OME and bilstiens
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jm1hawk, Sep 26, 2010.
  1. Sep 26, 2010 at 8:44 PM
    Jm1hawk
    Jm1hawk [OP] Well-Known Member
    Jamie
    Irvine
    05 4x4 black
    OME885s MT 17 inch powdercoated rims BHLM 20% tint Alpine headunit Hifonics 1600 W mono amp 2 10" alpine type R subwoofers
    I am wondering if i can run my OME 885 coils with bilstien 5100s in the front. I would like to set the billys at .85 and remove my small spacer. Is this possible if so tell me if ur running it and if you got your allingment done with stock UCA
  2. Sep 27, 2010 at 12:05 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  3. Sep 27, 2010 at 5:58 PM
    Jm1hawk
    Jamie
    Irvine
    05 4x4 black
    So this will work?
  4. Sep 27, 2010 at 6:18 PM
    06ToyTaco
    06ToyTaco Well-Known Member
    CA
    06 4x4 DCLB Sr5 Silver
    OME 885X, 1.5" AAL + TSB, LR UCA
    Billes @ .85 + OME 885 coils: Yes. Having alignment in proper spec with 3" lift and 33" tires and OEM UCA is Iffy. Aftermarket UCA's are recommended to get alignment back into spec.
  5. Sep 27, 2010 at 9:51 PM
    Jm1hawk
    Jamie
    Irvine
    05 4x4 black
    thanks
  6. Sep 28, 2010 at 12:03 PM
    Jm1hawk
    Jamie
    Irvine
    05 4x4 black
    Is it a good idea to do? would it hinder off road performance and would be better with the top plate spacer and billys set at 0. or billys set at .85 with no top plate
