OME BP-51 Install Report and Height Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WILDPEAK, Feb 17, 2017.
  1. Nov 30, 2021 at 1:50 PM
    #861
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    That is everything right now.
    I'm in distribution and things that normally took 5 weeks to ship are now 16-24 weeks out.
    Something's like electronic components that used to take 5 weeks aren't shipping til late next year.
    And huuuuge steel surcharges.
    Thanks China!
    o313 and HelloFelix[QUOTED] like this.
  2. Nov 30, 2021 at 3:45 PM
    #862
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Please tell us more about the UCA warranty?
    I should clarify, interested in the failure he had.
  3. Nov 30, 2021 at 4:35 PM
    #863
    Jose_Dirte
    Joey
    Green Acres, CO
    I have them and they're 3 years as well.
  4. Nov 30, 2021 at 5:24 PM
    #864
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    Rubber Bushing separated from the control arm . Less than a year old.
    o313 likes this.
  5. Feb 15, 2022 at 2:28 PM
    #865
    Grape_Salad
    Grape_Salad Active Member
    Oak Harbor
    2021 DCSB TRD OFFROAD ARMY GREEN
    BP-51, Cali Raised Sliders, Safari AIRMAX, UPTOP Alpha
    The answer is yes you should do a diff drop.
  6. Feb 17, 2022 at 6:48 PM
    #866
    Lando883
    Lando883 Well-Known Member
    Lando
    SoCal
    2021 Tacoma TRD OR
    Hey OP and all. What do y’all recommend for preset settings for not armor in front, just TRD skid. 10mm?
    plan to install 285/75/16 KO2s on the stock rims. Looking for 2.5inch lift in the front. I got the medium leaf spring set from OME.
    Thank you!
  7. Feb 17, 2022 at 8:55 PM
    #867
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    Id get the replacements and sell them. Ive been so happy with my dirt kings since switching
    HelloFelix[QUOTED] likes this.
  8. Feb 17, 2022 at 9:04 PM
    #868
    HelloFelix
    Felix
    Las Vegas
    Going on 5 months
  9. Feb 18, 2022 at 9:39 PM
    #869
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    picked up a barely used set of BP-51 coilovers and while I had was able to install them pretty easily I would like to know what the official instructions are from ARB.
    Just to make sure I did everything 100%.
    Anyone have a link, pdf, or barely legible blurry cell phone pic??
    Having to drill the lower rear shock mount bracket makes me feel like I'm missing something :/
  10. Feb 18, 2022 at 11:07 PM
    #870
    Evan_P
    Evan_P Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    This should cover it.
    N minus 1[QUOTED] likes this.
  11. Feb 19, 2022 at 7:39 AM
    #871
    N minus 1
    San Diego, CA
    2014 TRD Off Road
  12. Feb 19, 2022 at 7:49 AM
    #872
    Evan_P
    Evan
    Hillsboro OR
    No problem. Good luck on your install.
  13. Mar 30, 2022 at 5:21 PM
    #873
    Fallout76
    Fallout76 New Member
    I've done an plethora of reading and still unsure about the answer to my question.
    If I only have a skid plate in the front and nothing else, can I get away with 15-20mm of preload without damaging anything else? ARB is telling me it will ride rough, which I don't care about. My local off road shop is telling me it could cause a leak and void my warranty which I don't want. Right now it is at 5mm preload and the rake on my truck is gross. measured from hub center, rear: 24.5" front: 22". I want to level out my truck but I'm torn at how to take the information. I dont do serious off-roading my any means. Its more of a mud pony than anything.
  14. Mar 30, 2022 at 5:49 PM
    #874
    o313
    N
    2018 DCLB AT SC
    Cause a leak? like from topping out too hard?
    Maybe start with 15mm and see what you think.
  15. Mar 30, 2022 at 6:15 PM
    #875
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    Based on your post above (not alot of off roading)
    I'd say your best is to keep the preload at what ARB recommends (~10mm) and add top plate spacers. Super simple to install and you can find tune the ride height.
    Some people will give you sh** for it but it is a perfectly safe and acceptable method to gain ride height. Just don't go crazy (3+" spacers)
    I HIGHLY recommend watching this guy's videos. Best explanation Iv herd and he debunks some of the myths that alot of us believed without actually testing it.
    https://youtube.com/c/TinkerersAdventure
    Fallout76[QUOTED] likes this.
  16. Mar 30, 2022 at 6:46 PM
    #876
    Fallout76
    Thanks for the video reccomendation I will check them out. I was curious about a 1 in top spacer, but wouldn't that mess with my CV linkage? I havent really read into the pros and cons of top spacers.
  17. Mar 30, 2022 at 7:09 PM
    #877
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    The over all ride height is what is important. In my opinion the CV joint (and UCA) can handle a 0-2.5" with no issues. A 1" lift from spring pre load and a 1" inch lift from a top plate spacer is the same if only considering ride height. You will however be altering your down and up travel which will not affect anything provided you are not doing any heavy off roading.
  18. Apr 4, 2022 at 9:54 AM
    #878
    o313
    N
    2018 DCLB AT SC
    Went to install my BP-51's and the preload is set to 5mm out of the box VS the 20mm it says its supposed to be. This lack of attention to detail makes any reasonable person think "did they miss other things like seals, clips, bushings, internal torque specs, etc..." Not the best start to the $$$ OME upgrade. The official ARB dealer is incapable of adjusting the coil overs o_O???
    ARB customer service says "use most any old spring compressor claw style and its not too hard"
  19. Apr 4, 2022 at 9:56 AM
    #879
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    They changed the factory preload a while back but not the documentation. Mine were also set at 5mm preload out of the box.
  20. Apr 4, 2022 at 10:02 AM
    #880
    o313
    N
    2018 DCLB AT SC
    Where did you end up with the preload and what if any bling are you running?
    I've got a Dual Comp, 90lbs of steel skids, and the SuperCharger so I'm thinking 10mm?
