OME 886 with Bilstein 5100 - Good or bad?
Discussion in 'Suspension' started by Sandman614, Jun 9, 2011.
Poll closed Jul 9, 2011.
  1. Bilstein 5100's will be 100% ok with OME 886 coils
    7 vote(s)
    35.0%
  2. Bilstein 5100's are junk and will break on OME 886 coils
    0 vote(s)
    0.0%
  3. OME nitrochargers with OME 886 coils are the way to go
    11 vote(s)
    55.0%
  4. Other, explain
    2 vote(s)
    10.0%
  1. Jan 12, 2016 at 7:25 PM
    #41
    Tako9
    Tako9 Well-Known Member
    Gatineau, Québec
    07 Trd offroad access cab SWB
    Ok cool I might do the 886 on 5100 plus 1.5-2" aal on the rear... thanks for the input!
  2. Jan 12, 2016 at 8:09 PM
    #42
    Honeybadger
    Honeybadger Powaaaaaah!
    Alex
    Kirkland, Wa
    05 Tacoma TRD Sport 05 4Runner Lmt
    ARB: Front bumper, compressor, tire repair kit, deflate 4xinnovations: Full skids King Racing: extended travel coil overs. Bamf shock relocation buckets with 12" smoothies. EBC: Slotted/drilled brakes with Yellowstuf pads Pioneer: Deck, speakers Wheelers: Front and rear superbumps, extended brake lines Homemade: Rear HC bumper with swingout Toyo: 255/85R16 Open Country MT
  3. Jan 13, 2016 at 10:05 PM
    #43
    Tako9
    Gatineau, Québec
    Forgot to asked which side did you measure up front??
  4. Jan 13, 2016 at 10:16 PM
    #44
    Honeybadger
    Alex
    Kirkland, Wa
  5. Mar 19, 2016 at 2:30 PM
    #45
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    Hmm this is an old thread that just keeps getting revived. So I'll bring it back again. I'm kicking around getting new front shocks but I have 886 coils and a pile of weight. So I may look into the 5100s my front makes a lot of noise offroad. They seem to hit the bumpstops a lot and it makes a popping sound on the rebound. So I think a shock is bad. Idk. It depends.
  6. Mar 20, 2016 at 7:58 AM
    #46
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    As I understand it, the biggest issue with 5100's and 886's is the spring rate for the 886 over taxes the rebound dampening capabilities of the 5100. 5100's are fine with the lower rate spring (such as 885/887's) and well within the capabilities of the 5100. They tend to "jackhammer" with hard rebound when using the 886's. With that said, the higher spring rate also causes premature failure due in large part to the internal shock rebound valving being overworked.
    Casper66 likes this.
  7. Mar 20, 2016 at 8:18 AM
    #47
    M192
    Dan
    Cambria county PA
    Alot
    O ok gotcha
  8. Mar 20, 2016 at 8:33 AM
    #48
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    I read way more complaints from people who are running Nitrichargers and 886 springs than I do 5100s and 886 springs. The topping out/jackhammering issue seems to be exclusive to the OME/886 setup.
  9. Mar 20, 2016 at 8:34 AM
    #49
    Bluegrass Taco
    Bill
    Mt Washington Ky
    My take on THAT is, the 886 is a problem....the common denominator.....that may take a higher end adjustable shock to deal with the stiff rate.
    And the 5100's don't "clunk" when they top out but they don't last very long with 886's either. I think a major contributor to NOT hearing as many complaints on the 5100/886 combo is most of the dealers caution people to avoid that setup.
  10. Sep 6, 2016 at 7:26 PM
    #50
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Blue - help me out here with a shock recommendation.
    I'm going all in with Bruteforce full plate bumpers with winch. Already have dual batteries in the engine bay. Lot's of weight up front (~300 + lbs) so I'm getting 886's.
    I already have 5100's but I risk ruining it with rebound force of the 886's. They are fairly new, so I can get some of my money back selling them.
    I don't really want the OME Nitochargers because many on TW have experienced these guys topping out and getting the dreaded clunk.
    What shock do you recommend to deal with the stiff 866 spring rate? I'm ok with a higher end adjustable shock (within reason.) Which one?
  11. Sep 7, 2016 at 9:46 AM
    #51
    benzy
    benzy Well-Known Member
    Bay Area, CA
    2006 DCSB TRD OR
    Simple OME/884/AAL lift. 32” WP’s
    Happens with 884s and 90021s. Replacing with 90000s solved the problem. The 90000s have better valving IMO.
    Arailt[QUOTED] likes this.
  12. Sep 7, 2016 at 11:00 AM
    #52
    Honeybadger
    Alex
    Kirkland, Wa
    They 5100s will be fine. Just set it on the lowest clip and dint preload them. The rear is a different problem. They are too short for the lift. You can get the 5100s from a tundra to extend the drop but then you will need bump stops for sure.
  13. Sep 7, 2016 at 11:08 AM
    #53
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    this is a bit off topic but why do second gen shocks have that thin bar/tube on the bottom of the shock? why don't they just extend the body all the way down to the eye? seems like every shock I've seen with that little bar breaks right where it meets the body, is it to clear the cv or something? doesn't seem to make sense to me
  14. Sep 7, 2016 at 11:45 AM
    #54
    Subway4X4
    Lloyd
    NY/NJ
    Ok thanks. I'm sticking with the front 5100 set to zero. Already ordered extended length rear Bilsteins.
  15. Sep 7, 2016 at 11:57 AM
    #55
    Honeybadger
    Alex
    Kirkland, Wa
    Did you order bumpstops?
  16. Sep 7, 2016 at 12:02 PM
    #56
    Subway4X4
    Lloyd
    NY/NJ
    Yup. Thanks.
    Honeybadger likes this.
  17. Oct 28, 2017 at 9:07 AM
    #57
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
    I am thinking about a similar setup. OME 881 (don't plan to add winch etc...) and 5100's in the front with 5125 in the rear with either a new leaf pack or aal. My truck already has the ride rite air bags. Will the air bags suffice for the bump stops?
  18. Apr 15, 2019 at 6:51 PM
    #58
    14TacomaTRD
    14TacomaTRD Member
    2014 White Tacoma TRD
    KO off-road bumper with winch
    I just had the local 4x4 shop install my 3" lift. 886 coils, Dakar rear leafs, SPC control arms and 5100s all around per their recommendation. I expressed my concern with this combo but they said they have done allot of Toyotas that way and it works great. So far I love the ride. They actually talked me out of paying extra for the nitro chargers because they said it won't ride as well. Need to get it off pavement for the real test though.
    BrashBrusier and robertjohnsonjr like this.
  19. Apr 15, 2019 at 6:53 PM
    #59
    14TacomaTRD
    14TacomaTRD Member
    While I'm thinking about it. Wouldn't the spring rate for the heavy duty 886 coil be similar to the 885/887 as long as it has all the extra weight from the heavy bumper and winch holding it back?
    twotwentyswift likes this.
  20. May 2, 2019 at 9:08 AM
    #60
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    You brought a very old thread alive sir! haha but you are correct and I actually ran this setup with the 5100s up front with the extra bumper and winch and I love it!
