OME BP-51 Review on 3rd Gen
Discussion in 'Suspension' started by Jeffwels, Apr 11, 2017.
  1. Jan 10, 2018 at 8:25 AM
    #41
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    I have been experiencing some rubbing with 265/75/16s on stock suspension when I make a right turn over a bump/curb. Any thoughts if this rubbing will be eliminated when the BP-51 is installed? Hoping to get 3" out of it.
    Later.
  2. Jan 10, 2018 at 9:06 AM
    #42
    msoverland
    msoverland Mountain State Overland
    Appalachia
    2020 Tacoma DCSB
    Expedition Equipped
    Fantastic write up! We've had great success with our BPs on both the Tacoma and the 4Runner. Cheers!
  3. Feb 13, 2018 at 11:41 AM
    #43
    imjustabill1970
    bill
    clarksville, tn
  4. Jul 15, 2018 at 1:17 PM
    #44
    20taco16
    20taco16 Well-Known Member
    Beau
    2017 metallic grey double cab long bed 4wd
    I have the same setup, but after installing the coilovers before I took the truck out this weekend, I noticed that they feel like they are topping out......what are u running for the preload? Factory 20mm? What compression and rebound settings?
    I
  5. Jul 29, 2018 at 9:22 PM
    #45
    SpeySquatch
    2016 TRD OR DCSB
    It would be awesome if you or someone has driven both the medium 90021 kit and compared it to these. Curious to know noticeable differences. Truck looks solid with good stance in your pics. This is by far the sexiest suspension color and design out of the bunch (icon, Fox, king, etc.)
  6. Aug 4, 2018 at 6:35 PM
    #46
    jgallo1
    jgallo1 Well-Known Member
    Ca and MT
    1988 fj62, 2018 Tacoma
    I am about to pull the trigger on the BP-51 kit. I also have a 3rd gen tacoma dbcb. I was wondering how much lift the kit gave you?
  7. Aug 7, 2018 at 8:57 AM
    #47
    SAMSONITE88
    SAMSONITE88 Well-Known Member
    Samuel
    2016 White OR
    OME BP-51s, LR UCAs, Dakar Leaf Pack, Diff Breather Mod, TRD Pro's with 275/70/17 KO2s 1.5" spacer, Clazzio Seat Covers
    jgallo1[QUOTED] likes this.
  8. Aug 7, 2018 at 4:44 PM
    #48
    jgallo1
    Ca and MT
    Thank You
  9. Sep 9, 2018 at 2:11 AM
    #49
    ArmyYota
    ArmyYota Active Member
    Southeast, AZ
    Excalibur. Perfection. :bowdown: ((Que cheesy LARPer music...or something...)).
  10. Oct 13, 2018 at 1:09 PM
    #50
    swaze604
    swaze604 Member
    Cam
    2017 Tacoma TRD Offroad
    about to purchase this set up for my rig, Cant wait to shed these 5100s and get a big boy set up!
    WillTheThri11 and SAMSONITE88 like this.
  11. Oct 26, 2018 at 9:21 PM
    #51
    swaze604
    swaze604 Member
    Cam
    Hey Jeff, I am just about to buy the 51s, Update on how they have been doing? any issues?
    Also what did you have to do to run that tire size?
    thank you for all of your info.
    Cam
  12. Jan 17, 2019 at 12:22 PM
    #52
    supralee
    supralee Well-Known Member
    Lee
    Boulder, CO
    2018 Sandshark Tacoma DCSB 6MT TRD OR
    Great review! So a few questions for the OP or other who have installed the ARB BP51:
    • At the softest setting on the BP51, was the ride quality more comfortable or harsh when compared to the OEM TRD Offroad suspension?
    • Without UCA, where you able to achieve 0 camber and 0 toe? And also keep caster within spec?
    • I'm assume the BP51 is extend travel front and rear? If so how much additional travel does the BP51 have?
    Thanks!
  13. Jul 31, 2019 at 10:39 PM
    #53
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    do the BP-51 setup give you any extended travel length over stock or is it the same?
  14. Aug 3, 2019 at 9:10 PM
    #54
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    They arent extend travel but wooooo definitely one of the best suspensions out there right now
  15. Aug 8, 2019 at 12:00 PM
    #55
    1sandytaco
    1sandytaco Well-Known Member
    SLC, UT
    2015 - Black
    Supercharged
    I would love to try out a day on the trail using the BP-51's! They look amazing.
  16. Aug 13, 2019 at 10:54 AM
    #56
    jwillson77
    jwillson77 Member
    Jonathan
    Orlando, FL
    2019 Tacoma TRD DCSB OR 4x4
    Did you install the medium or heavy duty leaf's?
  17. Sep 18, 2019 at 9:27 PM
    #57
    ujacobm
    ujacobm Well-Known Member
    Jake
    Happy with my OME BP-51 set up. Just lowered the front to 10mm (came stock at 20mm). I don't have an aftermarket bumper and the 10mm. feels spot on.
    U402 Deavers, Stage 1, Medium Duty
  18. Oct 19, 2019 at 2:03 PM
    #58
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    how much of a lift did you get with this preload?
  19. Oct 20, 2019 at 9:54 PM
    #59
    ujacobm
    Jake
    When it came stock at 20mm I believe I had about a 2.25" lift. Now, having gone to 10mm on the OME BP-51, it's just under 2".
  20. Oct 30, 2019 at 10:12 AM
    #60
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    Are any of you running shims on the rear leaf pack? I notice the kit just comes with a shim for the carrier bearing correct? I’ve seen it mentioned others had to use a 2 deg shim the leaf pack due to vibrations. I’m trying to figure out if I should just order the shims and install them right away or try it without first.
    Going on a 2019 DCSB SR5.
