OME 885 + Bilsteins 0" DCLB Lift and lean?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by daivs, Mar 31, 2015.
  1. Mar 31, 2015 at 6:27 PM
    daivs
    daivs [OP] Active Member
    3" front lift, 2" rear lift, SPidertrax wheel spacers
    Any other DCLB's here running the OME 885 Coil setup with Bilsteins?
    How did you correct the lean while still getting the top plate spacers for the full 3"? Two spacers on one side?
  2. Mar 31, 2015 at 6:34 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    My kit came with an additional spacer specifically for the taco lean. I'm running 884 + 5100s.
  3. Mar 31, 2015 at 6:38 PM
    daivs
    So did you have 3 spacers total to reach that 3" lift? or just had a spacer to correct it?
  4. Mar 31, 2015 at 6:44 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    wut? The bilstein is an adjustable strut, the Coil is.. a coil (a longer than stock one at that) and the spacer is, well a spacer. A total of 1 spacer.
    Many guys here will run:
    Driver side: 5100@.85" + 885
    Passenger side: 5100@0" + 855
    Spacers may push, depending on size, over 3" and you'll be too maxed out for stock UCA's. I ran the setup above and got a little under 2.75-3". Now settled to about 2.5. Spacers would have pushed me over 3"
  5. Mar 31, 2015 at 6:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can get 1/4" spacers
  6. Mar 31, 2015 at 6:57 PM
    daivs
    I was referring to the need for top plate spacers to reach 3" lift but also another spacer to correct the taco lean? So i get a 1/4" spacer for each side to reach the 3", there'll still be a lean right?
  7. Apr 1, 2015 at 6:12 AM
    larrybbaker
    larrybbaker Well-Known Member
    larry
    South Central PA
    2013 MGM DCLB TRD SPORT 4WD
    OME 885 | Bilstein 5100 x 4 | WeatherTech Window Visors | VAIS Tech SiriusXM Adapter |Alpine KTP-445U Amp | Anytime fog light mod
    OME 885 with Bilstein 5100 set at "0" both sides and a 1/4" spacer on driver side. I got almost 3" of lift. This is about a week old so will wait for some settle and re-measure. Happy with look and feel.
    This is a 2013 DCLB TRD Sport.
  8. Apr 1, 2015 at 4:38 PM
    daivs
    So just one spacer is needed? or do you think after settling you'll go below 3" and that's why Toytec recommends top plate spacers to reach 3"?
  9. Apr 1, 2015 at 7:56 PM
    larrybbaker
    larry
    South Central PA
    I bought my parts locally (not a kit) and based on other threads here stayed away from any spacers except the one to correct the lean. Also trying to avoid further expense of UCAs. Everyone's experience seems to vary slightly but I am happy with what I ended up with. Aligned well and no UCAs.
  10. Apr 2, 2015 at 4:52 AM
    larrybbaker
    larry
    South Central PA
    Copied this from another thread - found it useful.
    884 + 5100 (@0) = 2"
    885 + 5100 (@0) = 2.5"
    Eibach + 5100 (@0) = 1.6"
    Eibach + 5100 (@.85) = 2.5"
  11. Apr 2, 2015 at 4:57 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I have one of those spacers if anyone wants it for fweeee
  12. Apr 2, 2015 at 5:02 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    I also have OME 885's on Billies and a 1/4" spacer on the drivers side. There is no lean on mine.
  13. Apr 2, 2015 at 5:02 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Check out my build for measurements. I wouldn't do two spacers. who cares about the lean?
    I have 885's and 1/4" top plates and it got me exactly 3" of lift (billies at 0")
  14. May 21, 2015 at 12:16 PM
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    1/4" top plate spacers on both sides?
  15. May 21, 2015 at 12:30 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    They should have just sold you on the 887 coils to get you to 3" and only one 1/4" spacer for the drivers side lean.
    Now you got 885 coils and two 1/4" spacers which still leaves you that lean. They could have at least recommended longer studs and one 1/2" spacer for the drivers side and one 1/4" spacer for the passenger side if doing 885s, but now you're stuck with stacking spacers on the drivers side and you'll still need longer studs.
    Hopefully you didn't pay for preassembly. To add the new studs they'll have to be taken apart.
  16. May 21, 2015 at 12:48 PM
    teneighty
    Yes
  17. May 21, 2015 at 1:05 PM
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    I'm pretty much set on what my truck needs for a true 3" lift...11 DCSB 4X4. Billies set to 0 with 885xs and 1/4" spacers on both sides. I don't really care about the taco lean-it's completely level when I'm not in it so that's good enough. Planning on doing this in conjunction with LR UCAs prior to installing 33" tires. I want to trim as little as possible, and this setup (I believe) will be my best bet.
  18. May 21, 2015 at 6:41 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    and why is that? replacing a spacer with a preload is the same effect. In the case of my truck, my driver side sagged more than normal. With that setup, for the past two years, I have maintained a level ride at +/- 2.8" lift, the max i would run with my stock UCA's. I don't see an issue.
  19. May 22, 2015 at 5:31 AM
    teneighty
    Sounds good, you'll really like it.
    Trimming will be affected by wheel backspacing and offset too. That plays a major role.
  20. May 22, 2015 at 5:49 PM
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    I read a build with someone using the same fj trail team wheels or whatever they're called and no matter what his setup, those wheel's backspacing required wheel spacers. I'm gonna install the 33"s without them to see what happens..not psyched about potentially having to use them.
