Ome 885 vs Eibach
Discussion in 'Suspension' started by knine00, Jan 19, 2012.
  1. Jan 19, 2012 at 1:02 PM
    knine00
    knine00 [OP] Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    What are the pros and cons of each spring? Trying to figure out which one to go with for road driving not so much off road.
  2. Jan 19, 2012 at 1:10 PM
    Large
    Large Red
    Can't go wrong with OME. They are $150 + shipping and fairly easy to install.
  3. Jan 19, 2012 at 1:16 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    OME = about 2.5" of lift
    Eibach = about 1.6" of lift but can be set on 5100's preloaded to .85 for 2.5" of lift.
    Eibachs are a shorter and stiffer than the OME's. They're both similar price wise. Can't really go wrong with either one, you'll find a ton of members that have either or and are happy. Personally, I went with Eibach. Being a little stiffer I like it for the driving I do which is mostly on the road.
  4. Jan 19, 2012 at 1:19 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    get a full OME set up and be done with it you wont be unhappy...this is coming from a billy owner....unless u wanna spend big dollars for an icon-king-fox setup....
  5. Jan 19, 2012 at 1:30 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I just picked up a set of 5100 with eibach springs but found some ome 885 for a decent price. Should I stay with the eibach and save my money?
  6. Jan 19, 2012 at 1:34 PM
    Pugga
    Massachusetts
    Do you have the eibachs installed yet? If you do and you like them, keep them. If not, your call. the OME's can get you a little more lift and will be a little softer due to the lower spring rate but both are great products.
  7. Jan 19, 2012 at 1:41 PM
    knine00
    Hudsonville, Mi
    Stock for now
    No I havent installed anything yet. I am waiting for my Icon 3 leaf progressive to come on.
  8. Jan 19, 2012 at 1:53 PM
    Pugga
    Massachusetts
    How much lift do you want up front?
  9. Jan 19, 2012 at 3:15 PM
    knine00
    Hudsonville, Mi
    Stock for now
    2.5 to 3
  10. Jan 19, 2012 at 3:30 PM
    tacoma07pre
    tacoma07pre Well-Known Member
    kansas city
    Can ome coils be installed on the 5100s?
  11. Jan 19, 2012 at 4:07 PM
    Pugga
    Massachusetts
    If you want to be between 2.5 and 3", then the OME coils sound like they'd be a better fit for you. You shouldn't have any trouble selling the Eibachs since they're on back order.
    Yes, you can use OME coils with 5100's with the exception of the 886 coils. If you're going to use the 886's, you should pair them with the Nitrocharger shocks.
  12. Jan 19, 2012 at 4:09 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I guess the springs are 885X not sure if that makes a difference?
  13. Jan 19, 2012 at 4:15 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Would the eibachs be better with a top spacer?
  14. Jan 19, 2012 at 4:26 PM
    Pugga
    Massachusetts
    885x would be better. The older 885's had manufacturing issues and would sag over time. The 885x are the newer ones and have a greater resistance to sagging.
    The OME coils are a taller coil. To get the Eibachs over 2.5", you need to preload them by setting the 5100's at .85 and then put a top plate on top of that. The OME coil will get you to 2.5" without any preloading or top plates. OME with trim packers will get you to a full 3". Both set-ups will work, just personal preference I suppose. FWIW, Toytec makes a different top plate to be used with the 5100/Eibach set-up to get you to 3" of lift if you want to keep your coils and not deal with the hassle of buying new and selling yours.
  15. Jan 19, 2012 at 4:35 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I take it in the long run a non preloaded spring wont cause near as much wear and tear on the suspension like a preload spring will?
  16. Jan 19, 2012 at 4:44 PM
    Pugga
    Massachusetts
    If a preloaded spring puts you to 2.5" or a non-preloaded spring puts you at 2.5", both will have the same effect on the other suspension components. I wouldn't let that be the deciding factor.
    Eibachs are a stiffer coil, so when you preload them, they'll be even stiffer. Eibachs have a spring rate of around 620#/in while OME has a rate of 580#/in if I recall correctly. That's why I suggested considering the OME's, they have a lower spring rate, are a taller coil and will give you the amount of lift you want without preloading or top plates.
  17. Jan 19, 2012 at 4:45 PM
    octacorunner
    octacorunner Well-Known Member
    G
    Orange County
    11 DCSB
    t|x pro rims, trd exhaust painted flat black, retrofit hids on oem smoked headlights, weathertech digifits, interior & exterior LEDs, console vault, 20% tint (need to install: eyelids, lower grillcraft, satoshi by homer)
    Get the OMEs and sell me the eibachs :thumbsup:
  18. Jan 19, 2012 at 4:48 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Ok I get what you are saying.....The ome would be a better ride then the eibach's? Thanks for the help!
    LOL I will let you know what I do.
  19. Jan 20, 2012 at 3:44 AM
    knine00
    Hudsonville, Mi
    Stock for now
    So the guy sold the springs to someone else. Would it be better to add the spacer then preload my eibach springs to 2.5?
  20. Jan 20, 2012 at 4:06 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    The red eibach's I have are #600 and heard they have some silver one's as well. Bilstein suggests to only use the eibachs as thats what they were desiged for. I'm assuming it's due to the different lengths?? Maybe the spring rate type.....I think the eibachs are progressive and the OME's are linear and softer?? Just some thoughts!
