OME 887 with Bilstein 5100
Discussion in 'Suspension' started by BeaverYota, Apr 7, 2015.
  1. Apr 10, 2018 at 6:10 PM
    #461
    TacoJuan
    TacoJuan Well-Known Member
    Hanover, PA
    2015 Black Tacoma TRD OR
    It sucks, I’m leaning towards that now... I just want to be sure of what it is. It’s so faint, I don’t know if it’s just in my head or maybe my tires. I think I’m going to let it go a little while longer and see if it gets any worse
  2. Apr 10, 2018 at 6:10 PM
    #462
    Travis1209
    Travis1209 Well-Known Member
    Travis
    2011 TRD Offroad Double Cab SB
    I lifted mine with 5100s at 1.75 and 2.5, before I had the 887s, and had the slight vibe from the needle bearing. Bought the ECGS bushing right away, cheap brand new. ECGS bushing is an easy swap too if you use their tool to pull the original needle bearing out. Completely fixed the slight vibe I had.
    The driveline vibration was a different story lol....had to go Tom Woods one piece on that to get the truck back to normal
    :bananadead::threadjacked:
  3. Apr 10, 2018 at 6:12 PM
    #463
    Travis1209
    Travis
    Letting it "get any worse", could end up scribing the needle bearing marks into your CV shaft. Then when you do the bushing swap you'll need a new CV shaft more than likely. Do the ECGS bushing and have a peace of mind
  4. Apr 10, 2018 at 7:14 PM
    #464
    TacoJuan
    Hanover, PA
    Ugh. I’ve re done my suspension 3 times now getting it to where I want it lol. I’m dreading this... does the truck need an alignment after?
    Rob Daman likes this.
  5. Apr 10, 2018 at 7:15 PM
    #465
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    It sounds like he can't even tell what the vibes are from. He could very well be feeling drive line vibes now that the TSB fixed the needle bearing.
    OP, I would try all the usual troubleshooting steps for the needle bearing and see if you get anywhere.
  6. Apr 10, 2018 at 7:31 PM
    #466
    TacoJuan
    Hanover, PA
    Nah, I’ve fixed the driveline vibes awhile ago, and I had the needle bearing vibes bad awhile back, I had the dealership replace it under warranty, it just feels like they’re coming back now. Maybe the needle bearing is wearing out. But they’re extremely faint. Same intermittent hum around the 30-35 mph mark
  7. Apr 10, 2018 at 8:05 PM
    #467
    Travis1209
    Travis
    Yea if you do it, an alignment should be done afterwords
  8. Apr 10, 2018 at 8:06 PM
    #468
    Chase8059
    Chase
    ESVA
    It's possible it's the OEM bearing going bad again. I wonder of a dealer would even do the TSB twice on the same truck :notsure:
  9. Apr 10, 2018 at 10:54 PM
    #469
    TacoJuan
    Hanover, PA
    What a pain... I don’t think I’ll even bother with the dealer again. I’ll just do the ecgs bushing call it a day... unless I can guilt the dealer into installing it for me instead of another bearing...
  10. Apr 11, 2018 at 4:05 AM
    #470
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    what is this ecgs bushing thing? only need to change it if you lift ?
  11. Apr 11, 2018 at 4:21 AM
    #471
    Travis1209
    Travis
  12. Apr 11, 2018 at 7:25 AM
    #472
    Chase8059
    Chase
    ESVA
    I hear ya, but if they reqplce it for free and under warranty it's not terrible to let them keep doing it. But I also get just wanting to have fixed for good.
  13. Apr 12, 2018 at 4:21 AM
    #473
    Canadianguy91
    Sean
    2016 Limited
    Just looking to clarify some stuff guys.
    I'm going with the 5100's and the 887. I got a third gen so this will give me 2" of lift?
    Also anyone have 265/70/18?
  14. Apr 15, 2018 at 6:35 AM
    #474
    Canadianguy91
    Sean
    2016 Limited
    Beauty truck man! I'm leaning towards the same setup. I'm not sure which add a leaf to go with yet. Why did you choose the Icon 1.5 progressive leaf? Also could you fit 18's with the 70 sidewall??
  15. Apr 21, 2018 at 7:06 AM
    #475
    Canadianguy91
    Sean
    2016 Limited
    was there a write up on installation?
  16. Apr 25, 2018 at 4:23 PM
    #476
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    hey! how much mpg difference was it? how are you liking it so far after few months now?
  17. Apr 28, 2018 at 3:19 PM
    #477
    Canadianguy91
    Sean
    2016 Limited
    do you only need the spacers because of the width?
    Would it if fit if it was 265?
  18. Apr 28, 2018 at 8:53 PM
    #478
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    What AAL do you have? 1.5?
  19. Apr 29, 2018 at 2:38 PM
    #479
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Ya I had the Wheelers 3 leaf with stock length 5100s. Id recommend them again in a heartbeat especially for the cost.
  20. May 3, 2018 at 11:14 AM
    #480
    AZ_tromping
    AZ_tromping New Member
    Nate
    AZ
    2015 4x4 SR5
    Billstein 5100 , OME 887 , SPC Light Racing UCAs, 17” Pro Comp wheels with 285 & a dog hammock in the backseat
    I just ordered this lift ( 5100s , 887, LR uca, and Deaver aal ) Do I need extended brake lines or will the stock lines be fine ?
