OME BP-51 current settings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kauhi, Jun 8, 2018.
  1. Jun 8, 2018 at 8:47 PM
    Kauhi
    Kauhi [OP] Well-Known Member
    Kauhi
    From Maui, Live in Portland OR
    2016 Tacoma 4x4 Off Road
    285/75/16 KO2, OME BP-51 3" Lift Kit, TRD Exhaust, TRD CAI, 30" Light Bar Grille, etc...
    With anyone with OME-BP-51 Loft Kit, what would be the best arrangement for compression and rebound and what be a good height, with not making much adjustments to the height so i can still drive it daily on the road.
    Current setup is "stock height" from install, but still feels a bit stiff.
    Plan on putting some armor and installing a canopy and RTT so jist want to make sure height and adjustments to added weight will be cherry.
    Appreciate any input.
  2. Jun 8, 2018 at 9:42 PM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    mine are set at factory, think it is 2 click on rebound and compression. Preload is at 28 I think, stock was too low with the arb bumper, winch and dual battery
  3. Jun 8, 2018 at 9:55 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
  4. Jun 8, 2018 at 10:00 PM
    reneg2k
    reneg2k Member
    Rene
    Durango, Colorado
    2014 TRD off-road
    CBI Moab 2.0 front aluminum bumper and sliders, 4x4 Innovation steel real bumper with bike carrier, baja roof rack, retrax pro, dual battery setup with ARB fridge, Wet Okole seat covers and Firestone Ride-rite air bags.
    tacoma double cab loaded permanently with around 500 lbs of armor plus fridge, second battery and mtn bikes. rear springs have 7 leaves
    coilover preload: 10 mm
    compression: 1-2 all around
    rebound: 4 all around
    it eats big holes as nobody's business but it is still rough on wash boards and street humps. the guys at the shop recommended lowering the reservoir pressure below 200 psi. They say it is too much pressure for such a little truck. I will be lowering preload in the front to 5 mm first since I only have 1.25 inches of drop right now.
