ome 886+what shock? for 3in lift?
Discussion in 'Suspension' started by achirdo, Jul 6, 2010.
  1. Jul 6, 2010 at 1:26 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i have a 05 double cab with the long bed and i plan on getting a steel plate front bumper so i figured the 886? coil would be the best correct? and also what is the best shock to use with with the most down travel? i stupidly purchased a spacer lift and now i want to do the front suspension right with out forking over $1000+ on coilovers...
  2. Jul 6, 2010 at 1:32 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    couple options. 886 with OME shocks and the extra top plate spacer wheelers has OR 886 with 5100s set NO HIGHER than .75" this will make the front end stiffer than the all OME setup.
  3. Jul 6, 2010 at 1:33 PM
    achirdo
    Adam
    North DFW
    or maybe Leeper coilovers...thoughts on these?
  4. Jul 6, 2010 at 1:34 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    and your down travel is going to be limited more by your Upper Control Arms and CV joint angle.
  5. Jul 6, 2010 at 1:34 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    Not a clue priced well thats all i know. They are a new beast.
  6. Jul 6, 2010 at 1:35 PM
    achirdo
    Adam
    North DFW
    so if i got new UCA i would have more down travel?
  7. Jul 6, 2010 at 1:38 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    slightly but upper control arms are more so you can get a perfect alignment. If you're looking for downtravel you're going to be looking at Long travel but that is $$$. I've got 885 with OME shocks and I haven't lifted a front wheel doing the light wheeling i do.
  8. Jul 6, 2010 at 1:44 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    From what I've read the 886 coils should already give you about 3" or higher.
    I think most people would recommend the OME shocks if you're going with OME springs. Some on here have OME springs + Bilsteins.
  9. Jul 6, 2010 at 1:45 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    Yes in his first post he said he's getting a plate bumper.
  10. Jul 6, 2010 at 1:46 PM
    tim920
    Tim
    Boston, MA
    Somehow I missed it even scanning it 3 times. :eek:
  11. Jul 6, 2010 at 1:54 PM
    achirdo
    Adam
    North DFW
    but thats probably not going to be for over a year after i put the coils and everything on...but the 886 with the ome shocks will give me 3in even with the plate bumper right? im just worried bout my tires rubbing if i dont have the full 3 in
  12. Jul 6, 2010 at 1:58 PM
    tim920
    Tim
    Boston, MA
    I thought everyone rubs even with 3 inches. I thought it was a given that we had trim no matter what with 33 inches. I could be wrong though.
    Bump for better help.
  13. Jul 6, 2010 at 1:59 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    well i would say assemble the 886 coils with the longer top plate bolts and install them if your itching to get them on. It will be stiff but won't be so high that you kill your cv joints and whatnot. then when you get your bumper it should cause the front end to sag all you will need to do it undo three nuts install the top plate spacer and you're done. It is really really important that you install the longer studs when you assemble them otherwise there is not enough thread to install the top plate later.
  14. Jul 6, 2010 at 2:04 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah if you are going to be running 33"s on a 2.5"-3" lift you will have to do some trimming but only up front. The rear does just fine. You will also have to remove the front mud guards as well. I have OME 885 coils w/top plate spacer and 5100's set at 0" height and its a full 3"s of lift. If not, its just barely under 3" cause its settled by now. I also have 33" tires and had to trim up front but it wasnt hard at all.:cool:
  15. Jul 6, 2010 at 2:12 PM
    achirdo
    Adam
    North DFW
    i just moved the front plastic piece up further...and the mud flags are gone...BUT just to make sure there are not any down sides to having this OME set up correct?? i want to do things right this time around
  16. Jul 6, 2010 at 2:12 PM
    achirdo
    Adam
    North DFW
    and also how much would that front set up end up costing me for parts?
  17. Jul 6, 2010 at 2:15 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah you should be just fine with that setup unless you want to go with a full coilover kit.
    Go check toyteclifts.com and you should be able to get some prices from there.;)
  18. Jul 6, 2010 at 2:32 PM
    achirdo
    Adam
    North DFW
    are those leeper 500 buck coilovers considered a a full coilover kit? or what else would be needed with those. because what i can see it looks like they will both ond up bein bout the same price. will the coilovers sag more in the front with the steel bumper?
  19. Jul 6, 2010 at 2:36 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    nice thing about coil overs is you can just crank them up top prevent sagging you can probably even get new springs if you wanted to.
  20. Jul 6, 2010 at 2:38 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Thats why I like the idea of them, the adjustment.;)
