OME 885 terrible off road ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TREED, Aug 26, 2015.
  1. Aug 28, 2015 at 8:33 AM
    #121
    TREED
    TREED [OP] Well-Known Member
    JT
    Spring Creek NV
    15 trd taco dc
    885x coils on 5100s. SPC upper a-arms 255/85/16 bighorns, 12k lb reciever mount rear winch,CBI offroad moab bumper,8k lb warn front winch, swaybar delete, spidertrax,icon minipacks, custom dog box, husky liners
    Yes, I took my truck bear hunting in Tonto national forest. The ome stuff is good if you drive 3mph but I walk at 4mph. The rear actually does ok and flexes really well. The front has no down travel and very little up travel due to a very stiff coil driving the strut down to full extension, A multi rate front coil would make a huge difference in ride. The front ome is coming off and I am going with extended travel Icon 2.5 ifp.
  2. Aug 28, 2015 at 8:42 AM
    #122
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Sounds like you know what you want to try next then.
    My practical tuning advice, whether using the OME coils or the Icon coils is this:
    1. Talk to a knowledgable vendor when ordering the Icons. Make sure they know how you want to use your truck and your complaints about the existing setup. That'll help them select the right shock valving for you. Be aware that the spring rates on the Icons are actually stiffer (at 650lbs/inch than the OME coils at 585lbs/inch)
    2. Once you're using an adjustable coilover, set the height lower to allow more downtravel.
    3. Lose the top plate spacer. That's solving for height, and you're definitely solving for ride, speed, and comfort.
    4. Figure out what's actually limiting your down travel. Is it the shock bottoming out? Or is the swaybar hitting the coil? Or is the upper control arm hitting the coil? Or is the balljoint on the upper control arm topping out?
    DoorDing, Kyitty and OZ-T like this.
  3. Aug 28, 2015 at 8:46 AM
    #123
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also, you *are* airing down when off-roading right? Airing down is the single biggest thing you can do to any truck to improve off road performance. With your 255/85R16 size, you ought to be able to go somewhere lower than 20lbs psi.
    Pigpen and DoorDing like this.
  4. Aug 28, 2015 at 8:57 AM
    #124
    TREED
    JT
    Spring Creek NV
    15 trd taco dc
    Actually you would think dropping to an 884 coil and then adding the 1/2 inch spacer on top of the strut assembly would give more downward travel of the strut but still maintain ride height. Maybe I can get a picture of how much droop it has in the front, I can stuff the rear tires into the bed.
  5. Aug 28, 2015 at 9:37 AM
    #125
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I too will do the same, but not sure when I'll have the $$$ to do so.
  6. Aug 28, 2015 at 9:37 AM
    #126
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not sure why you guys running E rated tires on a Tacoma are surprised your ride sucks if you aren't aired down.
    Good luck with the Kings.
    Justinlhc and Kyitty like this.
  7. Aug 28, 2015 at 9:40 AM
    #127
    TREED
    JT
    Spring Creek NV
    15 trd taco dc
    Just went out and took some measurements
    ground to fender flare pass loaded 38-1/4
    ground to fender flare driver loaded 38
    unloaded pass ground to fender flare 41-1/8
    unloaded driver 40-3/4
    sag from top of tire to fender flare pass 8-3/4
    sag from top of tire to fender flare driver 8.5
    loaded top of tire to fender flare pass 6-7/8
    loaded top of tire to fender flare driver 6-5/8
    Measurements were measured with 35psi in tires but my garage floor is not exactly level, This explains that it over extends the strut because it only has around 2 inches of travel in the extension end and the poor front articulation. Also at full sag no binding whatsoever and ball joint angles appear to be fine.
  8. Aug 28, 2015 at 9:47 AM
    #128
    TREED
    JT
    Spring Creek NV
    15 trd taco dc
    Pic of unloaded upper ball joint angle
    Stanky taco likes this.
  9. Aug 28, 2015 at 9:53 AM
    #129
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Late to the party here, but I have 5100s and OME 887 coils, and do experience hard top outs. Its a characteristic of both 5100s and Nitrochargers. The reason this happens with these shocks vs. high-end coilovers is because they have an part integrated into them called a "top out bumper." Bilsteins and Nitrochargers don't have these things, they have welds, pieces of metal, etc that is what stops them from extending any more.
    Also, the shocks aren't valved properly on the rebound side, which allows them to rebound way too damn fast for any application.
    Take a look at part number 9 in this diagram linked below. Though it says 2.0 IFP, the web address says truck 2.5, and was linked into their web-page for Tacoma coil-overs. (Just for authenticity.:D)
    http://www.ridefox.com/dl/truck/FOX_TRUCK_2.5IFP_Exploded_A.pdf
    Crom likes this.
  10. Aug 28, 2015 at 9:54 AM
    #130
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Vs an 885 spring only? Yes, I agree.
    If you off-road your truck hard and you use a 1/2" top plate spacer, I do recommend you space out your bumpstops a bit with some thick washers or a 3/8" aluminum billet spacer, so that the bumpstops, rather than the shock, take the transmitted load from the wheel to the frame on a hard hit.
  11. Aug 28, 2015 at 10:28 AM
    #131
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    This thread is making me reconsider ordering OME and saving up for some Fox/Icon/Kings:frusty:
  12. Aug 28, 2015 at 10:36 AM
    #132
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    it all depends on what you want to do and what cash you can do... I went with the OME and don't regret it I am taking off the sway bar for more travel on the front and will be putting armor on the front as soon as I can. More weight equals more resistance to the "jump"
    Kyitty likes this.
  13. Aug 28, 2015 at 10:37 AM
    #133
    xsteinbachx
    xsteinbachx Well-Known Member
    Victoria, BC
    2017 White TRD Sport DCLB 4x4
    Seems like Bilsteins are a waste of time too.
  14. Aug 28, 2015 at 10:39 AM
    #134
    T4RFTMFW
    I thought it was common knowledge that everything besides King's is shit? :D
    NorthwestCruiser and dakotasyota like this.
  15. Aug 28, 2015 at 10:44 AM
    #135
    Red Baron
    Aaron
    07 Radiant Red DCSB
    oh yea and DB lifts are the shit :rofl:
  16. Aug 28, 2015 at 10:45 AM
    #136
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    :rofl: for real though. You guys do know they come with C rated right??
  17. Aug 28, 2015 at 10:47 AM
    #137
    dakotasyota
    Dakota
    Ellensburg, WA
    Comfier ;)
    Red Baron[QUOTED] likes this.
  18. Aug 28, 2015 at 10:49 AM
    #138
    T4RFTMFW
    Appropriately rated tires are for bitches.
    A single E rated tire has a higher load rating than my Tacoma even weighs, and that is badass.
    dakotasyota[QUOTED] and Hartford like this.
  19. Aug 28, 2015 at 11:01 AM
    #139
    Red Baron
    Aaron
    07 Radiant Red DCSB
    soooo glad that I didn't blow the tires when I found what mine governs at with my E tires, had to go that badass for my fat ass
    T4RFTMFW[QUOTED] likes this.
  20. Aug 28, 2015 at 11:03 AM
    #140
    TREED
    JT
    Spring Creek NV
    15 trd taco dc
    I fully understand the tires argument but you will be walking home after wheeling a c rated tire, Not to mention tires have nothing to do with the suspension articulation except the weight of the tire during sag. They do affect ride due to sidewall stiffness etc. If that was the case I would have king make me some long travel tires and have a set of Cadillac tires for street driving and some lambo tires for more hp and prius tires for 50 mpg.
