OME BP-51 Install Report and Height Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WILDPEAK, Feb 17, 2017.
  1. Mar 16, 2017 at 1:06 PM
    #61
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    6 hours should be plenty - 2 hours for the front , 4 for the back
  2. Mar 16, 2017 at 1:07 PM
    #62
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    I did mine with uca's as well in 5.5 hours. Had help, but didn't have a lift so draw your own conclusions.
  3. Mar 17, 2017 at 9:21 AM
    #63
    DarthMinnow
    DarthMinnow Well-Known Member
    '16 Tacoma TRD Sport 4x4 AT
    I had a master tech at my toyota dealership install the lift ( without Total Chaos UCA at the time) and a new set of rims/tires with an alignment in 5-6 hours. If you are installing the lift be sure to immediately do an alignment right after or your truck could drive wacky/ wear your tires badly.
  4. Mar 17, 2017 at 11:10 AM
    #64
    Korndog1284
    Korndog1284 Well-Known Member
    J03l
    Washington
    2016 Off Road DCLB MGM
    All-Pro Raack Pack, Tepui Tent and Awning, ARB BP-51, K02 275/65/17, 4Runner Pro Wheels
    Yea for sure, Another reason that I'm trying to estimate my time is so I can schedule the 4 wheel alignment on the same day as the lift install. It seems that 4wp closes at 3pm on Saturday, I will need to find another place to get my wheels aligned near the shop. All of this additional work to try and save a buck... well at least 900 of them!
  5. Mar 17, 2017 at 12:50 PM
    #65
    Clay7160
    Driving one or two days is not bad before getting an alignment, will help suspension settle a bit also
    Juforrest likes this.
  6. Mar 17, 2017 at 12:54 PM
    #66
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    exactly, it's not a dire need thing. just get it done before any fast highway driving and within lets say 50 miles.
  7. Mar 17, 2017 at 12:55 PM
    #67
    DarthMinnow
    Not bad?!?! He is removing the stock UCA and replacing with aftermarket ones. The alignment can be so out of wack from the install it could be dangerous for him to drive any sort of distance.
  8. Mar 17, 2017 at 12:58 PM
    #68
    whitedlite
    USA!
    3RD Gen TRD 4WD
    how so? give me an example, not just your assumptions.
    wirenut likes this.
  9. Mar 17, 2017 at 1:21 PM
    #69
    Korndog1284
    J03l
    Washington
    I'm having some difficulty finding an alignment shop that is open after 3-4pm on a Saturday in the Redmond Washington area. Is it actually safe to drive with bad wheel alignment? I will have like a 30-40 minute drive home if I keep to the streets. But I don't want to do anything that will compromise my safety or my $40k truck or my lift kit... Thanks!
  10. Mar 17, 2017 at 1:23 PM
    #70
    whitedlite
    USA!
    3RD Gen TRD 4WD
    it won't ride well, but if you check torques of all bolts and such you should be fine.. yeah you'll get excess tire wear, but it's not like your 45 minute drive home is going to be noticeable in the lifetime of the tires.
    edit: just use good judgement and drive your truck like a granny.
  11. Mar 17, 2017 at 1:27 PM
    #71
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I installed mine at a friends in Puyallup then drove home to Shoreline. If you dont fuck with the lower control arms the only thing that will be way out is camber. With a properly installed lift and uca's you will be just fine.
  12. Mar 17, 2017 at 1:30 PM
    #72
    Korndog1284
    J03l
    Washington
    Ok, Will I might do the work on Saturday, drive home like a granny, Go to work Monday and get the alignment Monday night! Thanks Guys
    whitedlite likes this.
  13. Mar 17, 2017 at 1:59 PM
    #73
    Clay7160
    Light racing gives suggestions for caster settings in their install instructions, you can adjust camber by putting a straight edge on the wheel/tire and using a angle finder to get as close to 0 degrees as possible, then if you want to go further if you measure the front and back of tires, you can adjust toe by making the measurement the same. Like others have mentioned, making sure everything is tightened the truck will be fine, if it is out of alignment, it may not ride as great, but will be fine until he makes an appointment. In all the cars / trucks that i lifted and lowered, i have only had 1 that was almost un-drivable due to the toe being so badly out of alignment, both tires almost pointed 90 degrees facing the outside the vehicle.
  14. Mar 30, 2017 at 10:23 AM
    #74
    Korndog1284
    J03l
    Washington
    For those of you that have installed the BP-51's did you keep the pre-load adjustment the same for the fronts? I saw one comment that mentioned like a 2mm difference I assume to compensate for the Taco Lean.
  15. Mar 30, 2017 at 11:25 AM
    #75
    Clay7160
    That would work or doing the spacer on top also would work fine
  16. Mar 30, 2017 at 11:26 AM
    #76
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    No need for spacer with adjustable coilovers
  17. Mar 30, 2017 at 12:39 PM
    #77
    Clay7160
    The BP 51 coilovers have to be adjusted off the truck which means dismantling the suspension. Much easier to adjust the coil overs even and putting on the truck with the spacer
  18. Mar 30, 2017 at 2:05 PM
    #78
    DarthMinnow
    I didn't touch the pre-load at all for the front. Don't really notice any taco lean at all.
    JoeCOVA likes this.
  19. Mar 30, 2017 at 2:32 PM
    #79
    Korndog1284
    J03l
    Washington
    My plan is to adjust the coilovers before mounting them on the truck. I have access to a wall mounted strut compressor so this should be fairly easy. Once I buy/receive a new front bumper I will need to remove the coilovers and readjust the preload. Until then I would prefer to drive the truck properly adjusted for the current configuration.
    Do you have additional weight on the font? Hows the ride quality?
    wodahs and Clay7160[QUOTED] like this.
  20. Mar 30, 2017 at 3:31 PM
    #80
    DarthMinnow
    Yes, I have a 170 pound ARB front summit bumper. Mobtown steel front skid plate which is about 40 pounds. Also Mobtown bolt on sliders. The sliders helped the most with ride quality. When I get a cap/rear bumper the ride should be way better. It rides a little rough with no weight in the back because of the extra leaf in the dakars. When you put weight in the bed it rides really smooth. Offroad it rides like a champ, couldn't be happier. Absorbs pot holes and big bumps really well.
