OME 885's with 5100's at .85???
Discussion in 'Suspension' started by veet skeet, Apr 29, 2012.
  1. Apr 29, 2012 at 1:08 PM
    veet skeet
    veet skeet [OP] Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    Would it be fine to run 885 OME coils with 5100's set at .85 in the front? I know most people run the 885's without presetting the 5100's at anything, but would setting it at .85 with 885 coils be fine? Are there gonna be any problems? And how much lift would that yield on a DCSB? Thanks
  2. May 11, 2012 at 12:11 PM
    Tacoma977
    Tacoma977 Active Member
    Seth
    Texas
    2012 Tacoma TRD
    5100's set @ .85 w/;OME 885X coils and 2" Toytec AAL, 285/75/16 General Grabber A/T II's,Spidertrax 1.25" whee spacers, Toyota Preditor steps. Plasti-dipped grill trim and emblems, Weather Techs
    it would give you a little over 3" in the front with that setup. I just called downsouth motorsports and ordered that setup for my 12 DC trd. the technician on the phone said i would get a little over 3 inches in the front. I also ordered toytec 2" aal for the rear. i may have to go with a 1" block too but we will see. ill post pics next week if i can get it installed in time.
  3. May 11, 2012 at 12:12 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    You should be OK - I know somebody running this setup without issues.
  4. May 11, 2012 at 12:14 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How old are the 885's and are they the old 885s or the new 885X coils? Some people have set their 5100's to .85 mostly due to added weight of a plate bumper and/or winch or because the old 885s would sag over time and they wanted to regain some lift. Brand new, I wouldn't put 885s on 5100's set at .85. I'd look into the top plate spacers instead as that should put you at 3" of lift.
  5. May 18, 2012 at 7:50 PM
    PLYDRTY
    PLYDRTY Well-Known Member
    Jeff
    Haymarket, VA
    17 MGM TRD OR DCSB
    I just put a set of lightly used 885's (I think they are X's) on mine w/ the 5100's at 0. It definately looks like I got about 3" out of them. I had 3" spacers on the stock shocks/coils & it seems to sit about 1/2" higher now.
  6. May 18, 2012 at 7:54 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I put some old OME 885s on my 5100s at the .85 setting and I have about 3 inches of lift.
    So yes you will be fine.
  7. May 18, 2012 at 7:57 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    My truck sits a smidge over 3" up front with the 5100s at 0.
    Of course I have a prerunner so....
  8. May 18, 2012 at 7:58 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    I'd advise you to keep them at the "0" setting. If you do not have after market UCA's..
  9. May 19, 2012 at 5:52 AM
    Tacoma977
    Seth
    Texas
    2012 Tacoma TRD
    Im installing mine today. Im 1" higher in the rear stock. I just need 3" in the front to go with my 2" aal. My coils are 885x coils so maybe ill try the 0" setting first.
  10. May 21, 2012 at 6:59 AM
    Tacoma977
    Seth
    Texas
    2012 Tacoma TRD
    My install was unsuccessful, the coil spring compressor I picked up from auto zone was not strong enough to compress the 885x coils. The compressor was barley strong enough to compress the factory coils back on the stock shocks. Plus I couldn't get the stock spring to fit back into the the rubber washer thing on top of the stock assembly. So I put everything back together and my truck is pulling to the right, and now I'm calling around to get quotes on installation. I spent way to much time on it and I'm tired of jacking with it.
  11. May 21, 2012 at 9:30 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
  12. May 21, 2012 at 9:35 AM
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    I just did exact combination you are doing. 885x set at zero. I got a hefty 3 inches up front. I had new leafs built for the rear. My alignment numbers were decent but my caster is way out. I do not notice anything driving. But for sure I will notice some wear down the road if I do not replace the UCA
    But I think you will get what you need set at zero
    I am 4x4 as well
  13. May 21, 2012 at 9:36 AM
    Pugga
    Massachusetts
    Caster can be out and not affect tire wear. Toe and camber are the 2 that can eat up a set of tires.
  14. May 21, 2012 at 9:43 AM
    06tacomakev
    Kev
    Victoria BC
    You are right. I know one of the C is way out. I must have it backwards. I will check my spec sheet
  15. May 21, 2012 at 9:44 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get UCA's ^^^
  16. May 23, 2012 at 5:53 AM
    Tacoma977
    Seth
    Texas
    2012 Tacoma TRD
    Getting installed tomorrow at local 4x4 off road center. I woukd like to add 18" wheels and tires in the future.
  17. May 23, 2012 at 6:08 AM
    Pugga
    Massachusetts
    x2, and I just happen to have a set for sale :stirthepot:
  18. Jan 28, 2013 at 10:12 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Threads a little old but whatever... What about 885's with 5100's at .85 with top plate spacers? Not sure if you considered that or not or if it was implied that you would get them. I want a full 3" and I wouldn't mind a tad over. I'm thinking that would put it well over 3".
  19. Jan 28, 2013 at 10:14 PM
    OZ-T
    Peter North
    British Columbia
    I wouldn't
