OME (Again)
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2002quad, Jan 31, 2012.
  1. Jan 31, 2012 at 8:12 PM
    2002quad
    2002quad [OP] Active Member
    I have a set up on my truck already just wondering if I should change the coils or not.......depending on what websight you go off of answers to this question vary.......I have OME 881's on the truck now, just bought a front tube bumper from Low Range Off Road. I plan on getting a warn VR8000-S so total weight up front will be roughly 120 pounds. Should I buy 882's or will the 881's be just fine? Thanks in advance guys and gals, sorry to add another OME question to the list.
  2. Jan 31, 2012 at 8:23 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    do you have a I4 or the V6?
    If you have a v6, you should probalby go for the 882's. If you have a 4 cyl the 881 may be okay.
    But, if i were you I would get the winch and see if your front end sags/see how it rides and then decide.
  3. Jan 31, 2012 at 9:03 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Why decide now? Since you already have the 881s run them and if they arent working well with the extra weight, buy the 882s then. No point in buying them yet if you already have 881s installed.
  4. Jan 31, 2012 at 9:43 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Good advice ^^!
  5. Jan 31, 2012 at 11:54 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yup yup....
    I had the 881 coils on my 96 (3.4L). I also had a TJM T15 front bumper that weighed 75lbs by itself without a winch. The 881's gave me 2" of lift with that bumper.
  6. Feb 1, 2012 at 6:16 PM
    blitzburgh99
    blitzburgh99 Well-Known Member
    Houston, TX
    1999 Tacoma TRD 4x4
    239,600 (as of 7-20-13 and counting)original owner miles
    What about the 883s with a Shrockworks bumper and warn xp9000 winch with steel cable? Would that work good?
  7. Feb 2, 2012 at 8:55 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    883s are quite heavy-duty (given that the 882s are beefy already), and are more than capable of holding that. I would also recommend the N91S shocks, since they are the stiffer variant.
    To the OP:
    just use the 881s until they sag too much for your liking, then upgrade. They worked fine on my old 4cyl truck with an ARB for over a year. Rebuilding shock/coil setups is a PITA...I don't really like spring clamps.
  8. Feb 2, 2012 at 10:18 AM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    I'd go with 882's...I'm sure ARB had some smart people developing their suspension system, and 883's are not designed for our trucks. 882's are designed for that weight, they will work. They are 20mm longer than 881's and the coil is thicker. Kurt Williams on expedition portal has an arb bumper, winch, dual batts, s/c, hot water shower etc up front and he's running 882's. If you need a lil extra lift you can add a small 10mm top plate spacer also, or a trim packer like Box Rocket.
  9. Mar 19, 2012 at 9:14 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Are you talking about the Rock Defense tube bumper?
