OME 885 and OME Shocks to OME 885 and 5100s
Discussion in 'Suspension' started by AllMountainToy, Jul 29, 2013.
  1. Jul 29, 2013 at 2:28 PM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    Has anyone switched from OME 885 with Nitrocharger Sports to OME 885 with 5100s?
    If you have done this, or the reverse, which had the better ride? complete OME setup or OME + Billie?
    Please only reply if you have actually run both of these setups.
    thanks
  2. Jul 29, 2013 at 2:41 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've heard the OME shocks run better then the 5100's but then again the 885's were meant to go with the OME shocks so thats probably why.
  3. Jul 29, 2013 at 9:50 PM
    AllMountainToy
    Northern California
    Bump
    Also the reason I am asking is because I just installed OME 885 with billies set at zero on my buddy's 4th gen 4runner. The ride felt smoother up front but I know it is not apples to apples.
  4. Jul 31, 2013 at 11:26 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Any more info on this?
    I was looking to go with the same 5100/885 setup up front as i already ahve 5100's in the back. How does it ride?
  5. Jul 31, 2013 at 2:35 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I have 5100's up front with 885's and I like the ride. Its a little stiffer then stock but not bad at all. Just make sure to set your shocks at 0" height.
  6. Jul 31, 2013 at 3:30 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I'm not wanting to feel every little bump in the road....I understnad that it's not going to ride like a Cadillac but...I think you get what I'm saying.
    What about the notorious "Taco Lean"...what did you do to remedy that?
  7. Jul 31, 2013 at 3:42 PM
    Texas Taco
    Texas Taco Well-Known Member
    U.S.
    2016 TRD OR DC 4x4 QS
    Icon stage 4 w/RXT leaf pack and shocks, Icon hydraulic bump stops, LT285/75R16 BFG KO2s, 30" Rigid light bar, HIDs, and window tinting. More to come...
  8. Jul 31, 2013 at 3:46 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    No your not going to feel every little bump in the road its not that stiff. I didnt remedy the Taco Lean cause it never bugged me and you can barely notice it.
  9. Aug 1, 2013 at 3:35 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    There's probably a reason why the OME shocks cost almost twice as much. I don't think I would make that swap.
  10. Aug 1, 2013 at 5:35 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I had 5125's and now NitroChargers. I prefer the ride of the NitroChargers.
  11. Aug 1, 2013 at 7:57 AM
    AllMountainToy
    Northern California
    Thanks. This is what I was looking for. Much appreciated
