OME AAL question
Discussion in 'Suspension' started by thedude, May 13, 2011.
  1. May 13, 2011 at 11:24 AM
    thedude
    thedude [OP] Well-Known Member
    Lucas
    Little Rock, AR
    I have a 2010 TRD Tacoma without the TSB AAL done. I'm getting the OME kit with an AAL so should I bother with the TSB? Thanks
  2. May 13, 2011 at 11:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can get a 2" AAL
  3. May 13, 2011 at 11:28 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    get the 2 the 1.5 sucks if you put any weight in the bed
  4. May 13, 2011 at 11:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd still get the TSB if you need it. I've got a TSB pack with an AAL in it, much much better than the way it came from the factory.
  5. May 13, 2011 at 11:39 AM
    thedude
    Lucas
    Little Rock, AR
    Yeah I would if I wasn't already getting an AAL through the lift kit. Don't want the hassle of messing with the dealership if I don't need to.
  6. May 13, 2011 at 11:43 AM
    Pugga
    Massachusetts
    You probably don't NEED it, but if you think you need it now, before you install your lift, then all you're doing by putting the OME AAL in is making that single leaf pick up the slack from your stock leaf pack. If you plan on spending a lot of time hauling or towing I'd get the TSB, then throw the 1.5" AAL along with it.
  7. May 13, 2011 at 11:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If youre not having any bottoming out issues, then you dont need the TSB.
  8. May 13, 2011 at 11:56 AM
    Pugga
    Massachusetts
    Much simplier way of stating it :thumbsup:
  9. May 13, 2011 at 12:04 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X3. Just install the 2" AAL that comes with the kit and call it good. I also have a 2" AAL and no problems at all.
  10. May 13, 2011 at 12:46 PM
    thedude
    Lucas
    Little Rock, AR
    Thanks fella's. I have no bottom out issues but I haven't towed. The heaviest thing I will probably ever tow is a trailer with a 4 wheeler on it.
  11. May 13, 2011 at 1:53 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah you will be fine then. ;)
  12. May 13, 2011 at 1:59 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  13. May 13, 2011 at 7:33 PM
    thedude
    Lucas
    Little Rock, AR
    I'm not getting Dakar, just the Toytec AAL.
