OME advice
Discussion in 'Suspension' started by j cody, Jul 26, 2011.
  1. Jul 26, 2011 at 12:38 PM
    j cody
    j cody [OP] Member
    Cody
    Tennessee
    2011 Tacoma TRD 4x4
    Yakima LoadWarrior (with extension) basket rack
    I am about to order my OME lift kit and was wondering about the 885 vs 886 coils. I do want to put a front bumper on in the future and i know they suggest the 886 coils if you are going to do that, but do i really need them? Will it make the ride stiffer in any way?
  2. Jul 26, 2011 at 12:40 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    886's are taller and stiffer than 885's so they will definitely ride differently. The 886's are recommended for a heavy plate bumper with a winch. Do you know what kind of bumper you're planning on running and will it have a winch? Some manufactures make aluminum bumpers that offer the same protection with a fraction of the weight.
  3. Jul 26, 2011 at 12:40 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    If you are definitely putting on a steel bumper , and want 2 1/2 - 3" of front lift , I would get the 886's
  4. Jul 26, 2011 at 12:44 PM
    j cody
    j cody [OP] Member
    Cody
    Tennessee
    2011 Tacoma TRD 4x4
    i would probably try to find an aluminum bumper, but i will run a winch eventually. How much taller are the 886's? and im planning on running the Dakar Leaf Pack in the rear so would they be level?
  5. Jul 26, 2011 at 12:46 PM
    OZ-T
    Peter North
    British Columbia
    I got the 885's and Dakars for my DCLB .
    I am 2" higher in the rear than the front , but I did not add the top plate spacers for the full 3" up front , I got 2 1/2" .
    Look into the RelentlessFab aluminum bumper , it is winch capable and only weighs 55 lbs
  6. Jul 26, 2011 at 12:48 PM
    OZ-T
    Peter North
    British Columbia
  7. Jul 26, 2011 at 1:06 PM
    Pugga
    Massachusetts
    F-150 Mod
    886's are 656#/in 885's and the 884's are 588#/in. The 886's I believe are just under 10mm taller than the 885's but the big difference is the spring rate.
  8. Jul 26, 2011 at 1:06 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    With 886s the ride will be stiffer until you put the heavier bumper/winch on.
  9. Jul 26, 2011 at 1:08 PM
    j cody
    j cody [OP] Member
    Cody
    Tennessee
    2011 Tacoma TRD 4x4
    So your suggestion is getting the 886's might make the ride stiffer than i would want so i should go for the 885's and look for a light aluminum winch bumber? Very nice looking truck btw.
  10. Jul 26, 2011 at 1:11 PM
    Pugga
    Massachusetts
    F-150 Mod
    The 886's are designed for use with the ARB bumper and a winch. The ARB bumper is definitely on the heavier end of plate bumpers. If you're planning on running a 55 lb aluminum bumper then you might be better off with 885's and the top plate spacer. It'll ride a lot better before you get the bumper and still keep a lot of your lift once you do have all your armor on. If you do end up with a heavier plate bumper, you could always upgrade to 886's at that time.
  11. Jul 26, 2011 at 1:12 PM
    OZ-T
    Peter North
    British Columbia
    Those are the two ways of doing it .
    Steel bumper , get 886's
    No bumper or aluminum bumper , get 885's
  12. Jul 27, 2011 at 1:19 PM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    I have the 886's with the ARB bumper and winch. The ride is great in the front and there was some settling over a couple of weeks due to the weight. The rear end is a pretty stiff ride with no gear in the rear. You only really notice it over the bumps. 886's are a safe way to go if you plan on adding lots of weight in the front, otherwise definitely go for the softer ride 885's. Just remember that your 885's will sag more in the front if you go the heavy steel bumper/winch route!
  13. Oct 14, 2011 at 12:02 PM
    tburd83
    tburd83 Active Member
    Los Angeles
    TRD Off Road 4x4 6-manual
    With the 885's up front, and no top plate spacer, how much lift is usually achieved? I'm only looking for about two inches of functional lift. With this setup do you guys suggest replacing the UCA or can everything else stay stock. Also planing on adding the Dakar (light) leafs... I'm not planning on adding any extra weight anytime soon besides very occasional hauling/towing.
  14. Oct 14, 2011 at 12:17 PM
    OZ-T
    Peter North
    British Columbia
    885x coils , no spacer got me 2 1/2" up front on my DCLB 4x4
    The Dakars gained me 2 3/4"
    I added the LR UCA's
  15. Oct 14, 2011 at 12:22 PM
    Pugga
    Massachusetts
    F-150 Mod
    See above for your answer. At 2-1/2" you should think about getting new UCA's. You could go with 884's on your double cab and be closer to 2" of lift but I'd imagine the Dakar leaf pack will put you pretty high in the rear. At 2" you won't need new UCA's. Have you thought about Eibach coils also?
  16. Oct 14, 2011 at 12:22 PM
    Pugga
    Massachusetts
    F-150 Mod
    Dammit, you're too quick for me!
  17. Oct 14, 2011 at 4:04 PM
    Sprink669
    Sprink669 Well-Known Member
    I have OME 886's with a arb bumper, warn 8000#, dakar springs and 285's and the rear is way too stiff for my liking for normal driving but when you get some weight in the rear it is nice! I have a 12' trailer with 2 snowmobiles and I can't even tell it is back there that's when the ride is smooooooth!
  18. Oct 14, 2011 at 6:51 PM
    tburd83
    Los Angeles
    At Pugga, what size Eibach would be best to acheive a 2 in lift? I was also thinking about these with the 5100 and and Icon aal 1 1/2 inch. I think this might put more around where i want to be with some good function but not over 3 inches. At this point I'm not really ready change the UCA.
  19. Oct 14, 2011 at 6:52 PM
    tburd83
    Los Angeles
    sorry about the missing words and grammar in that last post. i'm still at work and I'm a little distracted...
