OME 885 terrible off road ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TREED, Aug 26, 2015.
  1. Aug 27, 2015 at 4:27 PM
    #101
    T4RFTMFW
    T4RFTMFW Well-Known Member
    ACs can't flex. The chains of poverty cab are far too strong.
    Czeleznick and Red Baron like this.
  2. Aug 27, 2015 at 4:48 PM
    #102
    xsteinbachx
    xsteinbachx Well-Known Member
    Victoria, BC
    2017 White TRD Sport DCLB 4x4
    OZ-T what suspension are you running?
  3. Aug 27, 2015 at 4:49 PM
    #103
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    #NoKids
    #SucksToBeOld
    Rock Lobster and Red Baron like this.
  4. Aug 27, 2015 at 4:55 PM
    #104
    Justinlhc
    Justinlhc Not looking for a relationship
    Lookie here you lil whippersnapper! :brianr:
    dakotasyota[QUOTED] likes this.
  5. Aug 27, 2015 at 4:56 PM
    #105
    T4RFTMFW
    Sick 'em, fellow geezers!
    dakotasyota likes this.
  6. Aug 27, 2015 at 5:01 PM
    #106
    dakotasyota
    Dakota
    Ellensburg, WA
  7. Aug 27, 2015 at 5:12 PM
    #107
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Haha!!! Wait! I'm a geezer?! Fuck!!!
  8. Aug 27, 2015 at 5:14 PM
    #108
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    895's and Dakars with OME shocks front and rear
    xsteinbachx[QUOTED] likes this.
  9. Aug 27, 2015 at 5:39 PM
    #109
    TREED
    TREED [OP] Well-Known Member
    JT
    Spring Creek NV
    15 trd taco dc
    885x coils on 5100s. SPC upper a-arms 255/85/16 bighorns, 12k lb reciever mount rear winch,CBI offroad moab bumper,8k lb warn front winch, swaybar delete, spidertrax,icon minipacks, custom dog box, husky liners
    The suggestion is to run a mid travel set up, Icon, fox, or king in the 2.5 series. With a mini pack out back and rebuild able rear shocks. I need to make some decisions.
    bzzr2 likes this.
  10. Aug 27, 2015 at 9:14 PM
    #110
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    05/ 07,09/11Tacoma access cab 4x4
    I would never recommend OME For an IFS truck, they ride too high on droop and you can't dial in the correct ride height ( compression to droop ratio). The shocks rebound valving is weak and causes the spring to unload very quickly hitting the internal metal stop causing a banging noise... When going over big bumps. I've seen OME shocks fail because the internal metal stop fails causing the rod to get loose. The suspension then over droops causing the UCA to hit the spring. When the shock is removed from the spring,the shaft can be pulled out of the body.
    Nothing beats a high quality coilover shock..you will be smiling on every off road trip.
    03f5sp, Crom and BenTheMan like this.
  11. Aug 27, 2015 at 9:18 PM
    #111
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    @Rock Lobster
    Pigpen likes this.
  12. Aug 27, 2015 at 9:36 PM
    #112
    SlapChop7
    SlapChop7 Well-Known Member
    Eastern NC
    2019 MGM DCSB OR 4x4
    I just bought an OME setup last week after owning Kings on my Tundra. Thought about going Kings again for my Tacoma but decided to take the cheaper route for now and upgrade later on.... It was hard decision and I thought I was ok with it... Then I read your post and remember all the times I was cheesin ear to ear in my tundra running through the desert. Thank you for making me regret it. :smash:
  13. Aug 27, 2015 at 9:46 PM
    #113
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Mmm kings.... Mmm flex... Mmmmmmm :drool:
  14. Aug 27, 2015 at 9:52 PM
    #114
    SlapChop7
    Eastern NC
    Thanks. :crapstorm: Anyone want a brand new set of OMEs? I guess its not too late...
  15. Aug 27, 2015 at 9:54 PM
    #115
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Try the OME thread? :notsure:
  16. Aug 27, 2015 at 9:55 PM
    #116
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Have you driven the truck actually off road yet? Speed bumps are not any kind of accurate simulation of any type of actual off roading. As you've noticed, they serve mainly to test/illustrate limited downtravel.
    No off-road suspension that I know of handles speed bumps better than stock. What you really want for speed bumps is a really low spring rate and downtravel equal to uptravel. That's what stock does.
    Also, if you're solving for the best ride, you'll adjust your adjustable-coilover suspension to have more down travel. That equates to less lift. If you get an extended-travel kit with upper control arms that allow extended droop, you can have both - but at greater cost and likely only after removing the sway bar which I believe you've retained until now. And to do that in the back, you'll need a frame cage or something like BAMF's shock buckets.
    The OME equivalent trading less height for more downtravel is to use 884 springs instead of 885 springs. That's a much less expensive option than junking everything you've got and upgrading.
    But the main thing you're learning here - and I hope others who read this post get it - is that there is no BEST suspension.
    Once you vary from stock, it's all optimizing FOR some things and AWAY from others. Different users will end up with different optimal configurations. But once you get away from stock - you're signing up to tune your truck using what may be an iterative and experimental process.
    You don't get to simply check the box that says "upgrade suspension to 'best'" and be done. There is no "best" and folks who tell new members "Oooooh, upgrade to Long Travel - it's the BEST" or "Yeah baby - swap to Solid Front Axle - that's the best thing" are doing folks a great disservice. Those choices are a very high cost, very high labor, very-high-risk-of-adverse-side-effects tradeoff in favor of a specific optimal off-road performance. And that is obtained only after a long period of dialing in and tuning.
    Sorry Old Man Emu doesn't seem to be working out for you. Welcome to the world of unintended consequences and trying multiple times until you get it right.
    landphil, gunn_runner, JDM and 13 others like this.
  17. Aug 27, 2015 at 9:55 PM
    #117
    SlapChop7
    Eastern NC
    Nah, I think I'm gonna give em a shot and see how I like em. I'll eventually get Kings again. One day.
    Crom likes this.
  18. Aug 27, 2015 at 10:17 PM
    #118
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Man you have to do the squeaky Dakar fix. works like a charm.
  19. Aug 27, 2015 at 11:04 PM
    #119
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Red Baron likes this.
  20. Aug 28, 2015 at 4:18 AM
    #120
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    I'm gonna have to look that up!
