OME BP-51 Suspension coming in 2015?
Discussion in 'Suspension' started by Box Rocket, Sep 15, 2014.
  1. Sep 9, 2016 at 12:23 PM
    #441
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    I wonder if you could call arb and ask them about the valving on the Jeep ones. You would definitely have to get thru to the right rep. Like the designer in Australia lol.
  2. Sep 11, 2016 at 8:45 PM
    #442
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I actually happen to have a 2010 JKU along with the Taco... Might have to try this
    That's a negative... JKU comes in at 4,397 lbs based on published literature, that's only 28 pounds lighter than the published DCSB weight of a taco. I bet the valving will be really similar.
    I'll crawl under both here in a couple days and take some measurements on how they attach. I expect the top of the shock on the Taco will be different than the JKU.
    And yes @IronPeak4x4 , I realize "poorly designed" is probably exaggerated... But when these are made to be paired with their springs that provide lift (the dakar pack) and they don't accommodate the lift, I consider it a design oversight. They took the lazy way out and just went with stock length shocks. Shocks are not meant to be limit straps...
    luka likes this.
  3. Sep 11, 2016 at 8:48 PM
    #443
    IronPeak
    AuggieX
    Back to Back
    Looking at my shocks I appear to have equal uptravel and down, but yeah it is odd their shocks, both the nitro and these do not account for the downtravel possible with the dakar leafs they are paired with.
  4. Sep 11, 2016 at 9:00 PM
    #444
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    In for results.
  5. Sep 11, 2016 at 9:03 PM
    #445
    IronPeak
    AuggieX
    Back to Back
    How about a pic of the top shock seat on the jk? That might give an idea if they fit. The pics of both the jk and the taco bp-51s look similar if not identical. If they fit I may get them, and sell my existing rears
  6. Sep 11, 2016 at 9:12 PM
    #446
    IronPeak
    AuggieX
    Back to Back
  7. Sep 11, 2016 at 9:31 PM
    #447
    Sandman614
    Tim
    '06 SR5 Off Road
    Crom and IronPeak[QUOTED] like this.
  8. Sep 11, 2016 at 9:34 PM
    #448
    IronPeak
    AuggieX
    Back to Back
    So by your measurements the superbump flip kit available is not tall enough? Is that why you built a taller seat? Looks good BTW
  9. Sep 11, 2016 at 9:35 PM
    #449
    Sandman614
    Tim
    '06 SR5 Off Road
    I didn't even look at them. Here was my process
  10. Sep 11, 2016 at 9:39 PM
    #450
    IronPeak
    AuggieX
    Back to Back
    Thanks for doing the legwork , about the shocks not bumps, it looks like your droop/compressed match the shock. How would the extended length shock benefit us? And would we lose an inch of up travel? Would they require a mount relocate?
  11. Sep 11, 2016 at 9:43 PM
    #451
    Sandman614
    Tim
    '06 SR5 Off Road
    Those numbers are with the BP51s installed. I was measuring for the bumps. My spring only droop is about 28"
    IronPeak[QUOTED] likes this.
  12. Sep 11, 2016 at 9:46 PM
    #452
    IronPeak
    AuggieX
    Back to Back
    So when u flex and extend with your current setup the shock tops out? Or do you have limited strap?
  13. Sep 12, 2016 at 4:43 AM
    #453
    Sandman614
    Tim
    '06 SR5 Off Road
    No limit straps, I just try not to slam my suspension down (get air).
  14. Sep 13, 2016 at 7:41 PM
    #454
    Sandman614
    Tim
    '06 SR5 Off Road
  15. Sep 13, 2016 at 8:28 PM
    #455
    IronPeak
    AuggieX
    Back to Back
    I call it my luxury lift rides like a Cadillac on the streets and rocks the trails too
  16. Sep 13, 2016 at 8:34 PM
    #456
    Sandman614
    Tim
    '06 SR5 Off Road
    IronPeak likes this.
  17. Sep 14, 2016 at 12:17 AM
    #457
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Sub'd!@IronPeak4X4 knows that i inquired on another OME thread as of recent!:thumbsup: @IronPeak4x4
  18. Sep 25, 2016 at 1:11 PM
    #458
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Has anyone looked in to fabbing mounts to move the lower shock mount up by +/- 2" to compensate for the additional droop of the Dakar springs? Then installing the appropriate length bump stops?
    I'm really liking what I'm reading about the BP-51 set up for adjustability without the cost of going to a full bypass shock. I had ADS triple bypasses on my Tundra paired with Deaver springs and they rode amazingly well but that rear set up was damn near $3000 by itself.
    If I get the kit and then find myself wanting additional rear droop I'll try to accomplish it without changing the shocks out
  19. Sep 25, 2016 at 4:12 PM
    #459
    narshkey
    narshkey Fabrication Designer
    CDN
    In progress
    In progress... oh boy
    If you figure it out I am sure there is a lot of us that would be grateful.
  20. Sep 25, 2016 at 5:46 PM
    #460
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    I would imagine it's a pretty simple reworking of the bracket that arb provides. To basically take their L shape and make it more of a U so that the mount point moves out and up instead of just out. Over simplified i know but its just an idea
