OME axle shim confusion!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tbaytaco, Apr 12, 2012.
  1. Apr 12, 2012 at 2:21 PM
    Tbaytaco
    Tbaytaco [OP] Well-Known Member
    Nolan
    Thunder bay
    O6 TRD sport
    So I just received my complete OME lift kit from toytec, very pumped. But after taking everything out of the boxes I noticed something about the axle shims. Now I may just be confused but either I got the wrong shims or they are a new design. These dont seem to fit over the center pin, unless i completley remove the center pin and sandwich it in between. ANY help would be great!
  2. Apr 12, 2012 at 2:23 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Drill them out.
    EDIT: Nope. Wrong answer. See below.
  3. Apr 12, 2012 at 2:23 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You need centre pin collars to extend the pin so the axle shims will work , let me find you the thread
  4. Apr 12, 2012 at 2:24 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Literally out of the box and I need to drill them out? They look different than the others I have seen on TW
  5. Apr 12, 2012 at 2:25 PM
    OZ-T
    Peter North
    British Columbia
    Looks like they already have holes
    OP , do the heads of the centre pins fit through the shims ?
  6. Apr 12, 2012 at 2:26 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Negative, the center pin itself does, but the head doesnt, it can sit however in machined out groove on top... Hold a sec for pics
  7. Apr 12, 2012 at 2:28 PM
    OZ-T
    Peter North
    British Columbia
    Put a C clamp on the leaf pack , take out the centre pin and reinstall through the axle shim .
    The head needs to stick out below the shim to engage into the rear axle
    ETAV8R likes this.
  8. Apr 12, 2012 at 2:31 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    As you can see, I was sent extra center pins( not sure why). And you can see if they were installed within the leaf they would work, but dont fit over the bolt pin head.
  9. Apr 12, 2012 at 2:31 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If I recall correctly - when I tried to use the Toytec shims, I found as you have that the hole was too small so I needed to overdrill the existing hole in the shims for the larger pin assembly on the Dakar leaf pack.
    EDIT - NO - with replacement leaf pack pin provided, use it and add the shim to the leaf pack itself.
  10. Apr 12, 2012 at 2:31 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    maybe its just me but the shims look different then everyone elses
  11. Apr 12, 2012 at 2:32 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    ah I C
  12. Apr 12, 2012 at 2:32 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    I figured that would probably be the solution. Now to make sure I put them in the correct orientation. Thanks
  13. Apr 12, 2012 at 2:32 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Ah - but that replacement bolt pin head WILL fit in your spring perch right?
    Oz has the solution for you then. Listen to the Canadian. :)
  14. Apr 12, 2012 at 2:34 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Yah I guess the fellow canuck is right. Thanks . Ill be most definatly needing your OME install thread. Oh and did you install the carrier bearing drop?
  15. Apr 12, 2012 at 2:35 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Regular cabs don't have a carrier bearing at all.
  16. Apr 12, 2012 at 2:35 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Right... Newb here
  17. Apr 12, 2012 at 4:24 PM
    Tbaytaco
    Nolan
    Thunder bay
    O6 TRD sport
    Woah I was just looking at your OME DIY.. You have sway bar relocates?? do you need those with the OME. Mine kit didnt include them.
  18. Apr 12, 2012 at 8:12 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    They are an easy add later if it turns out the sway bar is hitting the spring perch.
  19. May 25, 2017 at 12:00 AM
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Kalifornia
    MGM 09 AC 4WD V6 TRD-OR w/ 2013 FWC Finch
    Grillcraft, Demello Sliders, Bilstein front and rear with OME coils and springs, Wheelers Bumpstops front and rear
    Gonna resurrect this thread.
    How is the shim working out for you?
