OME 885/Nitrocharger Feedback - mine is harsh!
Discussion in 'Suspension' started by Beast Mode, Oct 4, 2012.
  1. Oct 4, 2012 at 11:03 AM
    Beast Mode
    Beast Mode [OP] Well-Known Member
    PDX
    12 DCSB Sport 4x4
    RCD lift, Pro Comp, 285/70/17 Destination AT, LR UCA, magnaflow muffler, LEER 180, Flyzeye, Clazzio covers, N-Fab steps
    about a month ago I installed OME 885x springs accompanied by the OME nitrocharger shocks. I have the topout spacer as well. As of today my front end is harsh! going over most ruts, bumps, cracks in the road is felt substantially thru the truck. As if there is zero travel in the front.
    I'd like to hear from others who have this setup on what their experience is. As I log in more time will they soften up? I definitely dig the stance, but the ride quality has suffered signficantly. THis is my 3rd Tacoma that I've lifted and by far the most jolting.
  2. Oct 4, 2012 at 11:13 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Should soften up over time. Try to lower your tire pressure some as it helped with my ride. I had the 885x's for a few months and loved the ride...i now have the 886's and the ride is just as comfortable as the 885s with the right tire pressure.
  3. Oct 4, 2012 at 11:14 AM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    i have the 885x's but with billies instead of the OME shocks and my ride is nice and smoooooooth
  4. Oct 4, 2012 at 11:18 AM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    was it smooth from the start?
  5. Oct 4, 2012 at 11:19 AM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    I'll lower the tire pressure a bit and see if that helps. By the sounds of it the nitrochargers might be the culprit. They feel great in the back, not so much in the front.
  6. Oct 4, 2012 at 11:21 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    I've had the nitro chargers the whole time and love them. They are valved to go with the OME springs.
  7. Oct 4, 2012 at 11:33 AM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    Thanks Sje1124, I guess my plan at this point is to trust that they'll soften up as time goes on.
  8. Oct 4, 2012 at 11:37 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    I have the 885s & Nitros on my 4Banger without the spacer and they ride great.
  9. Oct 4, 2012 at 12:08 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I have the 885X / 90000 Nitrocharger combo set up , the ride is definitely stiffer than stock , but I think that a lot of my ride stiffness is due to my E rated tires
  10. Oct 4, 2012 at 2:15 PM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    Thanks OZ, I expected a stiffer set up when I upgraded; I'm rolling with some p-rated tires and it just seems stiffer then it should be. Do you get jolted when you hit any sort of bumps at speed or potholes? I keep hearing people describe their setups "like butter" and "smooth" and I'm nowhere near describing my setup like that. Honestly, my rear is twice as smooth with the Toytec 1.5 TSB AAL than my front end.
  11. Oct 4, 2012 at 2:29 PM
    wrxRome
    Brandon
    Yeah but I got it used with about 8k miles on them
  12. Oct 4, 2012 at 3:32 PM
    OZ-T
    Peter North
    British Columbia
    I don't buy the " like butter " comments , you can't help but stiffen up the front by adding the 885 / Nitros
  13. Oct 4, 2012 at 8:15 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    This ^
  14. Oct 4, 2012 at 10:49 PM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    Yeah no doubt no ones ride is like butter. I've never bought that either.
  15. Oct 5, 2012 at 9:08 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    They will soften up as time goes on for sure. The suggestion of running a lower tire presssure is good. What psi do you typically run? I know my truck is a 1st gen but with the OME 882s and Nitrochargers it was firm at first too. I typically run my tires at 25-28psi on the road. Offroad they are at 12-18psi depending on the terrain.
    When I first installed my suspension it felt more stiff than I expected but as soon as I got out in the dirt I loved it. It felt very controlled in the dirt which was the main priority.
  16. Oct 5, 2012 at 10:07 AM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    Thanks for sharing your experience. It's what I wanted to hear. I'll quit whining about it and give it some more miles. Hopefully I'll experience a more buttery ride. :D
  17. Oct 5, 2012 at 10:17 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I have the ome 885s and nitros and still think they are stiff. I have had them for about 50k miles and it has softened up but then I put on e rated tires which didn't help. But like box rocket said on gravel and off road the truck feels very in control. Over big rocks I still get bumped around but that's expected.
  18. Oct 5, 2012 at 10:24 AM
    Large
    Large Red
    Tried removing the spacers? It will probably help
  19. Oct 5, 2012 at 10:26 AM
    OZ-T
    Peter North
    British Columbia
    I don't have spacers
    yet
  20. Oct 5, 2012 at 11:47 AM
    Beast Mode
    PDX
    12 DCSB Sport 4x4
    Not yet, I do love the height that the spacer provides. I thought I researched folks who had the spacer and later removed it noticed no difference. I bet there is a difference but may be nominal. At this point I'm just going to rally for 5k more miles and reassess. I'm having the wheelers progressive pack installed this weekend in the rear so ill see if I have any offsetting effects with the ride quality.
    Thanks everyone for your comments.
