OME 886 Idea? with top spacer?
Discussion in 'Suspension' started by beer, Apr 13, 2010.
  1. Apr 13, 2010 at 9:27 AM
    beer
    beer [OP] Member
    Cody
    Montana/Oklahoma
    06 Trd Sport
    lift,bumper,wheel-tires,intake,moretocome
    So I have a 2006 Trd sport 4 door with OME lift 886 and nirochacher 90000 shocks on the front. I was Wondering if it would be a good idea to put a top spacer in? I do have a aftermarket ARB bump on the front too and I didn't get a 2" lift in the front when in lifted it I got just under a 2" lift would top spacer be a good idea or not? and if so what size of a spacer? :confused:
  2. Apr 13, 2010 at 9:28 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have OME 885's on my 06 TRD Sport 4door and it came with a top plate spacer. I think it only gives about 1/2" of lift and I'm pretty sure I got a full 3"s of lift out of it. Maybe a little less since its settled now.
  3. Apr 13, 2010 at 5:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You will be fine to run the spacer to give extra lift. a 14mm should give you close to 3", and a 10mm will give close to 2.5"
