OME 885s and 5100
Discussion in 'Suspension' started by bangin4WV, Apr 21, 2018.
  1. Apr 21, 2018 at 7:15 AM
    bangin4WV
    bangin4WV [OP] Well-Known Member
    Rocky
    WV.
    2016 SR5 2.7 MGM ACLB
    33s/sliders
    Are the 885s stiffer than the oem springs? These are suppose to give me about 2" lift but are about the same length?
  2. Apr 21, 2018 at 8:02 AM
    bangin4WV
    Rocky
    WV.
    33s/sliders
    No ONE? I'm kinda in a bind here guys. ANY help would be greatly appreciated.
  3. Apr 21, 2018 at 12:32 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    No you don’t, 885s are the same spring rate as 887s. With the 885s will see approximately 2.5” lift for a DCSB 2nd gen. So your 3rd gen should be about 1.5” lift on those coils. I don’t believe they are a higher spring rate than your stock coils but I don’t know about the 3rd gens. I believe the correct coils you need are the 888s for a 3rd gen 2” lift.
  4. Apr 21, 2018 at 12:35 PM
    Brent2014
    Brent2014 Well-Known Member
    Raleigh
    2020 DCSB TRD SPORT
    885s only give about 1.5 inch of lift on the third gens. I put those on my buddy’s truck and I put 887s on mine. They both handle and feel the same, I just have a little over an inch of lift on him. The 885s leveled the truck out nicely though. I put 1.5 inch aal in the rear of mine to level it out as well.
  5. Apr 21, 2018 at 5:29 PM
    DaveCanuck
    DaveCanuck Well-Known Member
    Dave
    Canada
    2011 SR5 V6
    I bought a DeMello aftermarket steel bumper (haven't installed yet), I think weighs 100lbs... what would be an appropriate spring if I wanted to add a little lift from stock?
    Also, what shocks would be best to use with the OME springs?
  6. Apr 21, 2018 at 11:26 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    883s or 884s. Depends how much lift u want to achieve and if you have an access cab or DC. The OME springs are meant to pair up with the OME struts but plenty of guys pair up the 5100s with OME coils with zero probs.
  7. Apr 22, 2018 at 2:34 AM
    bangin4WV
    Rocky
    WV.
    33s/sliders
    Thanks. Is your buddy's truck a 6cyl.? Do you know if his settled any?
  8. Apr 22, 2018 at 3:06 AM
    Brent2014
    Raleigh
    2020 DCSB TRD SPORT
    It is a 6cyl and yes it will settle a little, but his was nose high for a few days and settled into being level.
  9. Apr 22, 2018 at 3:28 AM
    bangin4WV
    Rocky
    WV.
    33s/sliders
    That's odd. I have the 4cyl. and it only gave me 1 1/2'' of lift.
  10. Apr 22, 2018 at 3:31 AM
    Brent2014
    Raleigh
    2020 DCSB TRD SPORT
    That’s about what it netted him as well. We measured and his rake was like 1.6 inches stock. Afterwards the rake was 1/16th of an inch.
