OME 885's & 5100's
Discussion in 'Suspension' started by jjbsocal, Nov 2, 2011.
  1. Nov 2, 2011 at 10:57 AM
    jjbsocal
    jjbsocal [OP] Well-Known Member
    Jeff
    So☆Cal
    2010 DCLB PreRunner TRD Sport
    Camburg MT; 4.0 Spindles and UCA's, Fox Extended Travel with Resi's all 4 Corners, All Pro Expo Leaf Pack, Method Standard's, BFG AT's, DTLT's, 1st Gen TRD CAI, Magnaflow Pro Offroad Exhaust..
    I am planning on running this set up until i can afford a spindle lift.. What wanted to know is this;
    I see that often people recommend NOT to set the billies above 0" with 885's, but no one says why.. Is is because it would set the lift above 3" and require new UCA's or is there some other reason??
  2. Nov 2, 2011 at 10:58 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You can set them to .85
  3. Nov 2, 2011 at 11:09 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    It's because you bought a lift coil so preloading them is not necessary. 885's are taller and stiffer than the factory coils, no need to preload, if you want to get to 3" of lift, use the trim packer.
  4. Nov 2, 2011 at 11:14 AM
    jjbsocal
    Jeff
    So☆Cal
    What i want is for the truck to have around 3" of lift and be level.. my plan so far is to add Dakars with the AAL for the rear (sometimes i carry camping gear, firewood, etc.).. 17x9's with 4.5" BS and either 275's or 285's without having to cut anything..
    Thats the plan, for now.
  5. Nov 2, 2011 at 11:23 AM
    OZ-T
    Peter North
    British Columbia
    Set the 5100's at 0 and use trim packers to get to 3" as Pugga suggested
  6. Nov 2, 2011 at 11:25 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    x2
    This is what I have on my truck right now. Rides great. It's the 886's you wanna leave set a 0". Your gonna have to cut with 285's.
    Oh, and don't skimp out on uca's...
  7. Nov 2, 2011 at 11:30 AM
    jjbsocal
    Jeff
    So☆Cal
    I am planning on running a Mid-Travel set up when i get the funds (Total Chaos +2" system with 3.5" Spindles and ICON Coilovers) havent decided what to do in the back yet, but leaning towards the AllPro expeditions or Baja's..
    I dont think the 2" TC UCA's will fit on stock, so maybe some LR UCA's in the short term..
