OME 885, 886, or eibach coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mickdizzle, Jan 4, 2012.
  1. Jan 4, 2012 at 4:43 AM
    Mickdizzle
    Mickdizzle [OP] Well-Known Member
    Montana
    12 TX Pro
    I am just looking for my best option on a coil for my '12 tacoma. I am going to install height adjustable bilsteins all around and I am trying to find a coil that will support the bumper that i am possibly going to put on in the future. I just don't want to have something too stiff on there and sacrifice the ride too much.
  2. Jan 4, 2012 at 4:51 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Well it will be stiff. Not too bad tho. How much weight are you going to add. If its around 100 do the 885s and keep the 5100 set at .85 DO NOT SET THEM ANY HIGHER. The rear 5100 do not add lift so you will need an aal or block.
    If you get the 886 it will be stiffer then the 885 but they hold more weight. And with the 886 the 5100 have to be set at 0.
    With both set ups you will also need new UCA also.
  3. Jan 4, 2012 at 4:57 AM
    Mickdizzle
    Montana
    12 TX Pro
    I am getting a 2" AAL in the rear. If i get the 885's and set at zero it will raise my front 2" won't it?
  4. Jan 4, 2012 at 5:00 AM
    Blackshirts
    TX
    Stuff
    Yes you will get just about that. Maybe lil less with the weight of the new bumber.
  5. Jan 4, 2012 at 5:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How much weight do you want to add and how much lift do you want after the weight is added?
    Eibachs are stiff, they have a 620 #/in rating and give you 1.6" of lift with 5100's at 0 and just under 2.5" when you set the 5100's at .85. They'll sag a little under the load of a plate bumper but are stiff enough to handle the weight.
    885's I believe are 588 #/in and will give you about 2.5" of lift unloaded, 3" if you use a top plate spacer with them. I wouldn't preload the 885's.
    886's are 656 #/in and are made to give you close to 3" of lift with 200+ lbs hanging off the front end (ARB bumper with a winch). Unless you're really putting a lot of weight up front, I wouldn't recommend the 886's. If you do go with them, I'd get the Nitrochargers instead of the 5100's. They seem to be a better match.
    WebberLander likes this.
  6. Jan 4, 2012 at 5:31 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    ^^^ I'm running 5100's and Eibach's on my both my Tacoma & 4Runner which have ARB's and winches, but, if I would have found this site sooner I would have gone with the Nitros and 886's. As they were designed to compliment this set up by the folks who actually use and develop the products. A little education up front makes all the difference. Live and learn, but at least learn.
  7. Jan 4, 2012 at 9:33 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Don't run billies with the 886 coils , if you get 886's shell out for the OME shocks
  8. Jan 6, 2012 at 4:38 AM
    Mickdizzle
    Montana
    12 TX Pro
    i am undecided if i am going to go with the ARB, Iron bull, or Road Armor bumpers. they are all pretty heavy bumpers. I think i may just go with the 885's with the 5100's set at zero and a 2" AAL in the rear. should level the truck out pretty good with a bumper on there
  9. Jan 6, 2012 at 5:10 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    like others have said you are much better off matching the OME shocks with the coils and not mixing up the billies with them. just another person putting in their .02 but ive had a spacer lift, 5100's, eibachs, and now full ome lift and am wishing i would have just saved my money to begin with and gotten the full ome to start with. but its your truck and ultimately you will be the person to decide what you want on it.
  10. Jan 6, 2012 at 9:46 AM
    Mickdizzle
    Montana
    12 TX Pro
    Would you run the OME Shocks in the rear as well?
  11. Jan 6, 2012 at 10:42 AM
    TacoFMS
    Justin
    Louisa County, VA
    i am right now. if you are going full ome up front you might as well go with it in the back. they are only a few dollars more than the rear 5100's and i had a set of the 5100's on my previous truck and they didnt seem as solid as these ome ones. but that is just my opinion, not fact.
  12. Jan 6, 2012 at 3:37 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    885's with Billies set at 0" or use the OME shocks. But, you can use the OME 885's with stock TRD shocks FWIW.
  13. Jan 6, 2012 at 4:38 PM
    Mickdizzle
    Montana
    12 TX Pro
    alright after talking to some people today i am going with the OME setup. I am still going with a heavier bumper so undecided if i should go with the 885's or 886's. Do they make a full kit?
  14. Jan 6, 2012 at 4:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If by "full kit" you mean a single order for all the parts- Yes. Downsouth Motorsports,TRDParts4U, or MetalTech can all hook you up. They'll also be able to talk to you about options for UCAs and probably sell you whatever you choose.
  15. Jan 6, 2012 at 4:55 PM
    Mickdizzle
    Montana
    12 TX Pro
  16. Jan 6, 2012 at 5:03 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Upper Control Arms. With the amount of lift you are seeking they are "highly recommended" upgrade. They are not required per se- but they will make your truck easier to align and give you the proper amount of travel.
  17. Jan 6, 2012 at 5:11 PM
    OZ-T
    Peter North
    British Columbia
    Gonna do a winch ?
  18. Jan 6, 2012 at 5:37 PM
    Mickdizzle
    Montana
    12 TX Pro
    most definetly. That is why i am throwing the bumper on it. Damn the more i research this stuff the more money i am throwing into it ha ha. any suggestions on a rear add a leaf?
  19. Jan 6, 2012 at 7:01 PM
    OZ-T
    Peter North
    British Columbia
    Get 886's and OME 90000 Nitrochargers up front then .
    I have Dakars in the rear of my truck .
  20. Jan 7, 2012 at 5:03 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    This- The ride will be stiff until you get the bumper but such is life.
    And I like the wheelers 3 pack AAL that I'm running right...and I'm pretty sure I'm going to like my Dakar pack even more.
