OME 886'S. WILL I NEED UCA'S?
Discussion in 'Suspension' started by nhgranite, Mar 30, 2011.
  1. Mar 30, 2011 at 4:07 PM
    nhgranite
    nhgranite [OP] Well-Known Member
    N.H
    fisher plow
    going with the ome complete lift. new leaf packs, 886 coils, new shocks etc.. will the lift from the 886's lift the truck to wear i have to do uca's? i've read that 885's give 2 3/4 inches. what about 886's. i run a plow thats why i'm going heavy. 95% of the time the plow won't be on the truck. i'd do uca's but can't afford it now.
    btw what started all this is that i snapped a leaf spring clean in half. i want to do this once.
  2. Mar 30, 2011 at 4:16 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Not 100% sure but I'd say plan on needing them
  3. Mar 30, 2011 at 4:25 PM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    Yes, you do need new upper control arms. It will save yourself from a lot of headaches down the road. I have the Heavy Duty OME setup also, it's a nice all around suspension. The 886 will be a little tough on the front, but I'll be adding a bull bar soon. Hopefully that weight in the front will help, but I doubt it. I have the light racing uca's; no maintenance required. So far so good.
  4. Mar 30, 2011 at 6:33 PM
    nhgranite
    N.H
    fisher plow
    well time to rethink then. might have to compromise and go 885's. what would happen btw? stock wheel backspacing hit the control arm? could i use wheel spacers?
  5. Mar 30, 2011 at 6:34 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    pics of your truck?:cool:
  6. Mar 31, 2011 at 11:03 AM
    plee33
    Peter
    Sacramento, CA.
    I'll get some photo as soon as i can.
  7. Mar 31, 2011 at 2:14 PM
    Sprink669
    Sprink669 Well-Known Member
    I have OME 886's with a ARB and warn winch, I do have Light Racing UCAs I have 4.5" BS rims and i have 285-75-16's. I had it aligned before the UCA's and then again after I did see a bit of difference in driving on the freeway.
  8. Mar 31, 2011 at 2:16 PM
    crf69
    Ohio
    ummm yeah
    pics of your truck?
  9. Mar 31, 2011 at 2:18 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    You'll need new UCAs with 885s aswell...OME revised there springs a few years back to prevent sagging so you get a little more height. I'm running 885s with Bilstein 5100s with NO top plates and i'm getting 3.25" up front. Without new UCAs your alignment will be off and you'll trash your tires.
    Check out Light Racing UCAs...best UCAs for you $$$ hands down and there fully adjustable
  10. Mar 31, 2011 at 2:27 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Without UCA you can align toe and camber to spec. Those affect tire wear. Caster will be off, but that just affects "feel"
  11. Mar 31, 2011 at 4:00 PM
    plee33
    Peter
    Sacramento, CA.
    Here it is.
  12. Mar 31, 2011 at 4:01 PM
    crf69
    Ohio
    ummm yeah
    nice!
  13. Mar 31, 2011 at 4:03 PM
    plee33
    Peter
    Sacramento, CA.
    Yep, 886 in the fronts.
  14. Mar 31, 2011 at 4:03 PM
    ColtsTRD
    Scott
    AZ
    Great lookin' truck!
  15. Apr 1, 2011 at 2:34 AM
    Sprink669
    I will get some this weekend
