OME BP-51 Suspension coming in 2015?
Discussion in 'Suspension' started by Box Rocket, Sep 15, 2014.
  1. May 9, 2016 at 8:01 PM
    #241
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Such as
  2. May 9, 2016 at 8:02 PM
    #242
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Binding, failure
  3. May 9, 2016 at 8:03 PM
    #243
    OZ-T
    Peter North
    British Columbia
    Failure of what , the balljoint ?
    Are you suggesting uniballs never wear out ?
  4. May 9, 2016 at 8:08 PM
    #244
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'm gonna play this game too. Apples are better than pineapples for headaches. #nofacts
    :kona:
  5. May 9, 2016 at 8:10 PM
    #245
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Less likely if you regularly service them. There are tons of threads on SPC/Light Racing ball joint's rampant failures. And yes I am aware there were "redesigned" ones. Besides, you get better alignment numbers, which can translate to better control/driveability. Seems like a lot to roll the dice on. But to each their own.
  6. May 9, 2016 at 8:11 PM
    #246
    OZ-T
    Peter North
    British Columbia
    K , so you know those issues are with the old arms but are using that as an example with the current arms
    legit
  7. May 9, 2016 at 8:12 PM
    #247
    Sandman614
    Tim
    '06 SR5 Off Road
    SPC light racing UCA's are all about adjustability... LR UCA's have more adjustments to get your alignment numbers where you want them. So how do uniballs give you better alignment numbers?
  8. May 9, 2016 at 8:33 PM
    #248
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    SPC ball joint UCA's are lower maintenance, probably quieter, and more adjustable. Yes, the ball joints may eventually wear out but they're not that expensive to replace.
    Uniball UCA's are stronger and will undoubtedly last longer, but also require more maintenance and some of them are prone to annoying noises/squeaks.
    These are just differences in UCA type, none of this has anything to do with why this setup specifically (BP-51) would work better with uniball UCA's as compared to ball joint UCA's.
    Solid Seung, IronPeak and T4RFTMFW like this.
  9. May 9, 2016 at 8:46 PM
    #249
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I meant travel brotha :anonymous:
  10. May 9, 2016 at 8:49 PM
    #250
    OZ-T
    Peter North
    British Columbia
    In this v ?
    Sandman614 likes this.
  11. May 9, 2016 at 8:50 PM
    #251
    OZ-T
    Peter North
    British Columbia
    You know what nevermind , too much nonsensical sideways threadjack
  12. May 9, 2016 at 9:05 PM
    #252
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Oz you going to get a set?
  13. May 9, 2016 at 9:05 PM
    #253
    Sandman614
    Tim
    '06 SR5 Off Road
    I ❤️ OME :drool:
    Red Baron likes this.
  14. May 9, 2016 at 9:14 PM
    #254
    OZ-T
    Peter North
    British Columbia
    Of the BP-51's ?
    Not soon
  15. May 9, 2016 at 9:30 PM
    #255
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Probably me. Mule's installing on the 24th!
    SCas and IronPeak like this.
  16. May 10, 2016 at 2:33 AM
    #256
    Blackouts
    Las Vegas, NV
    Like what? Axle shim in the back, or top plate spacer in the front?
  17. May 10, 2016 at 2:47 AM
    #257
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Blackouts likes this.
  18. May 10, 2016 at 5:43 AM
    #258
    Sandman614
    Tim
    '06 SR5 Off Road
    They're coilovers, you just crank down the driver side a little more to take care of the lean. No top plate spacer or trim packer needed.
    TacoCat, Blackouts[QUOTED] and scocar like this.
  19. May 10, 2016 at 6:52 AM
    #259
    IronPeak
    AuggieX
    Back to Back
    Well there you go, this is why TW is so great...
    @Blackouts , see this post
  20. May 16, 2016 at 8:00 AM
    #260
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    So did anyone order one of these kits or what?!?
