OME 885 coils and front winch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marcoc, Nov 30, 2014.
  1. Nov 30, 2014 at 2:13 PM
    Marcoc
    Marcoc [OP] Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    I am ready to install my Westin Max winch mounting plate (60lbs), TMaxx EW8500 winch with Synthetic rope (60lbs), and bull bar attachment (15lbs) on to my Tacoma and was wondering with a total weight of just under 150lbs can my OME 885 coils handle that "light" addition of front weight without a problem or do I have to go 886 coils? I already installed top plate spacers to get true 3" lift.
  2. Nov 30, 2014 at 2:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    885's are rated for up to 150lbs additional weight up front IIRC
  3. Nov 30, 2014 at 2:30 PM
    OZ-T
    Peter North
    British Columbia
  4. Nov 30, 2014 at 2:40 PM
    Marcoc
    Connecticut
  5. Nov 30, 2014 at 2:41 PM
    OZ-T
    Peter North
    British Columbia
    You will most likely get some compression / sag over time
  6. Nov 30, 2014 at 2:44 PM
    Marcoc
    Connecticut
    Would suck right now to jump to 886 coils after a recent alignment plus extra $$. I wasnt planning on a winch setup but deals were very good and I bit at it lol.
  7. Nov 30, 2014 at 2:45 PM
    Marcoc
    Connecticut
    So may be safe to say to eventually go 886 correct or just play it by time and see how they hold up
  8. Nov 30, 2014 at 3:02 PM
    OZ-T
    Peter North
    British Columbia
    If you don't want to switch now then don't see how it goes and switch later if you feel like you want to
  9. Nov 30, 2014 at 3:06 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    I have a ARB front bumper with a warn xp-s 9500 winch and 886 and they are still stiff . I think 885 would work better .
  10. Nov 30, 2014 at 4:47 PM
    weazel
    weazel Well-Known Member
  11. Nov 30, 2014 at 5:00 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    I have a 4 banger access cab 4x4 with sliders and I 4xinnovations 1/4 inch front skidplate sitting on 885x springs and it settled down to exactly 2 inches of lift if that helps at all.
  12. Nov 30, 2014 at 5:03 PM
    Cjanik
    Cjanik Senior Member
    Chase
    Vegas
    '11 4x4 Off-Road DCSB in MGM
    OME front & rear shocks, OME 886 springs, Dakar rear leaf pack, ICON UCA, Demello front bumper, BFG M/T 255/85r16
    absolutely NOT!!
    I have more weight than that on 886's and its borderline too stiff.
    -edit-
    ive been corrected by OZ-T, 887's actually would be better IF he is looking for that "lift"
  13. Nov 30, 2014 at 5:09 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I built a hidden winch mount this past fall, which weighs about 40lbs over the stock crash bar. I installed my warn M8000 with synthetic line, so it's probably in the same weight range as your Tmax. All this on stock front springs at stock height, and so far, no noticeable difference in ride height. It might feel a bit heavier up front, or it might just be in my head, but it still handles and drives just fine.
    I'd think you'd be fine with your 885's
  14. Nov 30, 2014 at 6:13 PM
    Marcoc
    Connecticut
    Thanks for the guys for the input. I will take a measurement before install and after. I will take another measurement in the spring and see if I lost height. If 885's are starting to sag I will go 886 coils. I think my 885's are going to be good they are still designed to handle extra weight( 110lbs ). I dont want a crazy stiff ride, truck rides perfect with my current setup.
  15. Nov 30, 2014 at 6:19 PM
    bzzr2
    bzzr2 Well-Known Member
    884 885 & 886 all have the same spring rate, they just get a bit taller to accommodate the extra weight. if you find you lose ride height i suggest a top plate spacer as a cost effective way to get back the extra height. this way you have a couple options and can choose the extra height you want knowing exactly what you will get. additionally you will also have more down travel in the coilover by not adding the taller springs to them resulting in a nicer on road ride.
  16. Nov 30, 2014 at 6:26 PM
    OZ-T
    Peter North
    British Columbia
    Not correct
  17. Nov 30, 2014 at 6:42 PM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    884 885 and 887 have the same spring rate and different lengths. 886 have greater stiffness. I think 590 vs 650 lb/in. Numbers may be slightly off but google will tell you. 887 will give a bit of height over the 885 without the added stiffness of 886. I think they are 5 mm taller.
  18. Nov 30, 2014 at 6:48 PM
    OZ-T
    Peter North
    British Columbia
  19. Nov 30, 2014 at 6:54 PM
    jshsltr
    Josh
    St Louis
  20. Nov 30, 2014 at 9:08 PM
    bzzr2
    my mistake, i would imagine the 886 do ride rough without lots of extra load up front.
