OME 885 terrible off road ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TREED, Aug 26, 2015.
  1. Aug 26, 2015 at 5:49 PM
    #41
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    ^^this.
    I have Eibach coils (stiffer than OME) and 5100's my truck glides smoothly over speed bumps at 15 mph.That 1"+ of extension is the difference.
    Crom likes this.
  2. Aug 26, 2015 at 5:52 PM
    #42
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    IMO, the shock could brake the internal weld which functions as a stop, in which case the shock could extend too far and blow a seal. If that happens, shock will leak oil and then you call ARB for warranty replacement.
  3. Aug 26, 2015 at 5:54 PM
    #43
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Is your top hat new?
  4. Aug 26, 2015 at 5:54 PM
    #44
    Crom
    Nick
    San Diego, CA
    Millions
    Good to know. Just so I have a frame of reference, how much lift over stock did your eibachs provide?
    Model number would be good, I can look up specs... Thx
  5. Aug 26, 2015 at 5:56 PM
    #45
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    About 1.75".
  6. Aug 26, 2015 at 5:59 PM
    #46
    Crom
    Nick
    San Diego, CA
    Millions
    Dunno who your speaking to, but mine was all new hardware, so yes on my truck.
  7. Aug 26, 2015 at 6:02 PM
    #47
    Red Baron
    Aaron
    07 Radiant Red DCSB
    Sorry meant for OP
  8. Aug 26, 2015 at 6:10 PM
    #48
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    FWIW, I had my frame replaced a while back due to rust. Along with the frame, they also replaced a lot of suspension parts up front, ie. Lower control arms, lower ball joints, etc. My truck was lifted prior to the replacement with 885x coils and nitrocharger shocks. Before the frame replacement, my truck rode like crap, and made the same loud clunks as OP describes. After i got it back, everything feels so much tighter, and the clunks over bumps are gone. My aftermarket suspension was put back on the same as it came off. I agree with most posts in this thread about OME being stiff and riding rough, but I think new LCAs and LBJs made a huge difference. 140k miles on the truck.
  9. Aug 26, 2015 at 6:31 PM
    #49
    TREED
    TREED [OP] Well-Known Member
    JT
    Spring Creek NV
    15 trd taco dc
    885x coils on 5100s. SPC upper a-arms 255/85/16 bighorns, 12k lb reciever mount rear winch,CBI offroad moab bumper,8k lb warn front winch, swaybar delete, spidertrax,icon minipacks, custom dog box, husky liners
    With 7200 miles on the truck I sure hope the only wear is on the tires
  10. Aug 26, 2015 at 6:41 PM
    #50
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I agree
  11. Aug 26, 2015 at 8:55 PM
    #51
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    This is bizarre. I just did the OME 887 coils up front with OME shocks. I go over a speed bump at work twice a day. The only thing I hear is a squeaking that started after I went up a forest service road a couple hundred miles ago. But I hear that over any bump.
    And honestly I don't think it feels all that rough going over speed bumps either... Whether I creep or do 15mph it feels fine to me.
    Red Baron likes this.
  12. Aug 26, 2015 at 8:58 PM
    #52
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Do you have any additional weight up front?
  13. Aug 26, 2015 at 9:01 PM
    #53
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Not yet. Unless you count my subwoofer box behind the rear seat. And the dealer set my tire pressure at like 36psi. So in theory I should be as rough as it gets.
    Have skids on order but obviously not on the truck yet.
  14. Aug 26, 2015 at 9:02 PM
    #54
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its simply the shocks topping out hard, or the UCA / swaybar hitting the coils. Droop the suspension out with a floor jack and see if anything is hitting.
    I know my 5100's n stock coils at 1.75 top out relatively hard, but its in part to the UCA hitting coils. (swaybar is long gone)
    If i am not mistaken (and correct me if i am wrong) the OME stuff is a gas emulshion type of shock.... no separate floating piston to separate oil n gas.
    5100's do have separate chambers with a floating piston. This allows better oil control and depending on how the shock is made you can make sections with more or less dampening rather easy.
  15. Aug 26, 2015 at 9:27 PM
    #55
    Mach4x4
    Mach4x4 Active Member
    James
    Kirkland, Washington
    2015 Tacoma TRD Sport DCLB Bilstein 6112's BFG KO2's
    I was planning on doing an OME lift next month, but now I may get Fox or Icon instead...
    Arailt likes this.
  16. Aug 26, 2015 at 9:33 PM
    #56
    TREED
    JT
    Spring Creek NV
    15 trd taco dc
    It barely has any droop and nothing is hitting, acts like the shocks are too short.
  17. Aug 26, 2015 at 9:34 PM
    #57
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Do you have the sport shocks?
  18. Aug 26, 2015 at 9:42 PM
    #58
    TREED
    JT
    Spring Creek NV
    15 trd taco dc
    sport i believe
  19. Aug 26, 2015 at 9:48 PM
    #59
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Just got my OME kit in the mail the other day, kinda wish I knew about this a few weeks ago. I'm gonna install it anyway. Definitely can't be as bad as my stock suspension with the spacer and rear block...
  20. Aug 26, 2015 at 9:53 PM
    #60
    OZ-T
    Peter North
    British Columbia
    You said 885's , trim packer and 1/2" spacers in the OP , are you over 3" of lift ?
