OME BP-51 Review on 3rd Gen
Discussion in 'Suspension' started by Jeffwels, Apr 11, 2017.
  1. Apr 24, 2020 at 4:52 AM
    #61
    TACOCAT Reversed
    TACOCAT Reversed Yum Yum Yum Yum Yum!!! - Cookie Monster
    NCentral Florida
    2018 Cement TRD OR
    Roll'N'Lock SEMA TRD Pro Rims General Grabber AT2 OME BP-51 Suspension Heavy Duty Dakar Leaf SPC UCA's CBI Fab Bolt on Sliders SSO slimline hybrid bumper Smittybuilt X20 Synthetic Winch Factor 55 Prolink 30" Baja Designs S8 Baja Designs SAE Fogs TRD Pro Grille Front and Rear Anytime Camera Expedition Essentials TPAM Meso Puddle lights Meso Ultimate Red LED dome Meso RED map lights Rear differential breather mod AC drain mod Oodles O Dynamat
    I have three weeks on mine, and the vibration is minor but there between 1 - 20mph. I got 2.5 degree shims but have not installed. Hoping it will take car of it. The 51s are amazing.
  2. May 4, 2020 at 8:05 PM
    #62
    WeDoPullups
    WeDoPullups Well-Known Member
    2020 TRD 4x4
    Bumping this. Looking to pull the trigger on these soon. Hoping there's more installs out there already
    I don't have any weight except sliders so I'll probably install at 15mm preload for now
  3. May 18, 2020 at 4:54 AM
    #63
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    Great write-up!
    Any long-term use thoughts/impressions/service/maintenance/problems?
    (I'm obviously on the market for a lift)
  4. Jul 6, 2020 at 10:40 AM
    #64
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    What spacers are you guys using? Anyone using the Headstrong 1/2 or 1/4?
  5. Aug 24, 2020 at 12:26 AM
    #65
    Team Scream
    Team Scream Well-Known Member
    Los Angeles Kali
    2018 TRD DCOR Quicksand 4x4
    Old Man $538.00 Sound System Upgrade w/Kicker DS in the doors, and a Cerwin Vega VPAS10 powered (10") sub under the drivers seat.
  6. Nov 29, 2021 at 11:02 PM
    #66
    SkipBurns36
    SkipBurns36 New Member
    2018 TRD Sport
    3” lift courtesy of OME BP-51s, BFG KO2 @ 285/70r17 on Black Rhino Warlord wheels (17”x8.5” w/-12mm offset)
    What weight are you hauling when you're hauling - and naturally, what are your offroad settings front and rear with that weight? Installing heavy duty BP-51 setup with OME's heavy duty leaf kit on an '18 TRD Sport (new diffs and lockers coming soon). Running 33" KO2s. Thank you in advance.
  7. Apr 17, 2023 at 8:29 AM
    #67
    Tommyboy12
    Tommyboy12 Member
    Tommy
    2021 TRD Offroad
    None
    I have the BP-51s on my pick-up. Icon UCAs, 285/75/16s, 1 1/4” spacers and 20mm of preload. I’m on 1 for comp and rebound all the way around. Rides very nice at speed, but the rebound seems harsh at times when rock crawling at slow speed. Anybody else have this issue? No added weight yet.
  8. May 29, 2023 at 6:11 PM
    #68
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    I’ve been set on bp-51’s for my 3rd gen since I’ve been wanting to get a great suspension setup and have read OME’s housing coating is a little more corrosion resistant than Kings. However I’m unlikely to do anything fast and really just want a great ride on road and occasional forest roads or semi technical Colorado or Moab trails.
    Would my money be better spent elsewhere?
  9. Aug 29, 2023 at 2:10 PM
    #69
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    Anyone receive these with the preload set to almost nothing? I just got these and the preload is barely 3 mm. The instruction manual says it should have been set to 20 mm from the factory. Should i be concerned?
  10. Sep 24, 2023 at 8:40 PM
    #70
    Jmk242
    Jmk242 New Member
    Josh
    2017 TRD O/R
    Hey man- great review. I know I’m late to the game here but I’ve had trouble dialing in my compression/rebound settings on mine for over a year now. I drive a lot of shitty bumpy roads and highways regularly and have a truck cap, tent and rear bumper on so trying to find a smooth and balanced ride but right now it’s super stiff and jostles around non stop on large and small bumps and pot holes. Any recs on settings? Thanks
  11. Jun 1, 2024 at 10:45 PM
    #71
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    I'm curious how these compare to Dobinsons MRR?
