OME 885x with 5100s how much lift
Discussion in 'Suspension' started by Tacoma414, Dec 13, 2012.
  1. Dec 13, 2012 at 12:58 AM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    so i found a deal on OME 885xs and 5100s all around, i have an access cab prerunner not 4x4, i dont want the full 3" cause i dont have the money for UCAs, i want 2.5" of lift in the front, what will i get with the 885xs cause i know they have a little higher spring rate, and if it is the full 3" what springs should i get to have 2.5" of llft and the billies at 0
    thanks
    -Cody
  2. Dec 13, 2012 at 2:08 AM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Poweraid TB spacer, a bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, LR UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more but it's alre
    I'll measure mine later, but it's not a full 3". You won't be disappointed.
  3. Dec 13, 2012 at 2:16 AM
    TRON_
    TRON_ The Game Has Changed
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    IG: st3f3ns OverlandBound1235 R.I.P. Rinzler
    X2 if you found a deal on this lift, go for it! i have this on my prerunner as well and its worked just fine for a basic 2.5 - 3" lift.
  4. Dec 13, 2012 at 2:25 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Since your front end is a little lighter, access cab pre runner, i would go with 884s if you dont want UCAs. 885s will probably get you real close to 3" Actually if you are concerned about UCAs you should look into a spindle lift.
  5. Dec 13, 2012 at 3:17 AM
    Tacoma414
    Cody
    Agua Dulce
    Texoma- thanks!
    T4COCH40S- yeah I'm thinking about it I'm just not sure! I want the Pre runner look so I don't know if I want to AAL or not, I don't want it to have to much of a lean but just a little higher in the front
    evanmb31- spindles are pricey, and I was thinking about just getting the shocks and getting the 884s but I want 2.5 and I heard those give you 2" which I have right now with spacers
  6. Dec 13, 2012 at 4:02 AM
    TRON_
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    when you say prerunner lift do you mean socal lift being alittle higher in front? i have a pic somewhere that shows what the lift looks like with just the 885s and 5100s and a stock tsb lift in the rear, no AAL. ill find it and post in here
  7. Dec 13, 2012 at 4:22 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    If you end up needing UCAs with the new coilovers then spindles would probably be the cheaper option. From what i have read 885xs ushually get 2.5 inches with double cab 4x4s. Some access cabs are more like 2 3/4. Just dont want this to happen http://www.tacomaworld.com/forum/suspension/244811-5100-ome-885-install-problems-help.html somehow he got 4 inches, but this might be the only case of that happening with 885s on an access cab prerunner. You will probably be fine with 885s, you just might get a little more lift than others because your front end is lighter.
  8. Dec 13, 2012 at 4:29 AM
    TRON_
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    heres the pic back before i did the 1.5" AAL. I have 885x, 5100 set at 0, and a spring TSB for the rear
  9. Dec 13, 2012 at 4:31 AM
    evanmb31
    evan
    connecticut
    09 trd off road
  10. Dec 13, 2012 at 4:37 AM
    TRON_
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    I had similar measurements (about 3.15" settled to 2.9" after couple months) and know atleast 2 others that have the same lift and still use their stock UCAs.
  11. Dec 13, 2012 at 6:45 AM
    Squirrel cage
    Squirrel cage Well-Known Member
    Sam
    Reno NV
    2016 DCSB TRD OFF ROAD
    Icon stage 4 lift,FN Countersteer wheels (16X8), 285/75/16 Duratracs
    That looks awesome! Did you raise the 5100's at all after you did the aal? Got any pics of that set up? I'm doing my lift this weekend, and am trying to figure out where to set the billies with the 885x and tsb+1.5 aal. (Only want to take it apart once) haha
  12. Dec 13, 2012 at 6:47 AM
    TRON_
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    Thanks man, youll have to check my build for all the specs and pics but thats an old pic haha! after the AAL i rode that around for a good 4-5months before raising the 5100s to the .85 setting. but now i have a bumper on the front that weighs it back down
  13. Dec 13, 2012 at 8:08 AM
    Squirrel cage
    Sam
    Reno NV
    Thanks! I think after seeing some of your pics ill leave them set at 0. Besides I still have stock uca's.
  14. Dec 13, 2012 at 10:08 AM
    Tacoma414
    Cody
    Agua Dulce
    So should I stick with the 885xs or what, cause I don't have 4x4 and only an access can so I don't want it to high, I just wanted to lift it enough to give it a little more of a lean and ride great without doing anything to the back besides putting the 5100s back there, I feel like mattmxracer has what I want and I wouldn't AAL
  15. Dec 13, 2012 at 11:58 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    I would do 884s to be safe, but that is just my opinion. I am installing 885s on my access cab but i have LR UCAs an dakars. If you want the front noticeable higher than the rear then go with the 885s but theres more of a chance that you will need aftermarket ucas.
  16. Dec 13, 2012 at 12:10 PM
    GeatWhiteNorth
    GeatWhiteNorth Well-Known Member
    Morgen
    Victoria BC
    05 TRD DC LB
    LR UCA's, 5100 all around, OME 885, add a leaf, Elite Sliders, 285's
    X2 on the 884
    I have 885x with 5100's set a 0 plus a 1/4 spacer and im sitting at a full 3" but i have a 4x4 dbl cab long bed.
  17. Dec 13, 2012 at 12:37 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Just doing a little math here...
    Coils run about $170
    Front bilstiens run about $175
    Now you will be over 2" of lift which means you may experience alignment issues (some say no, I say yes from my experience). For this reason you may need UCAs, which means another $375
    For a total of $345 w/o UCAs and $720 with em'
    Oh yeah… you also lose droop and stiffen things up a bit basically making your truck more street worthy than off-road worthy.
    ~OR~
    You get spindles and maintain a factory ride, alignment will be tits, get enough lift to clear 285's, and you get to keep your stock shocks and coils. Spindles sale for $485 - $510 for one brand and $800-$1200 for others.
    Was already mentioned, but just thought I'd bring this up again.
    I have a prerunner and I personally would never lift my truck any other way. Every 2wd truck I have owned has had spindles, the first one of which originally had coils. The ride was crap regardless of the different brands I tried until I finally got talked into spindles. Have never lifted a 2wd truck any other way since.
  18. Dec 13, 2012 at 12:45 PM
    Khaos
    Khaos Big Member
    Bryant
    Tallahassee FL
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Already got my 885s, 5100s are next. Access cab Prerunner.
  19. Dec 13, 2012 at 3:55 PM
    Tacoma414
    Cody
    Agua Dulce
    Can't afford sprindles, I have 97k on my stock shocks so I need new ones regardless, but I don't think that deal could work cause the guy had an 2012 4x4 DC so I don't think they will work
    Khaos let me know how the lift goes once you get the 5100s and send pics if you can I'd appreciate it
  20. Dec 13, 2012 at 11:36 PM
    Tacoma414
    Cody
    Agua Dulce
    so im confused, i called DSM and they said i will only get about 1.75" of lift with the 885xs and bilsteins at 0, he said i would have to set the billies at .85 to get about 2.5" of lift. does that make sense? i told him i only have the access cab 2wd and still said thats what ill get at 0, im so confused! why cant it be easier with shocks and springs, it would be with a spindle or coil over but cant afford
    all i want to see is an access cab with a stock back with 5100 shocks, no AAL or anything, and the 885xs and 5100s at 0 in the front so i can see what it looks like, yes i know there will be the "bro lean" but everyone has 4x4s and its completly different then a 2wd, more weight so if anyone can find this, my questions would be answered
    thanks
