OME/Bilstein setup Question
Discussion in 'Suspension' started by =JSG=, Oct 13, 2011.
  1. Oct 13, 2011 at 10:25 AM
    =JSG=
    =JSG= [OP] Well-Known Member
    Canada
    2017 DC TRD OR 4x4 SB
    Morimoto 2 Stroke lows, Baja designs Squadron-R Sport as fogs, Method NVs
    I want a 2 inch lift all the way around, so far I have bought the 5100s. this is the setup I want:
    - Bilstein 5100 front/rear
    - OME 884 Coils
    - Toytec AAl (non TSB)
    According to Toytec:
    Any thoughts?
  2. Oct 13, 2011 at 10:56 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    The 5100s are a digressive valved shock whereas the OME's are progressive and that's prob what they are talking about. The eibachs are prob a better choice with that valving! At the .85 clip and eibachs you should be around 2.5"??
  3. Oct 13, 2011 at 6:05 PM
    =JSG=
    Canada
    excellent, TY
  4. Oct 14, 2011 at 7:30 PM
    =JSG=
    Canada
    One more question:
    These are the parts that I will have in 2 weeks:
    - Eibech Coils
    What else do I need? I will be going 2.5 all the way around.
  5. Oct 14, 2011 at 8:34 PM
    2011Tacoma1293
    2011Tacoma1293 Well-Known Member
    Kevin
    Florida
    11 Tacoma 4cyl Barcelona red
    you and i are on the same boat same questions and everything
  6. Oct 14, 2011 at 9:05 PM
    =JSG=
    Canada
    Diff drop kit? lol
  7. Oct 14, 2011 at 9:30 PM
    2011Tacoma1293
    Kevin
    Florida
    im getting the same setup
    - Eibech Coils
    - Toytec AAl
    and what is non tsb mean?
  8. Oct 15, 2011 at 6:41 PM
    Brianstemm
    Brianstemm GM Convert
    Bryan
    Key Largo
    '17 White TRD Offroad
    Zero
    Non TSB is a 2" AAL kit. TSB AAL will give you an 1.5". I'm hoping to get the same setup once I stop being so damn indecisive.....:goingcrazy:
  9. Oct 15, 2011 at 6:44 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    If your truck has a 3 leaf pack you DO NOT have the TSB...if it has 4 than you do!...TSB Trucks = 1.5" AAL....No TSB = 2" AAL :)
  10. Oct 15, 2011 at 6:44 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    no ;)
  11. Oct 15, 2011 at 7:45 PM
    LouTaco
    LouTaco Well-Known Member
    Lou
    Des Moines, Iowa
    2018 T4R SR5 Premium
    also a thing worth noting make sure you get the right rears i got the ones for 1.5" of lift and i needed the ones for 3-4" lift
  12. Oct 15, 2011 at 7:56 PM
    Fletcher007
    Fletcher007 Well-Known Member
    Fletch
    Phoenix,AZ
    17 Access cab 4x4 4cyl 5spd Magnetic Grey
    Fox 2.0 coilers, Fox 2.0 rear shocks, 17" 4Runner Trail Edition 7 spoke rims, 255/75 17 Yokohama All Terrains. Secondary air filter removed and AFE pro Dry S installed. Lower Air valance removed.
    i got the rar tsb and ome 885's up front on 5100's and i am 1 inch high in the back
  13. Oct 16, 2011 at 1:08 AM
    =JSG=
    Canada
    Hmmm, I thought I did because Toytec sells them with their 5100 kit
  14. Oct 16, 2011 at 8:09 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    They sell them but you shouldn't need them with that sized lift. It's used to keep your cv's at a good angle. You'll also need the 1/4" spacer on the drivers side for the taco lean!
