OME 885 Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoGuy9065, Mar 23, 2014.
  1. Mar 23, 2014 at 7:52 PM
    TacoGuy9065
    TacoGuy9065 [OP] Member
    North Carolina
    07 4x4 SR5 Double Cab
    Black Wheels, Halo Leds, Kc Off-Road lights, Bull Bar
    Im just curious here but if I am only looking for like 1.75 inches of lift could i simply just switch out the stock springs? I already know about bilsteins so dont worry. Im just curious here. I have no clue by any means. Im sold on the bilsteins, which is all I have the coin for right now, but theoretically could you just switch the springs?
    Cheers Guys
  2. Mar 23, 2014 at 7:58 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Yes you can just switch the springs. Eibachs will give you about 1.6" with their springs 885 will give you close to 2.6-3" or just the billies and set them where you want too at .85 1.75 or 2.5
  3. Mar 24, 2014 at 9:32 AM
    TacoGuy9065
    North Carolina
    Is that even on just stock shocks? Im just trying to think of the smartest option for me to go since both bilsteins and the springs from wheelers are all around the same price. And if it was the stock shocks, would it do any damage to them having a larger spring with a larger rate on them? And do you think it would change the geometry of the lower suspension? Like Im thinking with a spring wont the preload just push the truck up therefore, not changing the lower suspension? Thanks! Im just trying to wrap my head around this.
  4. Mar 24, 2014 at 9:37 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    It's best to replace the shock. The 5100 is a slightly longer shock than factory, and it's designed specifically for lifting.
  5. Mar 24, 2014 at 11:04 AM
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    I went with 884's and 5100's (at lowest setting) and got about a 2" lift.
  6. Mar 24, 2014 at 11:10 AM
    aubi1414
    Justin
    Pensacola, FL
    As stated above people have done the springs with stock but isnt recommended. Just do the bilsteins and be done and set them at 1.75"
  7. Mar 24, 2014 at 12:15 PM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    I did 5100 at 0 with 885. not sure how much lift I actually got but its damn stiff compaired to stock, Wished I went with the 884 and .85. or the eibach springs at .85
  8. Mar 24, 2014 at 6:24 PM
    TacoGuy9065
    North Carolina
    Thanks for the help guys! Im going with the 5100's. I was just wondering what would happen with the others.
