OME BP-51 Install Report and Height Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WILDPEAK, Feb 17, 2017.
  1. Apr 6, 2018 at 6:06 AM
    #241
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    If you remove the link no over load it doesn't affect the capacity. Removing 3rd leaf from the top reduces capacity by 15%.
  2. Apr 6, 2018 at 6:29 AM
    #242
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    How does removing those two effect the amount of lift?
  3. Apr 6, 2018 at 7:27 AM
    #243
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Removing overload you drop .5" removing 3rd leaf is also about.5" but more dependent on the weight of your truck.
  4. Apr 7, 2018 at 5:45 AM
    #244
    roth_nj
    So if arb says to do the 10mm to match the full dakar pack with no load on the front, I'm guessing to go down to 0 if i remove the overload spring?
  5. Apr 11, 2018 at 7:48 AM
    #245
    KingdomKid
    KingdomKid Member
    Kyle
    2017 TRD Off Road Access Cab V6
    Hello all! I just got my BP-51 kit installed yesterday...its sweet. Its been a long process that started out by getting my rear bumper smashed last october. My CBI rear swing is on order and should be ready in a couple weeks. I did this kit to account for the weight that would come from that, my Leer topper, and eventually a RTT... (as well as front bumper...electronics...all things that are on the "list.) But I was hoping to keep my stock wheels as I have already paid for them and try and fit 285/75r16 Tires. It seems like I am going to have issues rubbing with my stock UCA right off the bat. Any thoughts or suggestions?
  6. Apr 11, 2018 at 7:57 AM
    #246
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Get aftermarket UCA's you may need them anyway.
  7. Apr 13, 2018 at 1:17 AM
    #247
    BenSando
    BenSando Well-Known Member
    2017 Silver DCSB OR
    My truck sat about 3/4” higher in the rear at 20mm preload and stock weight with the Dakar leafs.
  8. Apr 15, 2018 at 5:20 PM
    #248
    roth_nj
    What's the life span for the bp-51s look like?
    What's the rebuild process entail?
    trd_overland likes this.
  9. Apr 17, 2018 at 11:56 AM
    #249
    2016 Access in White
    2016 Access in White Well-Known Member
    2016 TRDOR Access
    Stupid question ... Is the rebound/compression adjustment only for the rear shocks and not the fronts? Close up pictures do not show the two adjusters for the fronts on the shock body or the reservoirs. My new fronts show up this week. I've followed this thread for some time so apologies if I missed it above.
  10. Apr 17, 2018 at 1:36 PM
    #250
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Bottom of the shock, inside the spring.
  11. Apr 17, 2018 at 3:34 PM
    #251
    2016 TRDOR Access
    Hard to see even in the ARB catalog but it's there! Thanks
  12. Apr 17, 2018 at 7:54 PM
    #252
    Dissent86
    Dissent86 Well-Known Member
    Ben
    2016 trd offroad Tacoma.
    Both my fronts started leaking just under 30k miles, Arb replaced both. I was unpleasantly surprised to find out that they have shortened the fronts by about 3/16" doesn't sound like much but this limited the wheel travel by about 3/4" which led to extremely harsh top outs. I was able to gain that back by lowering the preload and adding a spacer. Not sure why they shortened them but I wish they didn't.
    Arb USA didn't even know about the change and said it happens often, the manufacturer changes a product and doesn't let them know about the change
  13. Apr 18, 2018 at 6:44 AM
    #253
    2016 TRDOR Access
    Knowing what you now know...would you buy them again? If not, what would you consider as a suitable alternative?
  14. Apr 18, 2018 at 7:15 AM
    #254
    Dissent86
    Ben
    If they didn't shorten them I would in a heartbeat, but now that they are shorter probably not. I will most likely go icon extended travel.
    I'm assuming they shortened them do to possible over extending the factory upper control arm as they advertise they are compatible.
  15. Apr 18, 2018 at 11:07 AM
    #255
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    Is there a way to tell if someone has the shorter ones? Different part number?
  16. Apr 18, 2018 at 6:12 PM
    #256
    roth_nj
    How long are they supposed to last? I found that the foxes are supposed to be 50k, but couldn't find anything on the bp-51s. Figured ARB has a number since they replaced yours at 30k
  17. Apr 19, 2018 at 7:43 AM
    #257
    Dissent86
    Ben
    Nope, same part number. I know off the build date from the sn the ones built in 16 were the longer ones and the ones in 17 were shorter.
  18. Apr 19, 2018 at 7:44 AM
    #258
    Dissent86
    Ben
    I believe the warranty is 3 year 30k miles
  19. Apr 19, 2018 at 7:53 AM
    #259
    Double Phister
    Sacramento, CA
    I hate it when companies do that. There should be a different part number or a rev to easily identify products that have changes. I'd hate to have a mismatched set if you were cobbling a kit together from different sources or needed to just replace one.
  20. Apr 19, 2018 at 8:53 AM
    #260
    roth_nj
    so mine have shipped...
    im planing on removing the overload leaf in the rear, netting about 2-2.25" of lift
    i would like to equal this amount of lift up front. i have no additional weight and dont plan to add any anytime soon.
    Should i adjust the fronts to 0 or 5 mm?
