ome 885 install
Discussion in 'Suspension' started by chestnut35, Apr 13, 2010.
  1. Apr 13, 2010 at 12:10 AM
    chestnut35
    chestnut35 [OP] Well-Known Member
    tempe
    08 Off Road Double
    bixenon HID, chrome running boards, access tonneau cover, Bilstein 5100, rear TSB leafs, 18x9 XD wheels, 285/60/18 Nitto Terra Grapplers, Front Bull Bar
    Anyone have any good recommendations on where to have my ome 885 and top plate spacer installed at? I just received them and already have my billies on so I'm trying to decide where is a good place to install
  2. Apr 13, 2010 at 5:43 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Are you talking about someone who has a spring compressor or installing the whole lift kit?
  3. Apr 13, 2010 at 5:46 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Do it yourself. Very easy to do.
  4. Apr 13, 2010 at 5:47 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x10000000000000 :)
  5. Apr 13, 2010 at 5:56 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    x10000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  6. Apr 13, 2010 at 10:04 PM
    chestnut35
    tempe
    08 Off Road Double
    that easy huh? ive never used a spring compressor and didnt want to fuck it up or my suspension, thats one thing i didnt want to screw up. I'm good working onthe engine, just never really worked on suspension before
  7. Apr 13, 2010 at 10:07 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    xthat +1
    Just go to kraigns for 30 bucks you can get this on and it took like 30 minuites to get both set
  8. Apr 14, 2010 at 4:28 AM
    rmb_crew
    Its really not that bad and the new spring compressors arent as dangerous as the older ones. Its really not that hard and would probably only take you make 3 hours to do since you have never done it before. And it will save you a good chunk of cash. :)
  9. Apr 14, 2010 at 4:34 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    lol...it's a spring not a complicated piece of machinery.
  10. Apr 14, 2010 at 9:23 AM
    sirsaechao
    Tim
    Commifornia
    Any shop with a spring compressor can do it. Just check around. Shouldn't run you that much. Then do the install yourself.
