OME 885 Shock - Is this Bad
Discussion in 'Suspension' started by poorkid99, May 3, 2013.
  1. May 3, 2013 at 2:29 PM
    poorkid99
    poorkid99 [OP] Well-Known Member
    So, I was driving down a washboard road the other day and noticed a strange noise coming from my front end, it just looks like my shock completey failed, is Old Man Emu good with replacement? what is the warranty with these?
    Is this ok to drive on until i can get a replacement?
  2. May 3, 2013 at 2:34 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    not really safe to drive, hit a pothole and you could drive the shock top up and cause some damage...
    probably safe to wheel around the driveway to get into position to fix...
    it is either the shock or the lock ring in the top groove that failed....either way, it 's got to come out to fix...
  3. May 3, 2013 at 2:37 PM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    ^^ what he said. only safe at very slow speeds to prevent further damage.
  4. May 3, 2013 at 2:39 PM
    poorkid99
    figured as much. thanks guys.
  5. May 3, 2013 at 2:47 PM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Looks like the top of the shock body itself blew out, I wouldn't drive it
  6. May 3, 2013 at 2:49 PM
    poorkid99
    filling out an ARB claims form as we speak.
  7. May 3, 2013 at 3:36 PM
    mjm540ii
    Oxford, PA
    :p
    ARB?
  8. May 3, 2013 at 4:49 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ARB makes OME
  9. May 3, 2013 at 6:40 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    It looks to me like the coil over was not assembled correctly.
    How long have you had these on your truck?
    If the washers and bushings are not installed in the correct order and facing the right direction this will occur. I've seen it before.
  10. May 3, 2013 at 8:31 PM
    poorkid99
    4k miles
    It was professionally installed. However the rep at arb says the same thing. Time to get the shops story.
  11. May 3, 2013 at 8:32 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Well shit man, Good luck at getting it all fixed up, Sorry to see. Definitely not ARB at fault but most likely a shop error.
