFX Well-Known Member
    San Antonio, TX
    TX Pinstriped 08 Tacoma
    3" Lift w/small goodies
    After thinking back, I had a clunk when mine were brand new but it was only on the drivers side.
    I think after a trip out to Big Bend State Park and baja driving they settled and stopped, cause I haven't heard it since.
  9. Mar 20, 2013 at 8:54 AM
    #129
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    after a few weeks of driving it, the clunk has pretty much gone away, suspension even feels smoother and softer. i think the shocks and coils breaking in has really helped it. maybe a little offroad adventure might help it too like you said haha :cool:
  10. Mar 25, 2013 at 11:07 AM
    #130
    jerysan
    jerysan Well-Known Member
    San Diego
    09 PreRunner TRD Off Road SB
    Flowmaster 40 Delta Flow, K&N Air filter, TSB Rear AAL with 1" Block & 5100's, OME 885x with OME Nitrocharged and Toytec Top spacers, Built Right UCA's , Satoshi Grille, HID's, Bull Bar,
    Have the same sound coming from the front passenger side. I have the 885x with 5100's set at 0 with top spacer kit. It's only been a week on the install.
    2009 Prerunner DCSB V6
  11. Mar 26, 2013 at 10:26 AM
    #131
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I have a similar sound on both sides that started when I installed TC UCAs and 886x springs on 5100s a couple weeks ago. It started on the driver's side. Then a day later, the passenger side started doing it.
    2005 DC 4x4 w/bumper and winch
  12. Mar 26, 2013 at 11:59 AM
    #132
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    Strap it so it doesn't top out. Problem solved /thread
  13. Mar 27, 2013 at 4:57 PM
    #133
    jerysan
    San Diego
    Searched for the limit straps and can't find a thread....
  14. Apr 1, 2013 at 2:58 PM
    #134
    jerysan
    San Diego
    I had the same problem on my and decided to take it to the Truck Shop here in San Diego. I talked with James there and he told me that the shocks were maxed out. So my OME 885x with the 5100's set at 0" plus the Toytec top spacer kit didn't work like i had belived. So, had had the spacers removed there and know the truck rides fine, no more clunk/thud going over bumps. Had to compensate height.
    Hope this helps you out.
  15. Apr 1, 2013 at 9:21 PM
    #135
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    double cab huh?
  16. Apr 6, 2013 at 9:45 PM
    #136
    Carmaniac
    Carmaniac Member
    Tim
    Cheyenne, WY
    06 Double Cab TRD OR
    OME ARB Bumper Warn Winch Topper Duratracs 3-kid Mod
    I'm having the EXACT same issue. DCSB 4x4 with 885 and OME shocks. Horrible speed bump clunk and like you, offroading, rattles and clunks. I'm almost thinking about going back to stock it frustrates me so much. I email ToyTec, whom I purchased the lift from, and they told me to give it time, and most people like the set up. Sure. I might be driving down there when I get back in town from work. Its not right.
  17. Apr 6, 2013 at 10:04 PM
    #137
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    I have a 4x4 access cab with bilstein/eibach coilovers assembled from toytec. I had no clank noise until a few thousand miles AFTER the lift was installed. It was right around the same time I added winch/bumper/armor. Not sure if the timing was coincidental or not.. Driving down "wash board" dirt roads really gets the clank going!! I've inspected everything myself and even had a few shops look it over.. Nobody has found anything wrong. I've kinda gotten used to the clank noise..
  18. Apr 6, 2013 at 10:11 PM
    #138
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Have you checked to make sure your coils are seated correctly ?
  19. Apr 7, 2013 at 4:05 PM
    #139
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    it does get better over time, still a clunk over some speed bumps but nowhere near how bad it was at first, give it a little while to break in. sadly i don't think we'll be able to truly fix it:( but none the less, still a great suspension setup i think
  20. Apr 8, 2013 at 12:38 PM
    #140
    Carmaniac
    Carmaniac Member
    Tim
    Cheyenne, WY
    The coils are seated correct as far as I can tell. I ordered them assembled from ToyTec as I have done too many lifts, and I get tired of compressing springs! :D
    I will give it a little more time, but I might end up going another route. Just helped a friend install Toytec coil overs on his 3rd gen runner, and his ride made me jealous. I also had OME on my last 3rd Gen Runner and NEVER had a problem like this. Rather dissappointing. If anyone ever figures anything out post up, and I will do the same!
    Bckcntrytrout likes this.
