OME BP-51 Install Report and Height Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WILDPEAK, Feb 17, 2017.
  1. Mar 1, 2019 at 6:34 AM
    #401
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    @Nitori the reservoir has to clear the bump stop mounts that are rivited on. ( see pics) I think that’s why it appears angled in picture. If it is truly angled it’s not much. Sorry to much snow and to frickin cold to crawl under and measure things at this time.
  2. Mar 1, 2019 at 8:11 AM
    #402
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I meant if the reservoir is parallel to the frame, or if the reservoir would contact the frame if you could magically make it longer.
    Haha no worries man I appreciate all you’re doing. I may just have to fabricate my own mounts but this has been a huge help!
    -40[QUOTED] likes this.
  3. Mar 2, 2019 at 2:55 PM
    #403
    4X42HEL
    4X42HEL Well-Known Member
    San Diego
    2019 DCSB TRD-OR 4x4
    No added weight at the moment. Eventually want to add sliders.
    Just set the preload to 10mm/13mm. Will try to install kit next week.
  4. Mar 2, 2019 at 7:02 PM
    #404
    Gat_
    Gat_ Don’t be shattered.
    Bay Area, CA
    '19 Cement Tacoma TRD OR M/T
    Sounds good. Looking forward to photos.
  5. Apr 9, 2019 at 6:12 AM
    #405
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    Hey friends I'mbI'm lea towards the bp51 kit but have heard alot of shops tell me that the oil is thick and they won't do we'll iin the cold. I do mild off roading here in Utah ripping down washboard roads and occasional overlanding trip. Nothin too crazy but want something quality that lasts a while. What are your long term opinions so far on this vs icons or fox for those who have run those other kits?
  6. Apr 12, 2019 at 5:13 AM
    #406
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    I installed mine last spring. I didn’t notice much of a difference at all through the summer and through this past winter.
  7. Apr 12, 2019 at 5:15 AM
    #407
    roth_nj
    So I’ve asked about the rear end before and these shocks.
    What is the lift amount that they are designed for before you have issues? With my soft Dakar’s, I am at 2 inches of lift with no weight in the bed. I want to get another 1/2 inch or inch back there somehow.
    I have 31s on now but plan on putting on 33s this summer
  8. Apr 12, 2019 at 8:52 PM
    #408
    topaza
    topaza Well-Known Member
    2013 Black ACLB 4x4 V6
    I'm at 4" of lift in the rear at the moment with Heavy Dakars and only a shell. I'm adding rear bumper soon, but they ride great now.
  9. Apr 13, 2019 at 7:29 AM
    #409
    roth_nj
    Ok, so right now I have the front set at 5mm with no extras, the soft Dakar pack, and 31 inch tires. I got between 2-2.25 inches of lift all around
    I just ordered the sso front bumper and plan on putting on 33s this summer.
    I want to go up to 2.5-3 inches of lift. Easy to adjust up front.
    What can I do with the rear end?
  10. Apr 13, 2019 at 12:22 PM
    #410
    Gnarman
    Southwest
    So quick question, difference between bp51 at 2.0 and fox 2.5s, watched a video saying these shocks are not the same as a true bypass shock?
  11. Apr 13, 2019 at 12:42 PM
    #411
    Gnarman
    Southwest
  12. Apr 13, 2019 at 4:21 PM
    #412
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    IBP are a bit different to EBP but I think Bens point is that it’s not a true 2.5 shock. So while it used a 2.5 shock body it still uses a 2.0 piston.
    While a King 2.5 IBP still uses a 2.5 piston.
  13. Apr 13, 2019 at 5:28 PM
    #413
    Gnarman
    Southwest
    Copy that are you still happy with your purchase really leaning towards these as the arb people have been awesome and the deal at headstrong looks great. I also like the adjustability in the shock as well.
    Would this shock perform the same as a fox 2.5?
  14. Apr 13, 2019 at 7:11 PM
    #414
    JoeCOVA
    Joe
    Colorado Springs
    I actually went with King 2.5s because they are a better overall shock and were cheaper.
    As far as performance, a 2.5 will perform better but it depends on your use.
  15. Apr 13, 2019 at 8:01 PM
    #415
    Gnarman
    Southwest
    Thanks Joe, looking at something that will ride betterbet the street be able to handle our bed tent and shell and be able to take me down to moab and drive on some of the crappy back roads faster and smoother. Headstrong mentioned possibly looking at the fox level 2 kit with Dakar and extended length shocks as a good alternative.
  16. Apr 13, 2019 at 8:37 PM
    #416
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    You do not want the BP51s if you are looking for a better ride on the street. They do however perform awesome off road.
  17. Apr 15, 2019 at 10:17 AM
    #417
    roth_nj
    none on this one?
    dakar add a leaf el46xl?
    spec is for 15mm of lift (.6 inches) seems right where i want to be?
  18. Apr 17, 2019 at 2:43 AM
    #418
    roth_nj
    Did you extend your brake lines?
  19. Apr 25, 2019 at 7:01 AM
    #419
    bigwill837
    bigwill837 Well-Known Member
    Will
    Austin, TX
    1996 HZJ75 Land Cruiser Pickup
    Has anyone had issues with this setup topping out or “clunking”?
  20. Apr 25, 2019 at 7:09 AM
    #420
    roth_nj
    It was talked about a little bit earlier in this thread as a result of too much preload.
    They originally came set at 20mm, but it appears arb is shipping them set at 0 or 5 now to address that issue
