OME 885 lift
Discussion in 'Suspension' started by Taco Guy11, Jan 27, 2012.
  1. Jan 27, 2012 at 6:25 PM
    Taco Guy11
    Taco Guy11 [OP] Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    Questions if i get the OME kit from toytec is there anything else i will need. I think it comes with struts springs diff drop rear shocks and aal. Do i need anything else also if i run 265's can i run factory wheels or do i need back spacers? how much back spacing is needed? I think i may get LR UCA any input on them or sugguestions i live in a place that the salt in the winter can be rough i was afraid this would harm a uniball like a tc uca's. Thanks for any help.
  2. Jan 27, 2012 at 6:28 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    LR UCA's would be my choice.... No new wheels are needed if you plan on running 265s you'd be fine with the OEM wheels. IF you do plan on going up to 285s, you will need new wheels with a 4.5 BS, or wheel spacers if you decide to run the stock wheels instead of buying a whole new set of wheels.
  3. Jan 27, 2012 at 6:30 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    With the 885's you should be fine with stock uca's. Your alignment won't be perfect but it'll be good enough. Like you said, you could always go aftermarket if you aren't happy. I got the complete kit from them minus the diff drop and it has everything needed to lift it. Most people advise against the diff drops arguing they do more harm than good. I agree with them and also with the 885's you shouldn't have enough lift to need it anyways. You don't need spacers for your wheels unless you go with 285's and don't run an aftermarket uca but with 265's you'll be fine, that's what the off roads come with.
    The kit comes with everything but you still need a spring compressor to disassemble the stock struts and assemble the new ones. Also other basic tools are need obviously. Also, the stock u-bolts will work with the aal just make sure you have about the same amount of threads sticking out on both sides of the ubolt of course.
    Best of luck with your lift. If you have any other questions including install feel free to ask. I couldn't be happier with my OME lift and highly recommend it.
  4. Jan 27, 2012 at 6:34 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    I'm running 885s and I need new UCAs. Everyone is diff tho. Best of luck with your lift.
  5. Jan 27, 2012 at 6:36 PM
    Jason'sLawnCare
    Are you running 885's and 5100's set at 1.75"?
  6. Jan 27, 2012 at 6:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get the LR UCA's .
    FWIW , I'm very happy with my OME 885 set up with the LR UCA's .
    I got 2 1/2" up front with the 885's , no spacer , on my DCLB 4x4
  7. Jan 27, 2012 at 6:39 PM
    Blackshirts
    TX
    Stuff
    Heck no I have not change my profile.
    I did know someone who set there 5100s to 2.75 and ran 885 and yea he blew a shock. LOL
    I got my 885s set to .85 but I'm going to order the top plate spacer. And change it up here soon.
  8. Jan 27, 2012 at 10:37 PM
    Taco Guy11
    Joe
    Western Maryland
    I plan on getting the 885 with the one shocks and I kinda want my alignment right on so I thought LR UCAs but with them can I run stock wheels with 265's and aftermarket with 4.9bs with 265's
  9. Jan 28, 2012 at 4:42 AM
    Blackshirts
    TX
    Stuff
    Yes you should be fine.
  10. Jan 28, 2012 at 4:59 AM
    Taco Guy11
    Joe
    Western Maryland
    So do I need diff drop? Axel shims? Sway bar relocation brackets? Carrier bearing drop? Hum am I missing anything else. Thanks
  11. Jan 28, 2012 at 5:37 PM
    Jason'sLawnCare
    You shouldn't need any of that. If you run into vibes in there rear you would start with the carrier bearing drop but with an aal most don't have the vibes.
  12. Jan 31, 2012 at 3:27 PM
    MaloneS
    MaloneS Well-Known Member
    Steven
    The Woodlands, TX
    Sold, but going to by another
    I bought the diff. drop; lots of mixed opinions on it. But I know a tacoma owner (4 of them) that has had a lift on every truck and says that the cv axle boots wear much faster with a lift. He highly recommends doing the diff drop unless you have lots of cash o la!!!
  13. Oct 16, 2012 at 6:45 PM
    XREILLYX
    XREILLYX Well-Known Member
    Reilly
    okanogan
    07 white double cab
    blacked out taillights, White OME 885X's, Billy 5100's around, added 120v/aux charger, Browning sticker!
    did u end up putting in the diff drop?
  14. Oct 17, 2012 at 12:46 PM
    HERMS671
    HERMS671 Hey there! I'm using Tacoma World
    Guam, USA
    2008 Tacoma DCLB TRD Sport 4x4
    BHLM and HID Retrofit/Upgraded Sound System
    Don't mean to thread jack but does anybody know if any parts from the stock front suspension have to be re-used in order to assemble the OME shocks and 885 coils? I'm debating if it's worth it to spend the extra money to have the shocks and coils pre assembled or do it myself. Has anybody assembled it themselves? If so, how easy was it? Any stickies on it? Thanks TW.
  15. Oct 18, 2012 at 2:05 PM
    HERMS671
    Guam, USA
    Anybody? Did you guys re-use the old top plate or did you purchase new ones?
  16. Oct 18, 2012 at 2:11 PM
    krimson
    krimson Nothin
    TRD Off Road
    Re-use the top hat for the struts. I reused mine that came on my OEM struts. I brought my OEM struts and the OME struts to a shop.
  17. Oct 18, 2012 at 2:22 PM
    HERMS671
    Guam, USA
    Thanks!
  18. Oct 22, 2012 at 2:53 AM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    im running 885x's on bilstein 5100s. i used the stock top hat. pretty simply to do it yourself..just need a good spring compressor.
    currently running stock uca, but might upgrade later in future.
