OME and Eiabach
Discussion in 'Suspension' started by EricU, Jul 5, 2015.
  1. Jul 5, 2015 at 3:36 PM
    EricU
    EricU [OP] Well-Known Member
    Englewood, CO
    i've seen a few threads asking about this combo, figured id give my opinion since this is what i have on my truck.
    the truck is an extended cab 4x4 2001
    the lift is OME 90004 struts, Toytec 112620 coils
    Out back i am running OME Dakar 46a/b springs and Toytec 1" shackle with bilstien A463 extended travel shocks (about 9.25 if i remember right)
    Removed the sway bar as well.
    The valving is awesome although it does have a fast rebound which id imagine is from the spring rate with no added weight up front, im sure it will slow down a tad once i get the bumper,skids,sliders,winch installed in a few months.
    i gained about 3.25" lift up front going off the fender measurement, maybe a bit more, who knows.
    i did have some vibrations between 60-70mph. i installed the toytec carrier bearing drop (a bit thicker than OME FK29) as well as the Diff drop at the same time, now i only have a slight vibration from out of balance tires.
    I do like that the OME shock shaft is Much thicker than a 5100, i have yet to go offroad with it as i have a few other things to work on still but will report back next week most likely with results
