OME BP-51 Install Report and Height Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WILDPEAK, Feb 17, 2017.
  1. Dec 31, 2017 at 5:19 AM
    #201
    Hodakaguy
    Hodakaguy Well-Known Member
    12 Tacoma/Vagabond Drifter
    We just ordered two kits for my father and I’s 17 Tacoma’s. Can’t wait to get them installed :). Lots of great info and insight in this thread, thanks to all those contributing
    Hodakaguy
  2. Dec 31, 2017 at 7:17 AM
    #202
    r6realtor
    r6realtor Active Member
    Florida
    2017 Tacoma Sport 4x4 OME BP-51
    OME BP-51 full kit, total chaos spindle gussets, ecgs bearing, spc upper control arms, stainless steel extended brake lines, cab mount chop, SSO Hybrid front bumper, 9500# synthetic winch, allpro offroad frame sliders, vtx wheels, nitto trail grapplers, spod, ditch lights, hood scoop 10" led light bar, BAMF Grille
    absolutely love my kit!! I ended up doing rear extended brake lines, 1" front diff drop(until I get my bumper and winch mounted) as I left the preload at 20mm, total chaos spindle gussets and the ecgs bearing while it was all apart.
    The kit absolutely drives amazing 1 compression and 2 rebound I have mine set at for now and I can hit these trails at 40 mph(that's about as risky crash wise as I'd like to get, trees get really tight) and it just soaks up everything, the kids and wife just laugh the entire time we whip through the trails! rides amazing on the street as well! I would buy this kit over and over again!!
  3. Jan 1, 2018 at 1:01 PM
    #203
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    OK. I got everything installed a few days ago. I left the preload at the factory setting because I don't have a way to adjust it at home. I'm telling myself I'll correct it with bumpers/armor and a winch. :gossip:.
    So I started thinking about how the bypass shocks work. Ideally the truck should rest with the shaft of the shock at a particular position within the body and should be identical on both sides. This would give you the best ride on paved roads with both sides entering the different valving zones at the same time. So I imagine you'd use the preload to set the exposed length of the shafts. Then correct for any lean or ride height with spacers.
    Am I over thinking this?
    bigwill837 likes this.
  4. Jan 11, 2018 at 5:14 PM
    #204
    BenSando
    BenSando Well-Known Member
    2017 Silver DCSB OR
    95C264CB-F267-40BD-AA7A-C41D45C61163.jpg Here’s some pics for you guys. Bp-51’s with Dakar leaf pack, 1/4” spacer in the front to level with the back until I put a shell on. Icon delta joint uppers. 33x12.5r17 Nitro ridge grapplers on Stealth Ray 10’s. FEF74BBB-B007-494C-9843-5DA1B0A2A50E.jpg
    2C338250-B73A-4F61-87C3-6C418D43A092.jpg 7A39AE7C-89E0-4983-ADEA-79775D946201.jpg E452CE61-DE22-47AD-8B53-3E286FA88988.jpg
  5. Jan 12, 2018 at 8:50 AM
    #205
    Double Phister
    Sacramento, CA
    Did you bend the reservoir bracket outwards so it would sit outside of the rubber skirt?
    trd_overland likes this.
  6. Jan 12, 2018 at 10:13 PM
    #206
    trd_overland
    trd_overland Well-Known Member
    Dylan
    1904, CA
    2016 TRD Offroad 4x4
    IG: leonhvrdt
    I noticed that too. Mine sits inside the cover. BP-51 ftw!
    BenSando likes this.
  7. Jan 12, 2018 at 10:16 PM
    #207
    BenSando
    2017 Silver DCSB OR
    No I just stretched the rubber skirt a little lol.
  8. Jan 13, 2018 at 7:17 AM
    #208
    Hodakaguy
    Here's a easy way to adjust ride height! One of my favorite tools is a KTC Spring Compressor, I purchased this about 5 years ago and it's been awesome on numerous projects. This compressor is Very safe and easy to use, you'll never go back to anything else once you try it. Oh and this morning I tried it on the front BP-51 shock and it clears and works!, the cups just clear the shock body [​IMG] Will be nice not having to take it anywhere to make adjustments. Thought I'd share pictures of the tool for those who want a Very nice compressor!
    The unit comes with different cups for different size springs.
    Getting ready to try it on the BP-51....fingers crossed.
    And success! Just clears.
    Thought I would pass the info along.
    Hodakaguy
    bigwill837, yeos, CoachRed74 and 10 others like this.
  9. Jan 13, 2018 at 7:33 AM
    #209
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    That's awesome, thanks.
  10. Jan 13, 2018 at 7:34 AM
    #210
    r6realtor
    Florida
    Awesome info thank you! However I am more curious to see if you have the room to use this while the coilover is on the truck?? I really love the height of my truck right now and once the bumper finally comes in and I mount the winch it may or may not compress a little(we will see) and if so I want to raise the height back up just a bit, I spoke with arb tech support and he said that I could do that to regain the height he just wasn't sure if or how much it might effect the harshness of the ride.
  11. Jan 13, 2018 at 8:56 AM
    #211
    Hodakaguy
    It may or may not work on the truck...I'll report back once everything is installed :)
    Hodakaguy
  12. Jan 13, 2018 at 10:02 AM
    #212
    r6realtor
    Florida
    awesome thanks man!
  13. Jan 14, 2018 at 5:16 PM
    #213
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Any luck trying this compressor while the shocks are on the truck? I see a china copy of the ktc compressors you are using on Amazon for 80$ (looks identical, same factory?)would be a game changer if we could adjust on truck.
  14. Jan 19, 2018 at 6:14 PM
    #214
    Hodakaguy
    No dice adjusting with the shock on the truck, I tried it a couple nights ago. Shock will have to be removed for adjustment.
    Hodakaguy
    IronPeak[QUOTED] likes this.
  15. Jan 19, 2018 at 6:17 PM
    #215
    r6realtor
    Florida
    dang it man, wonder if taking the tire off would help make some room or just not gonna happen either way?
  16. Jan 19, 2018 at 6:19 PM
    #216
    Hodakaguy
    Nope...my tire and spindle is off the truck right now. Basically the shock tower interfears with the spring compressor....just not enough space with it on the truck. Luckily adjustments shouldn't be something one has to do often.
    Hodakaguy
  17. Jan 19, 2018 at 6:28 PM
    #217
    r6realtor
    Florida
    bummer, definitely appreciate the feedback
  18. Jan 19, 2018 at 6:30 PM
    #218
    Hodakaguy
    No Problem, Glad I could help.
    Hodakaguy
  19. Feb 8, 2018 at 3:08 PM
    #219
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
  20. Feb 10, 2018 at 4:06 PM
    #220
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    You might be able to get away with running that compressor while still on the car. What do you think?
