OME 885 and lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk3, Jan 24, 2011.
  1. Jan 24, 2011 at 4:14 PM
    luk3
    luk3 [OP] I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    I am about to buy a lift: 885 OME coilovers with the top plate spacer, the 1.5 inch AAL, and the Light Racing UCAs.
    The 885 coils have a note that I should buy new shocks. I have a regular cab with 40,xxx miles on it and dont really want to buy new shocks. Do I have to get shocks. Also will I need to get longer brake lines. Is there anything else I need?
  2. Jan 24, 2011 at 4:17 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    They recommend new shocks for the valving purposes. You don't need new brake lines. :)
  3. Jan 24, 2011 at 4:19 PM
    Gabex35
    Gabex35 Shinty Killer
    Gabe
    San Diego
    2014 4 Runner Trail Premium
    King OEM Performance Series with compression adjusters, Custom rear coils drom CSS, 22% Tint, Method Race NV's 17x8.5, 285/70-17 MTR's, AllPro welded Sliders, Cobra CB, Gobi stealth roof rack, Rigid 40" e series & duallys out back
    I'll jump to conclusions and assume you have the stock shocks.
    You cannot use the stock toyota shocks with the OME springs. You can use either the OME Shocks or the Bilstein 5100's. There may be other shocks you can use, but the previously stated shocks are the only ones i know of.
    I personally have the 5100's (set at zero) with the OME 885's. No problems with them at all...so far
  4. Jan 24, 2011 at 4:20 PM
    luk3
    luke
    Isle of Palms, SC
    stanky taco
    Do you really need it though, what does valving purposes even do?
    edit: I do have stock shocks, i saw the 884 OME coils dont have that side note. Would I need new shocks for the 884 coils with a top plate spacer?
  5. Jan 24, 2011 at 4:21 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
  6. Jan 24, 2011 at 4:23 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    you need a shock that can keep up with (accommodate) the different spring rate...stock won't do it. You need Either the N90000 or the Bilstein 5100s
  7. Jan 24, 2011 at 4:25 PM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    S.D.
    08 DCLB 4X4
    The stock shocks aren't long enough. I had the OME 9000 Nitrocharger shocks and I loved the set up. I got a hell of a deal on some Kings for the rear so I went and got the Kings up front too. For the price and quality OME is phenomenal.
  8. Jan 24, 2011 at 4:27 PM
    luk3
    luke
    Isle of Palms, SC
    stanky taco
    would I need new shocks even with the 884 coils?
  9. Jan 24, 2011 at 4:29 PM
    bnavin
    bnavin Negative Ghostrider
    Ben
    Littleton, Colorado
    OME lift, driveline spacer, iPod interface, rattle canned center console and radio face flat black, LEER topper, Yakima rack, 20% tint all around
    Do it right the first time and get the new shocks. trust me you wont regret it
  10. Jan 24, 2011 at 4:32 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Valving allows the shock to handle the spring weight correctly. Have you ever had a car with a worn out shocks? it bounces like crazy and has terrible road manors.
  11. Feb 13, 2011 at 10:17 PM
    Range 44
    Range 44 Well-Known Member
    Georgia
    2008 FJ TTE
    How much lift do you get with the 885's and the 5100's set at 0?
