OME BP-51 Install Report and Height Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WILDPEAK, Feb 17, 2017.
  1. Nov 13, 2020 at 6:42 AM
    #781
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    FAT! I totally regret the side-by-side config just due to the weight on the sheet metal there. But i'll live with it for now. My bitch is heavy
  2. Nov 16, 2020 at 1:51 PM
    #782
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    I just experienced this for the first time wheeling this past weekend, Everyone near my truck when I was going over rocks was like "Dude one of your rear shocks is leaking"
    @SR-71A You called it correctly!
    SR-71A likes this.
  3. Nov 17, 2020 at 6:45 AM
    #783
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    :cheers:
    ME OFF Rd[QUOTED] likes this.
  4. Nov 17, 2020 at 6:49 AM
    #784
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Good to know its not your shocks. Its odd that it just started happening on that trip. You have definitely been flexed out that much before
  5. Nov 17, 2020 at 7:01 AM
    #785
    WreckedRooster
    WreckedRooster Well-Known Member
    Jake
    Oklahoma
    2020 MGM DCSB
    I thought people were experiencing topping out issues with no weight and a 20mm setup?
  6. Nov 18, 2020 at 6:20 AM
    #786
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    No weight... maybe... Im just shy of 30mm range and im good. Truck has been been everywhere from the Rubicon to fast Nevada dirt trails... daily driven... solid. Springs are definitely stiffer than stock so those who are running no weight are probably confusing the stiff ride with "topping out" or maybe they need to adjust the rebound? Who knows.
  7. Nov 25, 2020 at 3:09 PM
    #787
    TACOCAT Reversed
    TACOCAT Reversed Yum Yum Yum Yum Yum!!! - Cookie Monster
    NCentral Florida
    2018 Cement TRD OR
    Roll'N'Lock SEMA TRD Pro Rims General Grabber AT2 OME BP-51 Suspension Heavy Duty Dakar Leaf SPC UCA's CBI Fab Bolt on Sliders SSO slimline hybrid bumper Smittybuilt X20 Synthetic Winch Factor 55 Prolink 30" Baja Designs S8 Baja Designs SAE Fogs TRD Pro Grille Front and Rear Anytime Camera Expedition Essentials TPAM Meso Puddle lights Meso Ultimate Red LED dome Meso RED map lights Rear differential breather mod AC drain mod Oodles O Dynamat
    This stuff:
    Energy Suspension 9.11104 8 Oz Tub Of Lubricant
    on Amazon, along with the cheapest 1 inch brush at Home Depot. Pry apart springs with flat head screw driver and liberally coat everything that might touch. Wear disposable gloves. Works great. Would recommend the big tub rather than the little packets. Or get new leaf pack....o_O:notsure:
  8. Nov 25, 2020 at 4:52 PM
    #788
    SR-71A
    Zack
    Southern Maine
    I do that with regular grease. Use a flat blade screwdriver to dab it in between the end of the leafs where most of the movement is
  9. Dec 16, 2020 at 5:32 PM
    #789
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    Installed replacement leaf pack medium load. Preload at 13 driver 12 passenger with a 1/2 in spacer driver and 1/4 passenger. Switched from 255/85 to 265/75 again. Rides way better so far.
  10. Dec 16, 2020 at 5:45 PM
    #790
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    How do you determine whether you have the old leaf pack opposed to the new replacement?
  11. Dec 17, 2020 at 10:19 AM
    #791
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    I received the new leaf pack from ARB, but haven't installed it yet. Liking the new one, huh? Notice any difference in ride height or quality (stiffer, more plush)?
  12. Dec 17, 2020 at 10:20 AM
    #792
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    There should be a part number on the spring in large yellow letters/numbers.
  13. Dec 17, 2020 at 10:41 AM
    #793
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    I finally got my preload adjusted to 30mm drivers and 27mm passenger
    i'm also using a 1/4" spacer drivers side.
    I like to drive fast (who doesn't?) and when i hit a good little dip, my front drivers side sounds like it rubs the inner wheel well up top. I can't tell if it's my tire or UCA (I'd assume my tire).
    I have the compression maxed drivers side.
    What now, bumpstops?
    Edit: I guess it's important to note - i have full steel skid package, sliders, front bumper, winch, and dual AGM's. She's a whale
  14. Dec 17, 2020 at 12:02 PM
    #794
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Is it a small drop off and you are topping out, or a small bump and you are bottoming out?
  15. Dec 17, 2020 at 12:30 PM
    #795
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    it usually happens when i hit a dip. The front drivers compresses all the way to the wheel well liner, then back out.
  16. Dec 17, 2020 at 6:01 PM
    #796
    Gnarman
    Southwest
    so far it rides much better. I also added the el05 spacer on the rear pack to level it out. My wife drove the truck today and said it was night and day to her. I have e load tires again but where we live we need to have it to be honest.
  17. Dec 17, 2020 at 7:07 PM
    #797
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    whats the EL05 spacer? Tried searching for it but didn’t come up with anything.
  18. Dec 17, 2020 at 7:11 PM
    #798
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Hmmm... I’m running 285’s at 15mm preload with steel bumper, winch, skids, sliders and never bottom out like that. I do have durabump bump stops.
  19. Dec 18, 2020 at 3:14 AM
    #799
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Sorry meant 1/4" spacer. Fat fingers, small phone lol
  20. Dec 18, 2020 at 7:57 AM
    #800
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    That question was for @Gnarman , you're good. Not sure what 's causing your issue. If you have compression maxed, it shouldn't bottom out, I would think.
