OME BP-51 Install Report and Height Adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WILDPEAK, Feb 17, 2017.
  1. Apr 12, 2017 at 10:27 PM
    #101
    DarthMinnow
    DarthMinnow Well-Known Member
    '16 Tacoma TRD Sport 4x4 AT
    You only need to do an alignment after working on suspension components. Adding weight does not affect alignment much at all. I installed heavy rock sliders and skid plate after I had done the alignment with suspension install. Haven't had any problems.
  2. Apr 13, 2017 at 7:42 AM
    #102
    gearguy911
    gearguy911 Well-Known Member
    Boulder, CO
    2016 Magnetic Grey Tacoma TRD OR DCLB
    Awesome, thanks for confirming!
  3. Apr 25, 2017 at 2:58 PM
    #103
    robbins
    robbins Active Member
    I haven't brought my truck in yet to have it adjusted because I'm not quite sure what to have done. I did a quick measurement between the top of the rim and the wheel well and the right side was about .5" higher than the left side. I also checked with a leveler and it was spot on. I guess it's not an actual lean I'm feeling. What I am feeling is the front right side of the suspension feeling softer than the left. Do I possibly have a bad shock on the front right? I have compression set to zero on the front and the back and the rebound set to half way on the rear and a bit over that on the front. Any ideas?
  4. Apr 25, 2017 at 3:15 PM
    #104
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    You don't have to be at the same settings from side to side. Adjust the one that feels softer see if it makes a difference.
    WILDPEAK[OP] likes this.
  5. Apr 25, 2017 at 5:16 PM
    #105
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    This is why I buy my suspension last after I have everything else so I know exactly what I need.
    WILDPEAK[OP] and RedBeard1 like this.
  6. Apr 26, 2017 at 5:13 PM
    #106
    robbins
    Yeah, I saw people had different preload between the right and left sides which makes sense. I'm going to remeasure with more precision to see where everything is at because it sounds like I need to add a bit of preload or a spacer to stiffen up the right side. I worry adding 2mm of preload will make the right side ride higher than the left side.
  7. Apr 26, 2017 at 5:27 PM
    #107
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I would just turn the compression up on the right side first. My truck is somewhat the opposite of yours. Felt softer on the left side. I turned the comp up 1 bar higher than the right feels about equal now.
  8. Apr 26, 2017 at 7:01 PM
    #108
    robbins
    Cool. I'll try that first. Thanks man.
  9. May 2, 2017 at 11:30 PM
    #109
    WILDPEAK
    WILDPEAK [OP] Well-Known Member
    Drew
    Rancho Cucamonga, CA
    '16 TRD OFF-ROAD
    LT265/75R16 WILDPEAK AT3W
    When you install the reservoirs, you can twist them and slide them back and forth in the clamps before tightening to find the optimal spot to avoid any rubbing- I don't have any "kinks" in the lines at all. Once the reservoirs are clamped, nothing really moves in that area besides the vertical movement of the control arms, so that is really the only concern.
    Clay7160[QUOTED] likes this.
  10. May 2, 2017 at 11:31 PM
    #110
    WILDPEAK
    Drew
    '16 TRD OFF-ROAD
    Agree, if you see my latest edit to the initial post, the BajaKits UCA's that I'm using aligned the truck perfectly. No need for LCA's unless going mid-travel setup.
  11. May 2, 2017 at 11:37 PM
    #111
    WILDPEAK
    Drew
    '16 TRD OFF-ROAD
    Tell Firestone to first move the LCA cams so that the LCA's extend outward away from the truck to get the Camber to 0deg, then adjust the toe to ~0deg then Caster should fall out depending on which UCA's you have. Using this method my final specs came out nicely:
    Of course I'm the tire guy so I'm always looking for perfect Camber/Toe to ensure proper tire wear :)
  12. May 2, 2017 at 11:40 PM
    #112
    WILDPEAK
    Drew
    '16 TRD OFF-ROAD
    New pics in updates are LT265/70R17LRE WILDPEAK AT3Ws on TRD Wheels.
    Here she sits with OME BP-51 set at 21mm Passenger /26mm Driver with 1/4" top plate spacer, and D29XL extra leaf to the Dakar pack.
    Cheers.
  13. May 2, 2017 at 11:45 PM
    #113
    WILDPEAK
    Drew
    '16 TRD OFF-ROAD
    I got about 0.75" lift from the D29XL. Went from 23.75 to 24.5 wheel center to flare (with camper shell, etc).
  14. May 2, 2017 at 11:55 PM
    #114
    WILDPEAK
    Drew
    '16 TRD OFF-ROAD
    The rear BP-51's are 625mm extended versus the stock TRD Off-Road OE Bilstiens at ~583mm, so the BP-51's are definitely longer. In fact I found that the rear brake lines need to be longer with this kit at full droop to avoid a tight bend in the lines (not sure they would actually stretch), or you can simply un-bolt the rear brake line bracket and add a small spacer as I did (any most installers do) to alleviate any issues.
    Basically you are correct, the shocks are longer, and plenty strong enough to limit the down travel as with most leaf sprung suspensions.
  15. May 3, 2017 at 1:03 AM
    #115
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    I am getting ready to pull my bp51s at a mod day coming up (there is a spring compressor that I believe will work with the arb gear) they are currently at the factory set 20mm preload and I plan to adjust them down to 10-12mm, thanks to your reports on height gain/loss. Trying to get it right the first time. I have no extra weight up front except an aluminum ifs skid. Looks like you adjusted them beyond the factory settings (+6mm/+1mm)?, is this to make up the extra height you gained in the rear from the D29XL? Thanks for doing the leg work.
  16. May 3, 2017 at 7:23 AM
    #116
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Is it not easy to adjust the BP 51 ride height?
  17. May 3, 2017 at 7:29 AM
    #117
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    No, the shocks have to be off the vehicle to make adjustments.
  18. May 3, 2017 at 2:05 PM
    #118
    2016trdtacoma
    Trevor
    Utah
    wow, that sucks.
  19. May 3, 2017 at 2:21 PM
    #119
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Yes and no. With king or Icon you would have to pull them to replace the spring (that would be even more money) if you wanted to add a plate bumper and winch. Kings also recommends adjusting the shocks while off the truck as well.
  20. May 3, 2017 at 2:23 PM
    #120
    2016trdtacoma
    Trevor
    Utah
    I have had conniver over b4, never taken them off to adjust them. Curious why they recommend taking them off to adjust them?
