OME 885 terrible off road ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TREED, Aug 26, 2015.
  1. Nov 20, 2015 at 8:20 AM
    #181
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    What do you mean when you say the ome shock locks the LCA to the frame?
  2. Nov 20, 2015 at 8:26 AM
    #182
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The OME shock is too short, it does not allow enough travel. It is also valved too light. So when the truck operator goes over an obstacle such as a speed bump or a rock, the shock will extend on the backside of the obstacle and when it's fully extended it hits an internal stop. The internal stop is a weld on the shaft. It's a fucking harsh experience for the truck operator and all the passengers. It shakes the shit outta the truck. It makes people thing something is wrong with their install.
    The shock is improperly designed IMO. I considered hiring an attorney to get my money back.
    Therefore when I say, the OME shock functions like a chain shackle, it does, it limits suspension travel in the harshest way.
    It is difficult to articulate with words the difference between the 5100 and the OME shock. But my experience was like night and day.
  3. Nov 20, 2015 at 8:29 AM
    #183
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I think part of the problem is the OME 885's are intended to have 100lbs of weight on them to provide 2" of lift and nobody runs weight and everybody tries to get the magical 3"
    YotaDan, Large and rhion82 like this.
  4. Nov 20, 2015 at 8:32 AM
    #184
    Crom
    Nick
    San Diego, CA
    Millions
    That's been discussed before. But even in this thread there are comments about the harshness with armor:
    Also I noted something different between the two shocks. When I had the 5100 out, I manually compressed it. It fully expanded in about 5 seconds, what I would consider normal. I performed this same test with the nitrocharger and it took something like 20 seconds to fully expand, maybe longer. Not sure if it's a defect or what, but both nitrochargers did this. Not sure why. Even so, that's a separate issue, and unrelated to the too-short length.
    Why did OME valve the shock that way?
  5. Nov 20, 2015 at 8:36 AM
    #185
    OZ-T
    Peter North
    British Columbia
    That poster has 886's
  6. Nov 20, 2015 at 8:40 AM
    #186
    Crom
    Nick
    San Diego, CA
    Millions
    Yup. 886 are stiffer spring rate. But really, it's not the spring, its the shock. If that poster swapped shocks, he would have a totally different experience.
  7. Nov 20, 2015 at 8:43 AM
    #187
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    You are using a guy that runs 886 without armor as supporting material for your argument. The 886s are made for people who have a lot of armor. I have the 886s with a bumper and full skids and it drives just fine.
    Yeah he could also change springs and it would be a totally different experience as well.
  8. Nov 20, 2015 at 8:46 AM
    #188
    OZ-T
    Peter North
    British Columbia
    I don't necessarily disagree but my point was that if you look at the OME application guide it states the 885 coil is intended to provide 2" of lift with approx 100 lbs front weight . If you compressed the coil with 100lbs I'm suggesting it would be less likely to suffer from the quick top out effect on the back side of sharp bumps
  9. Nov 20, 2015 at 8:46 AM
    #189
    Crom
    Nick
    San Diego, CA
    Millions
    If it works for you, then that's wonderful. For some of us, we have had a terrible experience with the product.
  10. Nov 20, 2015 at 8:52 AM
    #190
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    It's threads like this that made me nut up and decide to spend the extra money and order icons
    ChadsPride and rhion82 like this.
  11. Nov 20, 2015 at 8:58 AM
    #191
    Crom
    Nick
    San Diego, CA
    Millions
    What I want is an expert who understands shock valving to explain to me why when I manually compress the OME shock it takes 20 or more seconds to expand?
    To your point about extra weidht, my truck met that requirement, 80 lb of sliders, and 50 lb of roof rack. Hell it could be OME is putting out defective shocks!
    ChadsPride likes this.
  12. Nov 20, 2015 at 9:08 AM
    #192
    OZ-T
    Peter North
    British Columbia
    Roof rack weight and about 1/2 the slider weight would be carried by the rear suspension
  13. Nov 20, 2015 at 9:09 AM
    #193
    Crom
    Nick
    San Diego, CA
    Millions
    I get what your saying OZ... But I can't ignore the difference when I changed shocks. Night and day experience man.
  14. Nov 20, 2015 at 9:11 AM
    #194
    Tacoma SS
    Denver
    I have heard so many people complain about the same issue that I think may be oh OME should put a warning on their website saying that "these shocks are not intended for off-road use" or something like that... You would think that since OME is more expensive then Billy's that they would be better quality. But that does not seem to be the case
  15. Nov 20, 2015 at 9:16 AM
    #195
    OZ-T
    Peter North
    British Columbia
    not doubting you , and it makes sense with the greater travel length of the 5100 , nor am I a staunch "OME is the best ever " fanboy , just saying I think a lot of the reason for Over Speed Bump Goes Clank is that the 885's are intended to provide 2" of lift with about 100lbs of front weight and almost no one on this site runs them like that , myself included
  16. Nov 20, 2015 at 9:18 AM
    #196
    OZ-T
    Peter North
    British Columbia
    You mean for all those speed bumps you hit offroad ?
  17. Nov 20, 2015 at 9:20 AM
    #197
    Tacoma SS
    Denver
    Do they not suck off-road? Only over speedbumps?
  18. Nov 20, 2015 at 9:24 AM
    #198
    OZ-T
    Peter North
    British Columbia
    Generally the OSBGC happens on the backside of a sharp drop
  19. Nov 20, 2015 at 9:25 AM
    #199
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Icons aren't all that great either, nut up even more and go with ADS or Kings
  20. Nov 20, 2015 at 9:27 AM
    #200
    Tacoma SS
    Denver
    Aren't you riding on OMEs? You wouldn't rather have icons?
