OME 885 and 5100
Discussion in 'Suspension' started by Blouder, Mar 12, 2013.
  1. Apr 1, 2013 at 9:53 AM
    Blouder
    Blouder [OP] Well-Known Member
    That's a good idea. I have the top plate spacer still.
    Yes, I have a double cab with a v6.
  2. Apr 1, 2013 at 9:57 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've had my 885's with 5100's for almost 5 years now and still feel great!
  3. Apr 1, 2013 at 10:15 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Good to know!! I just finished picking up the rest of my lift...
    885x's with 5100's front and back and 2" toytec AAL (for now), LR UCA's
    Pumped to get everything on!!
  4. Apr 1, 2013 at 10:17 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Pretty much the same setup I started out with but I have the old 885's and I have TC UCA's and installed ICON rear reservoir shocks I won from DSMS. :D
  5. Apr 1, 2013 at 10:20 AM
    teneighty
    Nice! Yeah eventually dakars and we'll see what else.
    Now to make up my mind on some wheels and tires :notsure:
  6. Apr 1, 2013 at 10:21 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Are you getting the top plate spacers too?
  7. Apr 1, 2013 at 10:37 AM
    teneighty
    Yes, got them. And the sway bar relocate. Not sure if its needed.
  8. Apr 1, 2013 at 10:38 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay cool. I dont have the sway bar relocate kit but I'm sure it wont harm anything. I did install the diff drop kit though.
  9. Apr 1, 2013 at 10:41 AM
    teneighty
    I'm waiting to see what I need after I lift it. Diff drop, carrier bearing... I'm an LB and from what I've read, I should be ok due to the length.
  10. Apr 1, 2013 at 10:43 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    The diff drop kit isnt required but I just got it anyways for peace of mind and I got no vibrations before I installed them cause I put them on a couple months after I lifted.
  11. Apr 1, 2013 at 10:52 AM
    teneighty
    Probably do the same... It's a 13' so I don't want any issues.
  12. Apr 1, 2013 at 10:53 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I hear yah and the diff drop kits are pretty cheap.
  13. Apr 1, 2013 at 11:09 AM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    The OP shouldnt have the 5100's at .85
    If he had them set at 0" the 885's should work perfect and not top out.
    Add the 1/4 spacer to fix taco lean.
  14. Apr 1, 2013 at 11:16 AM
    teneighty
    This ^ ^
  15. Apr 1, 2013 at 11:59 AM
    #35
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Thats true but if he wants the full 3" of lift up front he will have to add the top plate spacers. I believe the 885's only give 2.5" of lift and not a full 3".
  16. Apr 1, 2013 at 12:02 PM
    #36
    teneighty
    This ^
    Might do a 1/2" spacer (approx 3/4") on drive side then 1/4" on pass. side.
  17. Apr 1, 2013 at 12:14 PM
    #37
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    This is what I am toying with also.....either just using a 1/4" on driver for lean..... OR doing what you described for lean and a boost.
    Being an Access cab I may not need them for a full 3" but after seeing Pacmac's thread a while back I'll prob go with the combo and get a full 3" of lift. Just worried bout those vibes the higher I go.
  18. Apr 1, 2013 at 12:36 PM
    #38
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I'm not sure if they have 1/2" spacers but OME makes what they call a trimmer pack and I believe its on toytecs website but I know people that have added the top plate spacers and just installed that trimmer pack to help with the Taco lean. To be honest with you the Taco lean doesnt even bother me. :cool:
  19. Apr 1, 2013 at 12:38 PM
    #39
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    5mm trim packer only works with OME shocks
  20. Apr 1, 2013 at 12:39 PM
    #40
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ohhh I totally forgot about that! Good looking out!
